Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 29th Jun 2010, 20:20   #1
prince88
What's a Dremel?
prince88 has yet to learn the way of the Dremel
Fans spin for a second and computer won't turn on
Hey guys I have built my second computer. It was working fine for three months and now I am running into problems. My computer turned off unexpectedly and when I try to turn it on again all the fans spin for like a second and shut off. So what I do then is unplug the power supply and plug it back in. So I press the power button, and again the fans spin for a second and everything shuts off. I have RMA my motherboard twice and ASUS has told me there is nothing wrong with the motherboard.
What can be the problem?? Power supply maybe??
My specs:
Asus P7P55D motherboard
Crosair Power supply 850watts
Intel i7 860
Thank you for your assistance.
prince88 is offline   Reply With Quote
Old 30th Jun 2010, 03:41   #2
prince88
What's a Dremel?
also my cpu has the megahalem cpu cooler and stays around 35-38C. So temps are fine.
Old 30th Jun 2010, 05:41   #3
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Take it out the case and try it on the motherboard box. This will isolate if it's shorting out.
What memory are you using? If you're using G.Skill Ripjaws there's a cold boot issue with Asus motherboards sometimes (Google is your friend here) so you'll need to exchange the memory for something else (there are ways around it but it's more work to explain).
Try just 1 memory stick in all the slots, then try the other one.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 2nd Jul 2010, 01:50   #4
morris8809
Supermodder
morris8809's Avatar
morris8809 has yet to learn the way of the Dremelmorris8809 has yet to learn the way of the Dremel
My first bet would be psu, but like Bindibadgi says id try it out of the case first to make sure its not shorting out.
__________________
|Lian-li A70F|Intel® i7 5820k|ASRock X99 Extreme4/3.1
|Crucial DDR4-2400 16GB|Zotac GTX1070|
|Corsair 650HX ||2x 1TB WD Black, 500GB Samsung 840EVO SSD|
|Minecraft server specs: I5 2400, 16GB DDR3, 840EVO 128GB SSD|ASUS P8Z77V-PRO|
morris8809 is offline   Reply With Quote
Old 2nd Jul 2010, 07:29   #5
prince88
What's a Dremel?
Here is an update. My computer today worked for like 6 hours and had normal post. When you turn on your computer I get the short beep and things worked for like 6 hours and computer unexpectedly shut off. Now it does not turn on. Computer is only 3 months old. Maybe faulty power supply??
I have to unplug powersupply and plug it back in. Then fans only spins for a second and computer does not turn on.
Old 2nd Jul 2010, 07:30   #6
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
I would suggest it's likely, but try it out the case first.
__________________
Old 3rd Jul 2010, 00:52   #7
confusis
Kiwi-modder
confusis's Avatar
confusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysis
That sounds like a PSU thermal overload to me - could be wrong though. Is the PSU fan spinning? No dust/blocked inlet/outlets?
Also try testing as Bindi mentioned - it may be a short somewhere
confusis is offline   Reply With Quote
Old 3rd Jul 2010, 04:04   #8
prince88
What's a Dremel?
The PSU fan spins less than a second and nothing turns on. What can be causing shortening and what do you mean by that?? I have the mobo on the spacers.
No dust or anything. I have moved all my memory sticks around the slots and tried them one by one and still same result. I have RMA my mobo twice and Asus said both time they are fine. When computer was working I could play any game fine and temps are around 35 to 38 since its summer. Sometimes computer turns on for 1 min to 30 min or 1 hour. Also when computer was working I ran 8 hours Memtest 86 on sticks and no errors.
When computer does turn on it is usually when I unplug power supply for 30 minutes and plug it back in and wait like 2 minutes. When I hold power button sometimes computer will turn on. And thats rare. When computer does work it has normal post with a normal beep.
Also I will try Bindi's method once I get my computer back from my cousin.
Old 3rd Jul 2010, 04:37   #9
confusis
Kiwi-modder
confusis's Avatar
Tried a different PSU?
Old 3rd Jul 2010, 06:22   #10
Elton
Officially a Whisky Nerd
Elton's Avatar
Elton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming Saiyan
Could be the PSU.
For some reason have you checked if the cooler is seated properly? After removing it a few times it might not be, but then again the meghalem mounting style is almost indestructible. Try a different PSU like confusis said. Any indicators on the mobo or GPU that are shining?
__________________
Gotta keep it 100 we got fundamentals.
Elton is offline   Reply With Quote
Old 3rd Jul 2010, 06:39   #11
prince88
What's a Dremel?
For the motherboard I have had it RMA by Asus and they told me nothing is wrong with my motherboard. For the GPU that I am pretty sure is fine because when computer was working the games ran wonderfully with no error or BSOD.
The unexpected shut down happened after I restated my computer and it just shut off .
My Megahalem cpu cooler I know for sure are seated properly.... I have reseated them but with the same problem. With those coolers there is no way I think someone can not seat them properly because you have to screw them down.
I will try out a new PSU once I get my computer back.
Old 7th Jul 2010, 00:52   #12
prince88
What's a Dremel?
So here is an update. I just talked to the computer repair guy and he said all my part are working fine......outside the case.......wtf??? Is something causing a short?? I have the motherboard on the jumpers.
Can the shape of a case cause problems??
Old 9th Jul 2010, 19:11   #13
prince88
What's a Dremel?
I have solved my problem. My motherboard was bent in the middle and so was the riser which caused a short. I have replaced the riser and everything is working great.
Old 9th Jul 2010, 23:00   #14
Delta Nine IT
New to this but not to Modding!
Delta Nine IT has yet to learn the way of the Dremel
how was it bent, did you have a mounting wrong?
Delta Nine IT is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
