#1 |
Multimodder
Project Intel "Ice" Video added 07/24/10 liquid resin case
Well after a long break I am back at doing some modding projects, I have 4 total that I wanted to have completed by the end of the year.
The first Mod is called Intel Ice, Featuring a Intel® Desktop Board D945GSEJT Atom CPU mini itx Board Sponsored by Intel, Looking to make it my Home Media Server. I t will set in a a Custom fake arclyic ice case. Let Begin Parts List Plexi Glass Plastic Resin Vandal Switch DC power adapter ( on order) Intel® Desktop Board D945GSEJT Mother Board Sponsored by Intel!!!! PCi min express wireless Card ( on order) Wireless Logitech Keyboard and mouse Western Digital hard drive Win 7 2 80 mm Blue led fans mixing bowl /wood spoon aluminium foil 2 boxs one slightly bigger than the other!!! ![]() ![]() ![]() ![]() The mold Not much Card Board and aluminum foil Lets Begin ![]() 64 fl oz of Plastic resin 1/2 oz of catalyst hardner Mixed it it for 60 sec ![]() Poured the top of the case in the moldto about 1/2 inch deep. Then waited 30 min till it start to gel then I put a second box on top to make inside walls. pour the remaining resin in to make the walls. I had to apply a little weight on top of the inside box to keep from floating up. This will set overnite to cure and make sure you are in a well ventilated area. Last edited by jj_sky5000; 24th Jul 2010 at 14:06. |
#3 |
The modding head is firmly back on.
I've seen this affect before but never actually seen any 1 do it, looks like it's off to a good start
#4 |
theorycrafting
That's a great idea and it makes the process of resin-cating so much more easier.
I'm trying to cast a case for an mITX-system aswell, but I was more thinking of something with an even and polished finish and I've troubles to make the moulds... resin-casting with 0.5mm clearance isn't particularily easy, if you don't have a CNC to mill the moulds
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#5 |
Danish Kid :D
Looks interesting. Keep working! Wanna see where this is going
#6 |
↓ Don't trust that face!
What are you using to keep the mold from leaking? I've always wanted to try doing this stuff.
__________________
#7 |
Multimodder
@cheapskate, that was one of my biggest worries. But by far this is the cheapest mold you can make (lol). I though of using clay or latax molds, but that gets costly. It did leak a little out of the almumin and box, The resin gets thick and gels in about 30 minutes. its just very minor. i watch it stop before my very eyes
#8 |
Multimodder
Time to un wrap
I did spray a resin release agent before i poured the mold so it would stick too bad. ![]() ![]() ![]() ![]() ![]() To square it up I did a little cutting with a dremal & hack saw!!! ![]() Ok took a few shots to see how it looks on different surfaces ![]() ![]() ![]() ![]() a little more work on the cover and then i will start on the base |
#9 |
Dremel Blades in ma head!
#10 |
Multimodder
This is going to be interesting.
I can't wait to see the end. |
#11 |
Hate your face
that's an awesome effect right there. Very impressive !
__________________
| i7 950 | 6GB | Sabertooth X58 | 2xGTX 570 | Force GT 120GB | 10.5TB total | X-1250 | Bravura X-Fi | Define R3 XL | H50 | 2233RZ 120Hz | |
#12 |
Avoiding the "I guess.." since 2004
Great idea with the resin/aluminum foil. Now I really want to try casting something
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2 Last edited by Jipa; 16th Jun 2010 at 09:23. |
#13 |
I'm insane, not stupid.
^Careful, you might get chemical burns...
![]() Does look just like a giant chunk of ice, so, perfect so far.
#14 |
Hypermodder
Having spent a lot of time working with polyester casting resin in the past six months, I'd like to tell you to watch out as a safety point. The catalyst itself is not nice, and whilst the clear resin is slightly more benign, it can still cause problems, even when hardened if you're touching it a lot. I'm not trying to make you think it's deadly or whatever, but if you're touching it a lot and have sensitive skin, it can be an irritant.
#15 |
Supermodder
Oooo that looks awesome! Nice job!
#16 |
Mauritius? 2nd speck east of africa
Sweet! very creative casting technique and the result is perfect. I'm watching
__________________
Q9550 | Evga 790i ultra sli | 4gb Ram | 2x Gtx460 (1gb) | 1Tb storage | Icute titanium 750w | Cold lava~MOTM Nominee May 2010. ![]() |
#17 |
I like wood ಠ_ಠ
Looks pretty sweet, I can't wait to see who this turns out
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
#18 |
Supermodder
As everyone I'm impressed. It's look's like a giant ice cube.
#19 |
Minimodder
Wow nice idea, and very creative ! I will follow this for sure.
__________________
Photogallery: http://www.flickr.com/photos/alindquist_/ |
#20 |
Multimodder
ah very interesting - good effect with the resin.
What's the name of the release agent spray?
__________________
Project: Hush! |
| Thread Tools | |
| View Mode | |
