Reply
Thread Tools View Mode
Old 19th Mar 2011, 07:38   #661
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Thanks.
If you minimize your shutter time (try with 1/1000s), we will be able to see the LED itself. Have a go at it.
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 19th Mar 2011, 10:04   #662
Dragonite
Multimodder
Dragonite's Avatar
Dragonite has yet to learn the way of the DremelDragonite has yet to learn the way of the DremelDragonite has yet to learn the way of the Dremel
Maybe a little late now though but these could have worked
http://www.phenoptix.com/shop/blue-f...rip-p-129.html
Dragonite is offline   Reply With Quote
Old 19th Mar 2011, 10:36   #663
riekmaharg2
has finished Blue Horizon
riekmaharg2's Avatar
riekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremel
Originally Posted by Nutman View Post
Thanks.
Are these what your looking for:
The space I had to put the LED's in was only 2mm deep, so those would also be too big, however they are perfect for some other work I'm doing, Thanks Dragonite
__________________
Scratch Builds
Silent Fiberglass PC
Completed * Blue Horizon * - 2012
riekmaharg2 is offline   Reply With Quote
Old 19th Mar 2011, 22:01   #664
Nutman
Nutman's Avatar
Yeah, much better pics. Nice spreading of the light. Thanks!
__________________
Old 20th Mar 2011, 13:41   #665
error404
Minimodder
error404 has yet to learn the way of the Dremel
Originally Posted by riekmaharg2 View Post
Thanks everyone , you guessed right RonanH there will be a metal panel on top of the acrylic which the screws go through before going through the heatsink.
The O ring seal arrived today heres a pic of the acrylic temporarily screwed on:
Sorry, but where / how do you get custom size o ring seals?
Awesome project!!
error404 is offline   Reply With Quote
Old 20th Mar 2011, 16:09   #666
Javerh
Topiary Golem
Javerh's Avatar
Javerh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the Dremel
Awesome project!!
You can make them yourself. Just buy o-ring splicing kit or a spool of o-ring cord stock and glue proper sizes with cyanoacrylate.
__________________
Project: Seawolf
Project: 1
Project: Flux (est 2012)
Modders make project logs. Project logs make mods. Mods make modders.
Javerh is offline   Reply With Quote
Old 20th Mar 2011, 20:50   #667
ringo
Supermodder
ringo has yet to learn the way of the Dremel
The water cooler looks different to the most one, I really like it. I also like it how you made it.
ringo is offline   Reply With Quote
Old 20th Mar 2011, 23:16   #668
riekmaharg2
Glad to be of assistance
Awesome project!!
Thanks Error404, its just a continuous piece of round rubber with the ends glued together. Heres the link for the rubber:
http://cgi.ebay.co.uk/Quality-O-Ring...#ht_2586wt_905
And heres the glue that bonds the ends together:
You need the actual glue:
http://www.sureloc-direct.com/producttypes.php?pid=52
And the activator:
http://www.sureloc-direct.com/producttypes.php?pid=35
It sets instantly as soon as the spray the activator on it or squash it between two surfaces however I always use the activator as it sets better, and can also be used to glue pretty much everything except it doesn't work very well on metals.
Yep , links are above.
Thanks Ringo
In order to fit LED's into the heatsink acrylic, I first milled out a square channel:
I then superglued and soldered the LED's
Once the heatsink is finished only the edge of the acrylic will be visible.
__________________
Scratch Builds
Old 21st Mar 2011, 01:01   #669
error404
Minimodder
And the activator:
Thanks!
I guess I was right on target....
I was planning to use
.070" Diam. Buna-N 70 O-Ring Cord Stock
http://www.fastenal.com/web/search/products/_/N-gj4zvx&
& and this
https://www.neverseezproductscart.co...152#googlebase
Old 21st Mar 2011, 01:13   #670
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Its so PWEEEEEEETY
Mankz is offline   Reply With Quote
Old 21st Mar 2011, 02:15   #671
D-Mon Taurus
Multimodder
D-Mon Taurus's Avatar
D-Mon Taurus has yet to learn the way of the Dremel
Only just started to plan a mod as i am newbie. I am in awe... seeing builds like this.
Simply amazing.. the lights so perrrrty
D-Mon Taurus is offline   Reply With Quote
Old 21st Mar 2011, 09:40   #672
riekmaharg2
Thanks!
