Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Aug 2010, 09:55   #1
julieb
Minimodder
julieb has yet to learn the way of the Dremel
Intel-Micron gives NAND some TLC
http://www.bit-tech.net/news/hardwar...and-some-tlc/1
julieb is offline   Reply With Quote
Old 18th Aug 2010, 11:33   #2
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
Sounds like MLC should be called BLC now.
Or DLC. OH WAIT.
rickysio is offline   Reply With Quote
Old 18th Aug 2010, 11:49   #3
shanky887614
Multimodder
shanky887614 has yet to learn the way of the Dremel
i htink this is good becasue memory is still too expensive
shanky887614 is offline   Reply With Quote
Old 18th Aug 2010, 13:09   #4
Burdman27911
Modder
Burdman27911 has yet to learn the way of the Dremel
I wonder what the performance hit will be. SLC NAND is quite a bit faster than MLC... so I assume there will be some sort of penalty to increasing the layers again. Certainly interesting though, and I look forward to higher capacities at the same price points for less-performance driven parts.
Burdman27911 is offline   Reply With Quote
Old 18th Aug 2010, 13:25   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Could explain why they're going for cheap SD cards and other non-performance-critical applications, rather than SSDs.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 18th Aug 2010, 20:21   #6
bobwya
Custom PC Migrant
bobwya has yet to learn the way of the Dremel
You can't use TLC or triple-bit flash cells in an SSD - the lifespan and write performance will be atrocious.
Looking forward to some 25nm MLC goodness though :-)
bobwya is offline   Reply With Quote
Old 19th Aug 2010, 08:49   #7
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Hmmm, has Mirrorbit* ever caught on?
*AMD/Fujitsu** dual bit cell.
**formerly FASL, then Spansion
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
