Case Mod - In Progress Acrylian 343B
Discussion in 'Project Logs' started by skullen, 20 Jun 2010.
  1. skullen
    skullen Minimodder
    31 Oct 2007
    Not been on for a while so i think its time for another build,this will take a while :)
    The case is a Lian-Li 343B with a bit of acrylic here and there.
    The Beast
    Bits of acrylic
    Got my trusty old scroll saw out and did a bit of cutting on some peices
    Rad and fans in for a test fit (using a duff board and some spare green fans,these will be changed for some blue fans )
    Rear panel cut out
    Rear panel taped and ready to be cut
    And cut
    Added grills
    Test fit,seems ok
    Fitted
    Also cut the bay bit for the grill
    And some more pics
    Thats where i am at the mo.
    Thanks for looking :thumb:
    Ian.
  2. DeadP1xels
    30 Nov 2009
    *Pulls up a seat*
    I'll be watching :)
  3. Guest-23315
    Guest-23315 Guest
    A Skullen mod? Oooh.
    Sub'd. :thumb:
  4. skullen
    skullen Minimodder
    31 Oct 2007
    Thanks for the replys,much appreciated :thumb:
  5. skullen
    skullen Minimodder
    31 Oct 2007
    A couple of ideas for the front
    With two of these
    And a bit of work to do on the tubing,just an idea at the mo
  6. The boy 4rm oz
    10 Apr 2008
    An excellent start skullen, I really like your internal plexi dividers, they look great. I like the first option for the front panel personally, the all white looks better then white and black. Although with the black fan grills it may look ok. What about everything white with just the grills and the buttons black instead of including the fan controller knobs as black?
  7. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    I prefer the white too. Great start.
    Since everibody is taking a chair I'll take one too ^^.
  8. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    I assume due to the new rear panel lacking any expansion slots for PCI, PCI-E that this machine will be using integrated video, so on that bases we looking at a huge home server?
    Water cooled server, for silence i would imagine.....
  9. skullen
    skullen Minimodder
    31 Oct 2007
    Thanks for the replys,very much appreciated :thumb:
    @ The boy 4rm oz i think im gonna go with the white,black grills and black knobs :thumb:
    @ Fabou white sounds good:thumb:
    @ Burnout21 On board graphics as im not that advanced in attacking a graphics card to add to the w/cooling,CPU and chipset will be w/cooled + 13 fans in total + three to cool the Ram.
  10. skullen
    skullen Minimodder
    31 Oct 2007
    Sorry for the lack of updates not much done to the case.
    Will be ordering a few bits as i am gonna change the res for another idea.
    Had a play on sketchup with what i hope will be the end design.
    Facia with slats and acrylic
    Without slats and acrylic
    Facia will be turned upside down as will the tube,idea is to have two holes at the top one pluged the other for filling,the one,s on the back will have the middle pluged top hole for inlet bottom for outlet.
    I hope it will work as i think it might look ok when finished.
  11. Daydream85
    Daydream85 What's a Dremel?
    14 Feb 2010
    Nice designs there. Going to be quite the case!
  12. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    This looks good man!! I'll be watching!!
  13. skullen
    skullen Minimodder
    31 Oct 2007
  14. Evenge
    Evenge Minimodder
    16 Sep 2006
    Cool, one of these big lian li's. I'm watching :cooldude:
  15. bulldogjeff
    2 Mar 2010
    I like the clean look of the inside, have to keep an eye on this one.
  16. The boy 4rm oz
    10 Apr 2008
    I'm liking the look of the first res fascia.
  17. skullen
    skullen Minimodder
    31 Oct 2007
    Small update,not much im afraid.
    Got some of my parts so i thought i would throw them in for a look before they get painted
    The Aquaybay front will be ghanged for the grilled version,will be ordering it soon.
    Hope to get some more done to the case over the weekend.
  18. LooZypher
    LooZypher Huh!? What!?
    4 Jan 2008
    I'm very fond oversized cases... This I love :D :rock:
  19. Kojak
    Kojak Who loves ya baby
    3 May 2010
    Looks like its gonna be great, dude you've got bags of space, that thing could hold two boards never mind one! Nice work skullen :thumb:
  20. skullen
    skullen Minimodder
    31 Oct 2007
    Sorry for the lack of updates build is going very slow at the mo
    Treated myself to a new desk for when the beast is finished,nothing posh bit of ikea stuff and some stain
    Done a bit more on the case,front panel bolted on these will be changed for black ones
    Still gotta do cutouts for grills
    Top also bolted on bolts will be changed for black ones also
    Side panel on for test dont look to bad,gotta get the window cut out and filled with clear acrylic
    Something like this so the window will be flush with the panel,but without the other bits beside it
