#1 |
Multimodder
ATi Theater Mode in Windows 7
Hey, can anyone get ATi Theater Mode to work in Windows 7? This has always worked for me in XP. I am in Extended Desktop Mode and Theater Mode is set to full screen, but when I open a video it will just display the video on the Primary Display and it won't show the same video in the Secondary Display, it just shows the Extended Desktop. I have tried several media players but I have had no luck. This has always worked in Windows XP.
I have been following every driver update since 9.12, and now I have the 10.7 drivers installed. Thanks for anyones help.
__________________
Gigabyte EP45T-UD3LR - Intel Core 2 Duo CPU E7400 @ 2.80GHz - OCZ 700W StealthXStream 2 Power Supply - 2x 1gig DDR3 (PC8500) 2x 2gig DDR3 (PC12800) - Gigabyte ATi Radeon HD 5770 - Western Digital WD1500HLFS (Win7 x64) - Western Digital WD5000AADS (WinXP x86) - Sound Blaster X-Fi Xtreme Audio - LG HL-DT-ST DVD-RAM GH22NP20 |
#2 |
has finished Blue Horizon
This is ment for vista but it will probably work just the same: http://forums.techpowerup.com/showthread.php?t=30831
#3 |
Multimodder
Thanks for the help riekmaharg2, I had a look at that guide and there was alot of steps involved, so instead I just tried setting VLC player to Windows XP SP3 compatibility mode and now Theater Mode works. I should have tried that to begin with lol.
__________________
#4 | |
Lol, yeah its annoying when you spend ages trying to solve a problem, and the solution was in fact incredibley simple. |
| Tags |
| ati, theater mode |
| Thread Tools | |