& and this
Yep those are right , you shouldn't need the activator if your only gonna use it to splice the o ring.
Originally Posted by Mankz View Post
Its so PWEEEEEEETY
Thanks D-Mon Tauru & Mankz
__________________
Scratch Builds
Old 21st Mar 2011, 10:56   #673
sixfootsideburns
modeteer
sixfootsideburns has yet to learn the way of the Dremelsixfootsideburns has yet to learn the way of the Dremel
Definitely be careful not to tighten down your fasteners to hard on that acrylic. Especially with a square channel machined out (that being one with sharp corners and not fillets) your bound to have higher stress levels. I don't think you would have trouble but it would be a shame to crack the panel at this stage. Lights look really sweet man! I tend to like it more when lighting is very evenly distributed without any bright spots (which is hard ) but in your case I think I like it more with the brighter areas.
Slick as hell man, I can't wait to see this assembled and running!
sixfootsideburns is offline   Reply With Quote
Old 23rd Mar 2011, 17:46   #674
riekmaharg2
Thanks sixfootsideburns , yeah I'll be very gentle with and I'll work my way around tightening each screw a bit a time.
I have poured some clear resin into the channel to make it a bit stronger:
I have now finished with the heatsink until I get it anodized.
Next up is attaching the coolant angle barb block. To start off I milled out a peice of aluminium using a small milling bit:
I then chopped it down to the sizes I needed using a Junior hacksaw:
I then drilled holes into each of the little tabs:
And here's the result after a little sanding:
I didn't spend too much time on making them look nice as they're not going to be visible.
I then drilled holes into the appropriate places on the angle barb block:
And then tapped them:
Here's the tabs now screwed onto the block:
It just needs a final polish and then I'll screw it to the case, which is the last step before I start to attach the top panels.
__________________
Scratch Builds
Old 24th Mar 2011, 10:12   #675
phenoptix
Multimodder
phenoptix's Avatar
phenoptix has yet to learn the way of the Dremelphenoptix has yet to learn the way of the Dremel
This is an amazing piece of workmanship. I love scratch builds.
phenoptix is offline   Reply With Quote
Old 24th Mar 2011, 10:44   #676
Waynio
Tetrep
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Awesome progress Graham, the acrylic piece looks great lit up & how you mention it'll only show light around the edge later on sounds even better .
That last piece, is that for attaching to the rad? if so flipping amazing work mate loving this build.
Waynio is offline   Reply With Quote
Old 24th Mar 2011, 13:55   #677
riekmaharg2
Thanks phenoptix
Thanks Waynio , the last two pics are of the block which trasfers the coolant from the tubes inside the case to the tubes behind the back panel which are then connected to the heatsink. I made it ages ago, but never got round to attaching it to the case.
__________________
Scratch Builds
Old 28th Mar 2011, 19:13   #678
riekmaharg2
Heres the next update:
To finish the top panels I first cut out some acrylic pieces to fit onto the side of the aluminium:
I then attached the acrylic to the aluminium with some JB weld:
I then used an Orbital sander to smooth down the acrylic:
Its not quite a perfect spread of light but it will have to do unless I think of something to spread the light out better.
I then screwed the water angle barb block onto the case:
Its not the prettiest view from the back but it wont bee seen:
I then used a bandsaw to cut out a block of aluminium:
I then used a facemill to trim down the edges:
I then drilled a pilot hole:
I then drilled all the way through with a 3mm bit, then half way through with a 7mm bit:
Then after a bit of sanding:
I then milled a slot across to all the top panel to sit on top of it:
I then drilled a hole through the back of the case:
I then drilled a hole into another block I made earlier:
I then tapped the hole:
Both the above blocks will be screwed together on either side of the back of the case.
I then drilled another hole through the back panel:
And then screwed on the next block which I made earlier:
__________________
Scratch Builds
Old 28th Mar 2011, 19:35   #679
Waynio
Tetrep
Waynio's Avatar
OMG this is looking amazing mate, beautiful work .
Old 28th Mar 2011, 19:38   #680
riekmaharg2
Thanks Waynio
__________________
Scratch Builds
Reply
Tags
blue, custom res, scratch build riekmaharg2
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
