Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Aug 2010, 10:59   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
Adobe to release emergency patch today
Adobe's Reader has suffered another set of vulnerabilities - but an emergency patch is due.
http://www.bit-tech.net/news/bits/20...-patch-today/1
Claave is offline   Reply With Quote
Old 19th Aug 2010, 11:26   #2
Ross1
Multimodder
Ross1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run Crysis
I just use sumatra PDF. I generally have a dislike of PDFs as well.
Ross1 is offline   Reply With Quote
Old 19th Aug 2010, 12:38   #3
Cleggmeister
Of reasonable knowledge...
Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.
Just checked for updates, none available as yet...
__________________
Pooting: Antec 300, P6T SE, i7 920 (3.20), Corsair F120SSD, 3x1TB HDD, 9Gb (1600XMP), GTX560Ti 2Gb (880/1760/2100), Win7 x64. Raspberry Pi B with OpenElec.
Grooving: Linn LP12, Klimax DS, Klimax Kontrol, Aktiv Akubariks. Linn Sekrit DSI +104's + Velodyne sub
Watching: Raspberry Pi running OpenELEC to 50" Panasonic.
Serving: HP Proliant Microserver N40L running Openmediavault.
Cleggmeister is offline   Reply With Quote
Old 19th Aug 2010, 12:59   #4
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run Crysis
No software is perfect, generally the more popular it is the more errors will be found. I've no doubt Adobe's suits are any worse than any other mainstream software package.
__________________
Intel Core i5-2500K | 8Gb Corsair Vengeance DDR3 1,600 Mhz
Gigabyte Geforce 460 GTX OC 1Gb | 1Tb + 1.5Tb Samsung Spinpoint F3 | Asrock Z68 Extreme4
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 19th Aug 2010, 13:07   #5
tad2008
Supermodder
tad2008 has yet to learn the way of the Dremel
I have been using Foxit PDF Reader since it first became available and find it much more responsive than the bloated Adobe version.
tad2008 is offline   Reply With Quote
Old 19th Aug 2010, 15:49   #6
Slavedriver
Minimodder
Slavedriver has yet to learn the way of the Dremel
You are so very wrong. If you have ever tried to work with Adobe's output PostScript that they shove to the poor print drivers you would be amazed how the company which invented the language can completely ignore every good coding practice they themselves have outlined.
That apart form Reader being a bloated bug-ridden rootkit of course.
Slavedriver is offline   Reply With Quote
Old 19th Aug 2010, 15:50   #7
crazyceo
Banned
crazyceo has yet to learn the way of the Dremel
Security due to online involvement is hot topic news today what with Intel buying McAfee for £5billion. They all need to keep on their toes to be sure their clients stay with them.
crazyceo is offline   Reply With Quote
Old 19th Aug 2010, 17:45   #8
Faulk_Wulf
Internet Addict
Faulk_Wulf's Avatar
Faulk_Wulf has yet to learn the way of the Dremel
No offense, but if a simple patch is enough to break your security / admin software, maybe... just maybe, you should be running a better security / admin software package? This isn't like trying to make a Mac play nice on an otherwise all Windows network or something. I mean it's not like you don't know that things will update, and not all software developers release patches in cycles, some just release as needed.
I mean I've obviously never been an admin but it just seems silly to me.
__________________
-- Faulken S. Wulf
"Under the Willow, he sleeps and dreams, of Heaven."
Looking over my threads, I've come to realize that I have a ridiculous amount of bad luck with my electronics.
Faulk_Wulf is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
