Reply
Thread Tools View Mode
Old 8th Jun 2010, 21:07   #41
ModaRobby
Supermodder
ModaRobby's Avatar
ModaRobby has yet to learn the way of the Dremel
Originally Posted by AnG3L View Post
Oups I didnt read the post that you sanded the surface. I was going to say you should sand. Prime always though in any surface!
So as long as I sanded I'm good? I hope so because all this work I did only to have it crack would piss me off.
__________________
I've seen a lot of mods in my life and I've noticed something. Some of them, they are so complicated with so many blink blinks, little lcd's popping out from everywhere etc etc. U can paint your case red and add a watercooling system and maybe it will look waaaaaaaaaay better than a mod that costs 6000 dollars with all of these useless thingies in it! Btw, modding is art and we are some goddamn good artists!!!
ModaRobby is offline   Reply With Quote
Old 9th Jun 2010, 03:12   #42
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
Originally Posted by ModaRobby View Post
International shipping? And why does your location say CA USA/Delhi? I know Delhi is in India but why did you also put California?
I live in India but go to Univ (not for much longer) in California.
International shipping doesn't handle pressurized goods like spray cans.
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is offline   Reply With Quote
Old 9th Jun 2010, 03:35   #43
ModaRobby
Supermodder
ModaRobby's Avatar
Oh I get it now. You need to go to your local Home Depot in California and stock up on all the American stuff you can!!! No offense to products in India.
__________________
Old 9th Jun 2010, 05:13   #44
Remmes
Be One With Your Mod
Remmes's Avatar
Remmes has yet to learn the way of the Dremel
lmao, sir, why do you have all those cans of spray paint?.. i am going to spray my computer..... yeah right, you were going to blow up the airplane!!!!
__________________
Originally Posted by bulldogjeff View Post
I wouldn't go round bragging to the ladies that you got a floppy that keeps popping out, especially if it's only a 3,1/2 inch
Remmes is offline   Reply With Quote
Old 9th Jun 2010, 07:09   #45
stonedsurd
stonedsurd's Avatar
They have regulations on carrying pressurized containers on airplanes
Exactly. Turban+beard doesn't help either.
__________________
My Flickr
Old 9th Jun 2010, 09:42   #46
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Steel comes with a protective coat so if you sand and paint you are good to go, but it wont be so durable as - sanding - prime - sanding - paint - sanding - paint .
AnG3L is offline   Reply With Quote
Old 9th Jun 2010, 12:56   #47
ModaRobby
Supermodder
ModaRobby's Avatar
Well you could always come to Florida and sand all this for me? I will be sanding in between coats of color. It depends on what part it is:
bare metal = wetsand + 3 coats of color (sanding in between) + 2 clear.
Painted metal = wetsand + primer + wetsand + 3 color (sanding in between) + 2 clear
Im moving to Delaware later in june/early July and my grandfather has a sand blaster in his autobody shop so all this sanding will be gravy later
@Remmes LMFAO
Now that I have people following my log: Is there anyway at all to get a Triple-Monitor (Eyefinity) setup using Nvidia GFX cards? The card in question is a PNY GTS 250 1gb edition. I googled it but a lot of the threads were from 2007 and earlier. Is softth a good option or do I need two Nvidia cards running in Non-Sli to have the extra display ports?
One more thing: My list keeps getting bigger...
__________________
Old 9th Jun 2010, 13:52   #48
Remmes
Remmes's Avatar
1 card usually has 2 DVI ports + a tv out or HDMI so 3 ports ( depending on the card)
__________________
Old 9th Jun 2010, 14:03   #49
ModaRobby
Supermodder
ModaRobby's Avatar
SO, if I use a HDMI -> DVI adapter on my GPU I can run 3 monitors using Softth?
__________________
Old 9th Jun 2010, 15:08   #50
Remmes
Remmes's Avatar
afaik, yep
__________________
Old 9th Jun 2010, 15:13   #51
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Ahh, the list. Every time I make one things tend to get added as I go or things get started and never finished. Plus, looking at a long list makes me feel like I will never get anything done lol. They do help though .
