#1 |
I Mod, Therefore I Own
Mass Effect Crash
Hello Everybody
Im having a problem in Mass Effect. When i hack thing in Mass Effect the pc Blue screens. This doesnt happen for any other game i have,Also it only after starting to happen recently E6750 @3.4 Ghz Asus P5K 2BG 1066 Ram ATI 4850 Samsung F1 X-Fi Titanium Pro Windows 7 64Bit Unlimited All my drivers are up to date Thanks |
#2 |
The upgrade bug biteth...
Probably a crap guess but how defragmented is your hard drive?
__________________
Lian Li PC-P80B / EVGA Classified 3 / i7 920 D0 @ 4043GHz (no HT) / NH-U12P / 3x4GB Corsair Vengeance @ 1544MHz 8-8-8-24-1T / 3x EVGA 3GB GTX 660 Ti SC+ @ 1150MHz core boost 7400MHz memory / X-Fi Titanium Professional / 2 x 250GB Samsung 840 / 120GB Vertex 2 / 2x1TB RAID0 Spinpoint F1 / 2TB WD Caviar Green / Silverstone 1500W / 3007WFP-HC / 2407WFP / Beyerdynamic MMX300 / Logitech K350 Wireless Curve / Razer Mamba (2012) / Sidewinder Force Feedback 2 / Datacolor Spyder3 / Windows 7 Ultimate x64
#3 |
4 Percent it defrags them every wed i think
#4 |
[Insert witty comment here]
You're playing it on a Wii.
That's your problem. Could it be an unstable overclock maybe? I know some game can be quite sensitive to overclocking (Crysis) Try lowering down to stock settings. Other then that, I have no idea.
__________________
Deathmatch Classic: Source |
#5 |
Multimodder
Interesting that it should crash only when you try to hack; the minigame isn't exactly demanding on hardware. If I had to guess I'd say driver issue--some graphical effect that's crashing.
Need more info to be sure: is there a stop message displayed when it bluescreens? Have you checked error logs? You could also try simply updating/reinstalling video drivers.
__________________
Rig:C2Q Q9550 OC'd to 3.5GHz - Asus Maximus II Formula - 8GB Patriot RAM - OCZ Vertex 120x2 (RAID 0) - WD Caviar Black 1TB + 2x500GB - Samsung Spinpoint F3EG 2TB x2 - Sapphire 5870 Vapor-X - Samsung 245T (24", 1920x1200) x 3. Blag: www.lucidpixels.net |
#6 |
Ultramodder
Have you patched the game or are you running it as per loaded from the disk?
First time I played it crashed on me as soon as I tried to run it and the patch fixed it and it works brilliantly. I'm playing it again as a female Shepard and I think its actually better. |
#7 |
I have put everything back to stock and my drivers have been updated.Its running through steam so it should be up to date
#8 |
Ultramodder
Does Steam update non Steam games in the same way it updates games like Half Life, Portal, L4D, TF2, etc, etc?
#9 |
Veni Vidi Vado
Usually: Yes.
If it's a non-Valve game you're free to patch it yourself anyway, just turn off the auto update function via the 'Properties' tab so Steam won't verify the integrity of the game cache. Then you can do whatever you want to the files, Steam won't interfere. I've modded Titan Quest I got via Steam to hell, a thing Steam didn't like that much until I turned off the auto updater. Also try to run Mass Effect as Administrator. Can't confirm this myself, but for a friend who had problems running the game via Steam it did wonders. Last edited by Aterius Gmork; 11th Jul 2010 at 16:44. |
| Tags |
| mass effect |
| Thread Tools | |
