Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Aug 2010, 10:54   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
Lian Li V1020, V2120 preview
We get hands-on with Lian Li's SR-2-compatible PC-V2120 and Mac Pro-a-like V1020 cases.
http://www.bit-tech.net/hardware/cas...2120-preview/1
Claave is offline   Reply With Quote
Old 25th Aug 2010, 11:05   #2
SouperAndy
To Bumble or not to Bumble?
SouperAndy's Avatar
SouperAndy has yet to learn the way of the DremelSouperAndy has yet to learn the way of the Dremel
In the immortal words of Al Murray:
"Filfy" (drool)
SouperAndy
__________________
Main: Antec 1200, HX850, P45-UD3P, Q9450, 8GB DDR2, HD4890, Torqx 128GB + P64 64GB SSD, 2x320GB 2.5" HDD, LG Blu-Ray / HD-DVD ODD.
Server: Lancool K60, Scythe 450W, DFI S939, AMD X2 4600, 2GB DDR, HD4550, 2x500GB + 2x1TB HDD, E700 TV Tuner.
HTPC: Lian-Li PC-V350, Zalman 500W, P45 T2RS-Jr, E7200, 4GB DDR2, HD4870, 2x500GB HDD, Pioneer Blu-Ray ODD, E650 TV Tuner.
Mini: Silverstone SG-05, Zotac 9300 Wifi, E7400, 4GB DDR2, HD4770, 320GB 2.5" HDD, Sony Slimline DVD-RW ODD.
SouperAndy is offline   Reply With Quote
Old 25th Aug 2010, 11:19   #3
[PUNK] crompers
Dremedial
[PUNK] crompers's Avatar
[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.
is that pink? sure looks pink.
both gorgeous cases though, the V1 looks amazing, if a little large.
__________________
| Main Rig | FT02 BW | 2600k @ 4.3Ghz | Sabertooth Z77 | 16GB Corsair Vengance | GTX 1070 @ 2020Mhz | OCZ ARC100 480GB |1TB Samsung F3 | Corsair HX650W | U2711 | Filco Majestouch 2 Tenkeyless | Xonar Essence STX | ProSonus Eris 4.5 monitors |
| HTPC | Lian Li Q11-B | AMD A10 5800k | ASRock FM2A75M-ITX | 8GB XMS3 2000 | 1TB Seagate | SFX 350W |
[PUNK] crompers is offline   Reply With Quote
Old 25th Aug 2010, 11:21   #4
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
Err, wheels...?
rickysio is offline   Reply With Quote
Old 25th Aug 2010, 11:34   #5
KayDat
Multimodder
KayDat's Avatar
KayDat has yet to learn the way of the Dremel
Gorgeous aluminium cases...but so expensive. I'll just have to be content with my Antec steel cases... =/
KayDat is offline   Reply With Quote
Old 25th Aug 2010, 11:36   #6
coolmiester
Coolermaster Legend
coolmiester's Avatar
coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!
BT: Why don't Lian Li cases support more standard water-cooling mounts for dual-120mm and triple-120mm radiators with 15mm spacing?
LiLi: Lian Li already has three models that support internal watercooling mounts which are the A70F, A71F (dual) and new V2120 (triple) and we will continue to design new models with support in future.
Good to know, looking forward to seeing what they come up with.
coolmiester is offline   Reply With Quote
Old 25th Aug 2010, 11:36   #7
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
Wohoo for the perforated comeback! And thanks for throwing my question at them as well
About the PC-V1020 looks great, but having a single huge HDD-rack instead of being able to split it half-way is a huge minus. It's hard to tell from the pictures how well graphic cards will fit, but with under 7 hard drives I'd much rather throw half of the cage out in order to have better airflow from the fan.. Like so:
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 25th Aug 2010, 11:38   #8
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
Hurrah! Finally, a cheesegrater that doesn't turn my motherboard upside down and defeat the point of heatpipe cooling systems. The question now is only can I justify selling my current case to buy one that looks almost identical...