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 9th Jun 2010, 16:01   #52
ModaRobby
Supermodder
ModaRobby's Avatar
Well if you take a look at it, most of it is slotted mesh so it isn't a lot of diverse stuff. I love that mesh, and not a lot of modders have used it from what I've seen.
As of right now, literally, I am sanding all the paint off of the stuff that I painted flat black because I decided to take Ang3ls advice and prime > wetsand > flat black > wetsand > flat black.
That way it is durable and I dont have to clear coat it which will make it shiny. Pics in two hours or so.
__________________
Old 9th Jun 2010, 19:00   #53
Remmes
Remmes's Avatar
clear coat wont make it shiny if you got the right coat ( like i do) , if you really want to do without clear coat i think you'll need some more coats of flat black..
__________________
Old 9th Jun 2010, 22:40   #54
ModaRobby
Supermodder
ModaRobby's Avatar
@Remmes: All this painting **** is so controversial. I think I'm just going to walk into the closest auto body shop and ask what works and what doesn't. Lol.
Time to show you guys what I've been up to all day.
Update 5: Another Day of Painting
I took Ang3l up on his suggestion about the clear coat on the flat black paint, which is to not use any. I wanted to have the contrast between Gloss Blue and Flat Black. I also didn't want to go spend another 18.00 on Satin Clear Coat (no gloss)
I started by sanding the side panel, rear I/O shield, secondary PCI slot, and 2.5" bay adapters. No progress pics but why bore you with sanding? Anyway, after I sanded everything I grabbed my can of Primer out of the closet and went to town.
I was quite pleased with the results until I saw this.... Since I'm a genius I decided to put my painting products on the shelf with all the other spray paint. So my can of Primer blended right in with this stuff.....
Cold Galvanizing Compound is a type of paint with Zinc in it that your spray on barbecue grills to prevent corrosion. WELL.... It is not a good primer because when you spray it on something it scratches off as easily as a scratch off lottery ticket. Literally, scratch off tickets are made from Zinc....... So now I have to deal with this.
The annoying part is the cans look exactly the same....
And you thought scratching your Mom's lottery tickets was fun... Happy thought evaporated.
And this is what I have left after about 25 minutes....
And this is what my 220 grit looks like after 35 minutes. You can actually see that after sanding it for awhile, the paint "buffed" and the zinc starts to shine.
Btw, I didn't win anything scratching off all those parts.
Here is the result after a coat of Primer, some wetsanding, and a coat of some flat black.
Now these I actually did properly because I happened to take a smoke break before I did these. Which is when I noticed the Galvanized garbage (which btw have been duct taped shut inside of a shopping bag)
Secondary PCI bracket, I/O shield, and 5.25 > 2.5 bay adapters.
I also put a second coat of paint on some parts but it doesn't look any different from a few days ago. I do have a couple of sample pictures.
I snapped this one to show the direct contrast between the gloss and matte colors.
Remember those buttons I painted from the tool-less drive bay assemblies? (best picture so far huh?)
I thought I was done for the day until I went upstairs and noticed the front fascia to my HAF was out of the box. I noticed even further that I did not paint the front grill.
The annoying part about this is that I had tried to paint the grill a few weeks ago. (a really hideous metallic blue, my attempt at a glittery powder coat look. Fail) Which reminded me that I had used that Galvanized garbage as Primer because I didn't have any real primer...
SO not only did I prime it with a paint that has the dried consistency of a scratch off lottery ticket, I also put 3 coats of paint over it...
Here is the color difference (sorry for the blur)
I began to sand it off using the last of my 220 grit and then wetsanding with 320, then I noticed that the paint was caked in between the holes.
And the solution.
And there I sat, chain smoking and brushing that for the next 20 minutes.
