Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Jun 2010, 15:09   #1
Lizard
@ Scan R&D
Lizard's Avatar
Lizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run Crysis
Asus Immensity: ROG board with on-board HD 5770
We preview the Asus Immensity, a concept board with a built-in mid-range GPU.
http://www.bit-tech.net/hardware/mot...oard-hd-5770/1
Lizard is offline   Reply With Quote
Old 3rd Jun 2010, 15:28   #2
DorkSterr
Hakuna Matata
DorkSterr's Avatar
DorkSterr has yet to learn the way of the Dremel
Wow! on-board HD 5770?!
__________________
i7 980X @ 4510.0MHz 1.4250V | ASUS Rampage III Extreme | Dominator GT 2038MHz 7-8-7-20 C7* | ASUS EAH6970 925MHz/1385MHz |RAID 0* 120GBX2 OCZ Vertex 3 (OS) | Corsair AX1200 | Corsair Obsidian 800D
DorkSterr is offline   Reply With Quote
Old 3rd Jun 2010, 15:33   #3
Material
Soco Amaretto Lime
Material's Avatar
Material is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpit
Just don't try it with Fermi unless you want a hole in your motherboard
__________________
bit-tech on Facebook - Custom PC on Facebook - bit-tech on Twitter
Steam ID: votelarry - BFBC2 ID: M4terial - Feel free to add me
Material is offline   Reply With Quote
Old 3rd Jun 2010, 16:07   #4
13eightyfour
Formerly Titanium Angel
13eightyfour's Avatar
13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan
The problem is its more than likely going to cost more than the equivalent mobo and GPU separate, Unless the lucid chip sees a massive improvement i cant see this taking off tbh.
If it was an matx 1156 with a built in 5450/5770 it would be great for a media comp.
13eightyfour is online now   Reply With Quote
Old 3rd Jun 2010, 16:23   #5
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
Wow! On board 5770? That'd be a killer to cool efficiently without blocking anything.
Sounds more like a 5450, TBH.
rickysio is offline   Reply With Quote
Old 3rd Jun 2010, 16:25   #6
Glix
Left Thumb Stick in the mud.
Glix has yet to learn the way of the Dremel
Whilst I like the idea of a mid end card on the mobo. I think that ATX is the wrong platform to use it on. Like above me says, m-ATX and it would be great for media comps as all it does here is take up lanes on a X58 board where you wouldn't even consider using a mid end card with. Thankfully it's only a prototype to demonstrate the idea.
Glix is offline   Reply With Quote
Old 3rd Jun 2010, 16:32   #7
CharlO
Multimodder
CharlO has yet to learn the way of the Dremel
Do want, here are my life savings. Only, will you please also add a 64gb ssd to boot the os? I'll die happy after unboxing.
CharlO is offline   Reply With Quote
Old 3rd Jun 2010, 16:48   #8
Lockon Stratos
I Will Snipe You!
Lockon Stratos's Avatar
Lockon Stratos has yet to learn the way of the Dremel
It would be nice if that onboard 5770/5450 can be hybred crossfired that would be total poonage. - imagine....2 5970s+integrated 5770 in hybred crossfire. though i suppose there would probably be some serious driver/Ai issues with the gpus fighting over work or deciding what sort of work to make the integrated chip do.as its not as powerful as the other GPUs...
guess we wont know until we get some reviews.
on a side note - its a pitty Asus cant be this Gung Ho about their soundcard dept. their drivers are stable but they could do with lots of tweaking. the DS3DGX eax emulation engine could do with a little fine tuning too. theres quite a few games out there that dont work properly with Xonars when it comes to EAX. but Asus just dont seem interested in building a decent tweaked driver that fixs the issues.
these guys in the interview seem genuinely passionate about their company & their products. now if only they could channel some of that enthusiasm into the audio dept.
Lockon Stratos is offline   Reply With Quote
Old 3rd Jun 2010, 17:04   #9
Sloth
#yolo #swag
Sloth's Avatar
Sloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming Saiyan
If they do release a model including a decent GPU I'd be tempted to purchase it for my next upgrade. If the Hydra really works as intended and provides decent performance then why not use it to blend my 5870 with a built in 5770 and get a little more performance and future proofing? Seems like that's the real goal listening to what the interview said: allow people who already have a dedicated graphics card get added gaming performance from their motherboard through the use of the Hydra.
Only slight draw back I see happening is it physically taking up the top couple expansion slots, but seeing as a full card would take up a couple anyway who cares?
