Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 7th Jun 2010, 10:42   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
Adobe warns of Flash, Acrobat attack
http://www.bit-tech.net/news/bits/20...robat-attack/1
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 7th Jun 2010, 11:06   #2
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
That's exactly the problem with PlugIns...
...they add security-risks.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 7th Jun 2010, 11:10   #3
Bakes
Hypermodder
Bakes has yet to learn the way of the DremelBakes has yet to learn the way of the DremelBakes has yet to learn the way of the Dremel
This article suffers from a classic case of putting two and two together to make five.
The problem is to do with Acrobat incorrectly handling embedded SWF files. It's not a vulnerability in either Flash or Shockwave so-to-speak, merely in the way that Adobe has handled it in Adobe Reader.
As the guy from Sophos said, why would I ever want to open an SWF file in a PDF file? Sure, it could be useful for a few people in select situations, but until five minutes ago I never even knew it could be done! Adobe deserves to be criticized, but saying it's a reason not to use Flash is like saying that you shouldn't use the web because every browser has security holes and you could be hacked through one of them.
In terms of whether Steve Jobs could be right, the fact that Apple products are consistently shown to be insecure would make any justification based on security seem to be hypocritical.
For iPhone, I'm talking about sending an sms to crash the phone, sending an sms to take control of the phone, using a web page to view someone's sms', etc.
For Macs, I'm talking about using links that can take control of the system, emails that can take control of the system, etc.
At least Adobe knows that it needs to cut down on these embarrassing security problems. Apple has the benefits of security by obscurity, so it's security is never tested as much. Which never seems to stop hackers getting through Safari in less than ten minutes. Flash is installed on 99% of computers, according to Millward Brown, which makes it even more open to attack than Windows. It's unsurprising that security problems are found frequently, almost every system has vulnerabilities and bugs, and most of them are fixed by simply not running under an admin account.
Bakes is offline   Reply With Quote
Old 7th Jun 2010, 11:40   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Sounds like you're struggling a bit with the mathematics yourself, there: the flaw exists in both Adobe Reader *and* Flash Player.
To quote Adobe: "A critical vulnerability exists in Adobe Flash Player 10.0.45.2 and earlier versions for Windows, Macintosh, Linux and Solaris operating systems, and the authplay.dll component that ships with Adobe Reader and Acrobat 9.x for Windows, Macintosh and UNIX operating systems." (my emphasis)
HTH.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 7th Jun 2010, 11:44   #5
NuTech
Mod Master
NuTech's Avatar
NuTech can run CrysisNuTech can run CrysisNuTech can run CrysisNuTech can run CrysisNuTech can run CrysisNuTech can run CrysisNuTech can run CrysisNuTech can run CrysisNuTech can run CrysisNuTech can run CrysisNuTech can run Crysis
Adobe, you're really not helping your case with Apple here.
__________________
NuTech
NuTech is offline   Reply With Quote
Old 7th Jun 2010, 12:18   #6
Bakes
Hypermodder
HTH.
Ah yes, but the vulnerability is only found when you are using Acrobat, it can only be exploited when Flash files are embedded in a PDF file. That's what I meant by 'so-to-speak', there is a vulnerability in Flash but it's dependent on other more important conditions before it can be properly exploited, it's entirely to do with the integration of Flash and Acrobat and the way that Acrobat handles Flash files. From what Adobe have said, there seems to be absolutely no problem with Flash applets in any web browser (with this specific exploit, anyway).
Old 7th Jun 2010, 13:23   #7
Showerhead
Ultramodder
Showerhead's Avatar
Showerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run Crysis
And that's why i don't use adobe reader. Unfortunately as a hige chuck of the internet uses flash i'm kinda stuck with it.
Showerhead is offline   Reply With Quote
Old 7th Jun 2010, 13:29   #8
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
Jobs : Kekekekekeke
rickysio is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