Time to break out the big guns. Or maybe just my Dremel... Here is whats left of my brush attachment after another 15 minutes or so.
And now it hangs all nice and Primed for color.
Look at this smiling asshole! Nice and shiny mobo panel.
One more bit before I head off. I went to my local Home Depot this morning to pick up some rivets and they only had white. Not even regular silver. So you know what they say, if life gives you white rivets you paint them black and blue!
I used my almost empty can of Sail Blue to create the splatter effect on the rivets. Here's a pic after painting and a layer of clear coat.
That's all for today guys and girls, but not until I give you the obligatory lunch and backyard photo. Mmmm stir fry.
Keep this in mind: I love constructive criticism, so comment away.
If you like my log then SUBSCRIBE!!.
__________________
Old 9th Jun 2010, 23:50   #55
The boy 4rm oz
Project: Elegant-Li
The paint looks much better now, a nice even coat with a nice finish. Priming really is a must, especially when working with alu.
__________________
Old 10th Jun 2010, 00:39   #56
AnG3L
Ultimate Modder
AnG3L's Avatar
Thanks for listening to my advice. Check my worklogs you will see some painting techniques and also you will see the proper way to spray paint and curing. If you cure using an oven its a different story. I have created techniques with 38 layers of paint so if you didnt see my work
check my channel it will help you and give you some ideas : http://www.youtube.com/user/chinoangel1
Feel free to ask any questions. Remember though, patience and dedication brings results, rush brings disasters.
Old 10th Jun 2010, 04:14   #57
ModaRobby
Supermodder
ModaRobby's Avatar
QFT on the rush brings disasters. That is why I spent an extra 45 minutes sanding and brushing that damn front grill. Lol. And 38 layers of paint? WTF?
I figured that if I'm going to paint something, and I've never spray painted before, I might as well take advice from the guy who has done some seriously awesome Projects and paintings. I must have read Project Ang3l about 3 times. Your first two updates blew me away, not to mention the art you showcased in the first post; very awesome.
I'll be checking out your tuts tomorrow, on my to-do list (not the project to-do list). Now it's time to sleep.
Anyway enough praises, back on topic, before I decided to wetsand the side panel (after the first paint attempt) I sprayed a coat of high gloss clear coat on the Matte Black paint and it looked terrible. So I'm glad I started over on that one. I may go to Home Depot sometime and get some Satin Clear Coat. It has no gloss and I tested some on some of that High Gloss Sail Blue Enamel and it came out looking Matte, meaning it completely took away whatever gloss was in the blue enamel. So I may do that to add durability (instead of 38 layers of paint)
__________________
Old 10th Jun 2010, 10:07   #58
AnG3L
Ultimate Modder
AnG3L's Avatar
Thank you my friend for your so kind words, as the quote says in your sig (thanks :P ) I am just an artist enjoying my journey through creation and learning! I ve learned from other modders so its my duty and every modders duty to guide a friend and dont keep the secrets for himself.
I will be here to help as much as I can and any time you like you can send me a pm with any questions and I would be really happy to help!
Mod on brother! Creation needs inspiration!
Old 27th Jun 2010, 21:46   #59
Jelle46
Belgian freedom
Jelle46's Avatar
Jelle46 has yet to learn the way of the DremelJelle46 has yet to learn the way of the Dremel
hey, looking good, pal.
Like the Ipod Dock
I should have patended it
keep up the good work!
__________________
CIP COSMOS
CIP G5 H2O
Asus Maximus Formula / E8400 / 8GB RAM / Club3D 4870 1GB / Silverstone 750W modular / 2 x 500GB Samsung HDD in RAID 0
Jelle46 is offline   Reply With Quote
Old 28th Jun 2010, 14:00   #60
ModaRobby
Supermodder
ModaRobby's Avatar
Hahaha. I definitely got it from your cosmos project. It's such an awesome thing.
__________________
Reply
Tags
922, blue, coolermaster, haf, modarobby
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
