Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 11th Aug 2010, 22:19   #61
Yslen
Lord of the Twenty-Seventh Circle
Yslen's Avatar
Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.
Okay so with everything on high, including physX, I get a pretty dreadful 12.2fps average. What's interesting though is that throughout the benchmark my GPU never went over 40% and my CPU never went over 50%, except on one core which occasionally reached 70% but mostly sat around the 60-65% mark.
With physX on low it's much the same story, except with slightly lower CPU usage and a much more playable (though still not really that great) average of 18.8fps.
With physX off completely I get an average of around 45fps, with the CPU doing very little (as with most games I play) and my GPU going full pelt, never dipping below 98%, as you'd expect.
I'd be prepared to accept a situation where my CPU was maxed out trying to do physics simulations, but still caused a bottleneck and struggled to maintain a decent framerate, but this is just rubbish. I have hardware headroom to spare and yet my framerates suck. Oh, and I had 2GB+ free RAM throughout the benchmark too. Thought I should check that after the "Borderlands incident" of last week (latest ATI drivers = memory leak).
I'd be interested to know if any i7 owners see a similar thing in the benchmark? It makes very little sense to me. Either your GPU is maxed or your CPU is. On rare occasions both are maxed but it requires a perfect balance of hardware (usually with GPU far in excess of CPU). I've never seen a game fail to max either of the two before and STILL run badly. It happens when I have Vsync on in some games, but that only kicks in a 60fps obviously...
So, is it just me?
__________________
Asrock Z77e-ITX - Intel i5 3570k - Corsair H50-1 - G.Skill Ripjaws X 2133MHz - Gigabyte HD6870 - Crucial M4 - Samsung HDD - 530W ThermalTake SS PSU - Bitfenix Prodigy - LG IPS231P - R.A.T. 5 - Cherry G80-3494 (MX Red) - Ducky YotD (MX Brown)
Take a look at my Photography portfolio, here.
Yslen is online now   Reply With Quote
Old 11th Aug 2010, 22:27   #62
Yslen
Yslen's Avatar
Originally Posted by Showerhead View Post
That's odd you get as big a drop as me yet you're using Nvidia.
Noticed that when i use Physx the CPU use never goes above 75% which is odd it runs at 60% normally would have expected it to use the rmaining 25% of my cpu to try to boost frames though i heard Physx isn't to well optimised for cpu use. (obviously)
Oh okay, if I'd read this it would have saved me making a massive post asking if anyone else had seen this exact thing.
__________________
Old 11th Aug 2010, 23:17   #63
Shaftydude
Multimodder
Shaftydude can run CrysisShaftydude can run CrysisShaftydude can run CrysisShaftydude can run CrysisShaftydude can run CrysisShaftydude can run CrysisShaftydude can run CrysisShaftydude can run Crysis
This game runs like dog **** on a GTX 260 216 core.
Shaftydude is offline   Reply With Quote
Old 11th Aug 2010, 23:43   #64
erratum1
Thread killer
erratum1's Avatar
erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.erratum1 is the Cheesecake. Relix smiles down upon them.
Nvidia has to give you a reason to buy a gtx 480, otherwise why would you bother.
erratum1 is offline   Reply With Quote
Old 11th Aug 2010, 23:55   #65
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Why does everyone criticise a game because it needs you not to have maxxed the settings on a 2 year old graphics card? It's called progress.
Runs fine on my 8800GT, as lowly as it is, because I don't expect it to run with max AA and max effects at 2048*1152.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is online now   Reply With Quote
Old 12th Aug 2010, 00:10   #66
Pieface
Mod Master
Pieface's Avatar
Pieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpitPieface is almost as Godly as yodasarmpit
Runs fine for me.
__________________
"I've never played the original Starcraft" - Bindi thought this was so shocking it needed going in Pie's sig.
@dominicpybus My Flickr
PC: CPU: i7 3770//GPU: EVGA GTX660ti//Memory: 16GB Corsair Vengeance//1st Drive: 120GB SSD//2nd Drive: 1TB Samsung F2//CPU Cooler: Corsair H70 Hydro Cooler
Pieface is online now   Reply With Quote
Old 12th Aug 2010, 02:23   #67
Er-El
Supermodder
Er-El's Avatar
Er-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the Dremel
-1 to 2K Games/2K Czech studio for using Physx, thus alienating almost half their audience who don't own an Nvidia card, when I'm willing to bet they could have done the same effects using a more open physics middleware such as Havok.