__________________
Intel i5 2500k | Gelid Tranquillo | ASUS P8P67 | G.Skill Ripjaws 8GB | XFX 7970 Black Edition | SeaSonic X650 | Intel X25-M 160GB | WD Caviar Black 1TB | CoolerMaster HAF922
Dell U2412M | 2x Samsung Syncmaster 931B | SteelSeries Siberia V2 | Razer DeathAdder 2013 | Leopold FC200RR/AB | Leopold FC200RC/AB
Sloth is offline   Reply With Quote
Old 3rd Jun 2010, 17:10   #10
shadow19935
Whats overclocking? :D
shadow19935 has yet to learn the way of the Dremel
You could have a HD 5970 + HD 5870 + HD 5770 and the onboard HD5*** an none of the cooling fans would be obstructed by the other GPU!! PURE WIN!!
shadow19935 is offline   Reply With Quote
Old 3rd Jun 2010, 17:44   #11
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
I'm going to go against the grain here and say having an on-board GPU is a BAD idea. Why?
1) That integrated GPU is taking up a 16x PCI lane that could be used on a more powerful card.
2) Integrated GPU with an i7 9xx CPU? Really?*
Bottom line is that if you want an X58 motherboard, you're most likely looking at a 5850+ anyway.
*I can think of some people who'd want to build a powerful FEA computer and wouldn't be interested in a stupidly powerful GPU. In which case, this would actually be quite a useful mobo.
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 3rd Jun 2010, 17:46   #12
alpaca
llama eats dremel
alpaca's Avatar
alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.
I clicked, and I immensified the Immensity.... MOUHAHAHA
(yes, I really felt that way. It was great.)
__________________
my English may not be as good as I think it is...
alpaca is offline   Reply With Quote
Old 3rd Jun 2010, 17:57   #13
Sloth
#yolo #swag
Sloth's Avatar
For point 2, judging by the presence of the Hydra and by the RoG naming, this is certainly not meant to be used as a standalone graphics solution. It's not just integrated graphics in the traditional sense, it's more like additional graphics. Like one of the gentlemen in the interview says, the idea is to provide integrated graphics which won't be wasted when additional GPUs are added, and instead support them.
Following that for 1, it would seem that it could easily be wired up to run at 8x, which would probably be fine for a 5770 or less, which should allow for two more 16x slots (X58 provides that many, right?). That would allow for 2 cards in full Crossfire/SLI as well as a 5770/5450. The only situation which really starts holding a person back is the likely inablity to use tri-SLI/Crossfire. Crossfire solutions could go 2x5970, so 3x5870 is somewhat rare, so ATI solutions are largely unaffected. SLI would allow for two cards of choice, such as 2xGTX480, with only extra high end system such as your own being affected.
__________________
Old 3rd Jun 2010, 18:04   #14
neocleous
Hypermodder
neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.
Forgive my ignorance but why would I want to mix ATI and nVidia cards together what is benefit over a straight ATI crossfire or nVidia SLi setup
neocleous is offline   Reply With Quote
Old 3rd Jun 2010, 19:12   #15
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
Jackie: [...] Recently, I went to Brazil, India and those countries, they don’t want so many high-end boards, they don’t want ROG boards...
Next time you see Mr. Hsu, please tell him that the reason no one wants ASUS in India is because they're selling their stuff at about 20% more than competing products and their local distributor is the spawn of Satan.
It has nothing to do with ROG or non-ROG boards.
__________________
stonedsurd is offline   Reply With Quote
Old 3rd Jun 2010, 19:20   #16
Unknownsock
Supermodder
Unknownsock has yet to learn the way of the Dremel
So when you upgrade to a new card you can still use your old card along side it.
Unknownsock is offline   Reply With Quote
Old 3rd Jun 2010, 20:14   #17
hbeevers
Yes, it can play crysis!
hbeevers has yet to learn the way of the Dremel
This is a great idea for future upgrdes! I'm only running an i3 cpu at the moment with an asus hd 5770 but in the future i'm looking to upping to an i7, this would mean that i could also see a GPU improvement with only buying a new CPU and mobo, hopefully this combo would be cheaper than buying a decent lga1366 mobo and 5770 seperately though. It's also great for future proofing, keep your old card AND use the new one no matter what manufacturer it is.
__________________
Intel Core i5 4690K / Gigabyte GTX 670 / Corsair H75 / Coolermaster Advanced CM690 II / 8GB RAM / 256GB SSD / 1TB HDD
hbeevers is offline   Reply With Quote
Old 3rd Jun 2010, 22:20   #18
willyolio
Multimodder
willyolio's Avatar
willyolio has yet to learn the way of the Dremelwillyolio has yet to learn the way of the Dremel
i want to see some benchmarks of this baby. and also how well the Lucid chip works.
willyolio is offline   Reply With Quote
Old 3rd Jun 2010, 22:40   #19
javaman
May irritate Eyes
javaman's Avatar
javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.
So Asus possibly integrate an HD5770 into their motherboard while AMD (and intel) aim to integrate that level of performance into the CPU.
javaman is offline   Reply With Quote
Old 3rd Jun 2010, 23:34   #20
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
In a mini-itx formfactor?
No?
Then I think I'll skip
Guinevere is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
