Scratch Build – In Progress concretronic
Discussion in 'Project Logs' started by Sonnenschein, 3 Jun 2010.
  1. Sonnenschein
    Sonnenschein What's a Dremel?
    6 Mar 2008
    Hello,
    I hope you still know me if no, I´m the guy with the PC in a tree trunk, the PC in shape of a sinecurve and I try to build a PC in shape of a sail with 24 carat leaf gilding.
    Well unfortunately I have to intermitted the project “golden sail” because I was one of five persons who could take part in the be-quiet! casecon contest.
    The motto of the contest was “See you PSU with our eyes, as heart of your PC” and at the following pictures you could see my concept for the contest.
    The shell of this PC should be made of real concrete and it should be flawless and seamless that means that I needed one shuttering and in the shuttering I had to integrate the windows and the fixing for the other parts of the case. To give the PSU something special was my plan to mount the PSU-board in the upper part of the case and sleeve all cables.
    With this plan in my head I started with the shuttering for the concrete.
    In this arc made of Plexiglas I bored later a lot of M4 threads to fix the steel sheets on it. Because only one arc isn´t so practical for fixing I made a second on, stabilized them with two Plexiglas sheets and connect the two ones.
    Ready with this I could start with bending the steel sheets.
    I used 1,5mm steel and for the whole shuttering I needed ca. 1 square meter steel sheet.
    After bending them all I drilled a lot of holes in the steel and transfer them to the Plexiglas arcs. Now I was able to drill the M4 threads in it to fix the sheets later on it.
    Now I changed the material from steel to Plexiglas at the one hand 10mm thick and on the other hand 4mm thick. With this Plexiglas I made the empty space for the two windows in the concrete case.
    After the shuttering was build I could started with the armor for the concrete. For this I used 4mm welding rod, 1,5mm steel sheet and some screws.
    To build the shuttering and the armor I needed nearly 2 months but I had to make all very exactly because of the deadline I hadn´t a second chance.
    I had to walk all over the down town to bring the shuttering to the construction engineer where the concrete came into it.
    When the concrete was hard the decisive moment for this project came – the taking off from the shuttering.
    How you could see at the pictures the big time involved was worthwhile and I could started to fit all the aluminum sheets I needed for the front, the back, the bottom and the for the fan grills.
    After I was ready with cutting, filing, grinding and all peaces fitted perfectly it was time to milling all ventilation slits I needed for the 11 fans.
    I brought all this aluminum sheets to a to powder coater who made them white.
    In the meantime I made to things, at the one hand I made a CAD-Model of the two sensors for the front. A 5-axes CNC milled them for me and I made a negative from it with silicon.
    In that form I casted concrete to get real concrete sensors at the end.
    At the other hand I build the “inner-space” with 6mm thick Plexiglas.
    I brought this thing to a paint shop for painting it white, too.
    Well at the following picture you could see the powdered aluminum sheets that I needed for the case.
    And now I could started with sleeving all the cables I used black and gray sleeve.
    Unfortunately I crashed one PSU that I had totally sleeved, so I have to start new. Because of this I came into time pressure and couldn´t take so many pictures from my sleeving work. But I think real interesting are anyway the final pictures…;-)
    Like I said at the beginning of this post was the case for the be-quiet casecon contest and here you could see the other three competitors and at this link you could vote for your favorite case. Under all voter´s be quiet raffled a lot of great products for example a be quiet Dark Power Pro 750W.
    Happy Voting and Modding!
    dullonien and stonedsurd like this.
  2. stonedsurd
    11 Mar 2009
    A concrete case. You win the internets. That is sheer awesomeness.
  3. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Wow just when it seems there's nothing new out there you come along with this! Great work man! Dare I ask the question that's on everyones lips .... How much does it weigh?
  4. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    That is pure unadulterated win my good sir!
    Awesome!
  5. subset7
    subset7 Spanking the Monkey
    31 Aug 2008
    Great work and very original,I wouldn't like to take it to a LAN though.
  6. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    Concrete :jawdrop:
  7. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Holy crap! That's completely awesome in every way! Great job man!
  8. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    heavy sh*t man! (get it? :D)
    at least your computer is bomb-proof now. no jealous competitor is going to be able to wreck this thing:D love it.
  9. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    That the only computer I see that you would be more worried about the floor than the the PC itself if it falls from the desk.
  10. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    I am always amazed by your new ways of modding and not being afraid to use ANY material. You are a true modder my friend keep on rollin' !!! :)
  11. kenco_uk
    28 Nov 2003
    It deserves at least ten internets. My guess on the weight is 50kg.
  12. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    So many people say that there computer ways a "TON" I think you might be the only one that has a PC that ways that much...
  13. amagriva
    amagriva Minimodder
    13 Jun 2009
    I was asking myself if concrete was a sort of aluminum or plexy that I didn't know (cause I'm not mothertongue) and then I saw....He really poured concrete! Man that's really new for me! Bravo!!!
  14. Cheapskate
    13 May 2007
    :clap: It's hard to do something truly unique mod-wise anymore. You did it with style.:D
  15. nlancaster
    nlancaster Minimodder
    21 Dec 2009
    fraking brilliant!!
    That is one material I have never thought of building a case out of.
  16. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Ive always wanted to make a concrete case, but never built the courage to do it. It really does look amazing :thumb::thumb:
  17. Doglobster
    Doglobster What's a Dremel?
    26 Jun 2009
    Congrats on a, having such an original idea, and b, pulling
    it off with such aplomb.
  18. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    There are no words accurate enough to describe this amount of genius :)
    P.S. Gain a man point for leaving it in its natural finish.
  19. Jelle46
    Jelle46 Belgium
    14 Feb 2009
    Sir, there are no words to tell you how much I like this unique idea!
  20. SWISS.SY
    SWISS.SY Precision + Quality Tools = Epic
    3 Apr 2009
    Great Build, it is truly one of a kind!