Er-El is offline   Reply With Quote
Old 12th Aug 2010, 03:11   #68
Slizza
beautiful to demons
Slizza's Avatar
Slizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run Crysis
Nvidia do this for the devs in there TWIMTBP program and the devs don't need to fork out like they would for havok.
It's a extra nvidia offer them for free.
They even send over nvidia people to implement it for them.
__________________
Case: HAF932 :PSU: 850W Corsair :Mobo: Asus Sabertooth Z77 CPU:I5 3570k @4.4Ghz
Memory: 8Gb Corsair 1866Mhz :64gb Crucial M4: 2x1Tb F3's :GPU: Nvidia GTX 570
Slizza is offline   Reply With Quote
Old 12th Aug 2010, 04:56   #69
Grape Flavor
Multimodder
Grape Flavor's Avatar
Grape Flavor has yet to learn the way of the Dremel
Originally Posted by tripwired View Post
Anyone else found the driving mechanics to be a bit.. well.. weird? Far too arcade-like.
Cars don't really behave as I would expect them to, especially while cornering. They all seem to slide far too easily, which ruins the sense of authenticity for me. I'll still end up buying it I'm sure, if only because I loved the original so much and crave more.
You realize, of course, they are aiming to simulate 40's-50's cars and not, say, cars like in GTA IV?
The cars are going to have a different feel than contemporary vehicles.
Grape Flavor is offline   Reply With Quote
Old 12th Aug 2010, 06:43   #70
DragunovHUN
Go ahead, spell my name wrong.
DragunovHUN's Avatar
DragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run CrysisDragunovHUN can run Crysis
So the correct way to look at it is not that half the users (red) get cheated out of shiny, but that half the users (green) get extra shiny as opposed to no shiny.
__________________
Gigabyte EX58-UD5 | Intel i7 920 @stock | 6x2gb 1600Mhz Corsair Dominator | 560Ti Hawk | Tagan 480W EasyCon | Lian Li PC-A77FB | Samsung Syncmaster 2443 | Logitech Illuminated | Logitech G500
gog.com - Classic videogames, Windows 7 compatible, no DRM, bundled extras, outstanding service. Check it out, get hooked, spread the word!
DragunovHUN is offline   Reply With Quote
Old 12th Aug 2010, 07:47   #71
Da_Rude_Baboon
What the?
Da_Rude_Baboon's Avatar
Da_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpit
Follow the link in Slizza's post and it tells you how to optimise the physics so it can run on the CPU.
The deal with the physx.
It's bugged and doesn't install the physx with the demo.
It will run better if you uninstall physx then manually install the physx from the game mafia ii directory.
If you still need more frames then the biggest frame rate killer is the dynamic cloth on npc.
You can disable dynamic cloth on the npc though and just have it on Vito.
guide here.
http://physxinfo.com/news/3628/mafia...x-performance/
The quote below is from the link.
Originally Posted by Physxinfo
And finally. With our tweaks it is possible to play Mafia II with APEX PhysX enabled – purely on CPU.
All fancy particles and impact debris (our CPU was enough for APEX Medium settings, GPU PhysX disabled in drivers), some clothing simulation – running around 30+ fps.
Looks like a nice deal for non-hybrid ATI users.
Da_Rude_Baboon is offline   Reply With Quote
Old 12th Aug 2010, 08:19   #72
knuck
Hate your face
knuck's Avatar
knuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpitknuck is almost as Godly as yodasarmpit
I just watched a trailer and it made me wonder; why do cars in third person game suffer from that much body roll ? It's ridiculous. You barely touch the steering wheel and the car looks like it wants to do a barrel roll
__________________
| i7 950 | 6GB | Sabertooth X58 | 2xGTX 570 | Force GT 120GB | 10.5TB total | X-1250 | Bravura X-Fi | Define R3 XL | H50 | 2233RZ 120Hz |
knuck is offline   Reply With Quote
Old 12th Aug 2010, 14:24   #73
Yslen
Yslen's Avatar
The graphics still look very DX9 to me, and run fine on my old 4850. It's the physics that I'm annoyed about, because they don't run very well on a CPU at all. It's not even using 100% of the CPU! It all looks like an attempt to shift Nvidia GPUs to me.
__________________
Old 12th Aug 2010, 14:54   #74
erratum1
Thread killer
erratum1's Avatar
They are 'old' cars and your probably taking a corner at suicide speeds, I think they look quite good in game.
Old 12th Aug 2010, 15:49   #75
[PUNK] crompers
Dremedial
[PUNK] crompers's Avatar
[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.
played the demo too many times now, cant wait for this to come out! if the story is good and the voice acting is as nice thoughout could be a real stunner.
__________________
| Main Rig | TJ07B-W | 2600k @ 4.7Ghz | Sabertooth Z77 | 8GB Corsair Vengance | EVGA FTW 670 @ 1305Mhz | Samsung 830 128GB |1TB Samsung F3 | EK Supremacy CSQ | EK FC680 CSQ | Corsair HX650W | U2711 | Filco Majestouch 2 Tenkeyless | Xonar Essence STX | Beyerdynamic DT990 Pro 250ohm |
| HTPC | Lian Li Q11-B | AMD A10 5800k | ASRock FM2A75M-ITX | 8GB XMS3 2000 | 1TB Seagate | SFX 350W |
[PUNK] crompers is online now   Reply With Quote
Old 12th Aug 2010, 17:45   #76
knuck
Hate your face
knuck's Avatar
4:00 exactly
__________________
Old 12th Aug 2010, 17:56   #77
WildThing
Hypermodder
WildThing's Avatar
WildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the Dremel
Originally Posted by LeMaltor View Post
Anyone tried the file that stops the timer? My anti virus went crazy so I hex edited it instead and it works
Just found THIS. Works for me, it's really simple to do in case anyone is not familiar with Hex editors, like me .
__________________
Asus P8P67 PRO ¦ Intel i5 2500K @ 4.4GHz ¦ Titan Fenrir ¦ XFX 6950 @ 6970 ¦ 2x4GB Corsair DDR3 1600MHz ¦ 2x Crucial C300 128GB (OS + Games) ¦ Samsung Spinpoint F3 1TB ¦ Auzentech XFI-Prelude + Creative T7700 7.1¦ Enermax Liberty 500W ¦ Corsair 650D case ¦ HP 24" LP2475W ¦ Win7 x64
WildThing is offline   Reply With Quote
Old 12th Aug 2010, 19:50   #78
LeMaltor
>^_^<
LeMaltor's Avatar
LeMaltor has yet to learn the way of the DremelLeMaltor has yet to learn the way of the DremelLeMaltor has yet to learn the way of the DremelLeMaltor has yet to learn the way of the DremelLeMaltor has yet to learn the way of the DremelLeMaltor has yet to learn the way of the Dremel
Yeah that's the way I did it too
__________________
Welcoming the riff-raff since February 2009.
LeMaltor is offline   Reply With Quote
Old 12th Aug 2010, 21:42   #79
pimonserry
sounds like a party.
pimonserry's Avatar
pimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremel
My 4870 got a C grade
Bear in mind, I didn't even look at the settings - just installed, started, hit benchmark.
Edit: default settings are 16xAF, 0xAA, No PhysX, VSync on, other settings on High.
Double edit: anyone else's screen incredibly dark once they've exited the game?!?!
Triple edit:
strange problems with monitor brightness on ATI cards ... hit Ctrl + Alt + Del, then Esc
MASSIVE THANK YOU!
Quadruple edit: Actually playing the game, in indoors areas (the distillery) it seems to my untrained eye to get an average of ~20 fps.. but I did put PhysX up to Medium
It's quite fun though, not sure I'll buy it as moving to Uni in the coming months and not taking the desktop with me...
__________________
I'm a student, any money I might possibly have is not mine.
+REP ME FOR BEING WONDERFUL
pimonserry is offline   Reply With Quote
Old 12th Aug 2010, 21:44   #80
Pieface
Mod Master
Pieface's Avatar
I got a D grade of 2GB of Ram
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