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 25th Aug 2010, 11:44   #9
DragunovHUN
Go ahead, spell my name wrong.
DragunovHUN's Avatar
DragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming SaiyanDragunovHUN is a Super Spamming Saiyan
LiLi: We do have an online store, however it is only for the Taiwanese market. We did consider a world-wide online store, however the cost of shipping individual parts would be too great and usually costs more than the part itself to ship it safely without damage.
WAAAAAAGH
__________________
Gigabyte H97N-WIFI | Intel i7 4790k | Thermalright True 120 | 2x8gb 1600Mhz CL9 Crucial DDR3 | GTX 760 | Corsair RM750 | Fractal Nano S | 2x BenQ GL2460 | Pok3r (blues) | Logitech G500s
DragunovHUN is offline   Reply With Quote
Old 25th Aug 2010, 11:44   #10
DBA
I do my modding with a spoon
DBA's Avatar
DBA has yet to learn the way of the Dremel
It's quite funny how you can consider yourself a fan of something you have never even seen in real life.
It's really good to see a return of the removable motherboard tray and, depending on the price, the V1 in red could very well be my next case (otherwise it will be either the A05 or B25)
DBA is offline   Reply With Quote
Old 25th Aug 2010, 11:47   #11
StoneyMahoney
Supermodder
StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!StoneyMahoney - it's over 9000!!!!!!!!1!1!1!!!
Mac Pro-a-like my arse. No-one who ever used on gave a damn about the outside, it was the internals that made it fantastic. Never poked around inside a more friendly system in my life.
StoneyMahoney is offline   Reply With Quote
Old 25th Aug 2010, 12:00   #12
rehk
Minimodder
rehk has yet to learn the way of the Dremel
Good to hear that Lancool are doing good. I'd love to see more Lian Li cases but made of steel for cheapness, like how the K62 was essentially a PCP50 but with some minor changes such as a dedicated 3.5inch drive rack instead of 5.25>3.5 inch adapters.
Also the red outside black inside color scheme looks brilliant.
rehk is offline   Reply With Quote
Old 25th Aug 2010, 12:10   #13
SNIPERMikeUK
Multimodder
SNIPERMikeUK has yet to learn the way of the Dremel
Lian-Li should make an arcade fight stick case for sanwa parts....Imagine the craftsmanship....
__________________
SNIPERMikeUK
SNIPERMikeUK is offline   Reply With Quote
Old 25th Aug 2010, 12:53   #14
Lance
Ender of discussions.
Lance's Avatar
Lance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming Saiyan
Really want one of those. V1020's. Just not in pink. Maybe as a next case..... I do need to replace mine at some point, pity it doesn't support watercooling though as that was my plan.
__________________
Originally Posted by mrMonkeyChunks View Post
All hail lance, the lord of interior design.
Lance is offline   Reply With Quote
Old 25th Aug 2010, 12:58   #15
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
Ohh, I like the V2120!
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 25th Aug 2010, 14:20   #16
Hakuren
Multimodder
Hakuren has yet to learn the way of the Dremel
Keep in mind that V1020 in dusty environment is a bad idea (had one from older model). It looks really bad because mesh is constantly "attacked" by dust, and keeping it clean is a full time job.
If someone want water cooling - in particular with more than 1 loop - then Lian-Li is not the way to go. Pick a Mountain Mods case (in Europe only available - with delay - from aquatunning.de). You get 15mm fan spacing in standard, perfect for every radiator. You don't need any DIY to install WC system in MM box.
Hakuren is offline   Reply With Quote
Old 25th Aug 2010, 14:30   #17
Zinfandel
I Mod, Therefore I Own
Zinfandel's Avatar
Zinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpit
Do you work for MM? That's twice now.
1020 looks lubberly.
Zinfandel is offline   Reply With Quote
Old 25th Aug 2010, 15:03   #18
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
It's not pink, it's a deeper red. Just strip lights make colour correction very difficult.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 25th Aug 2010, 15:03   #19
Fingers66
Kiwi in London
Fingers66's Avatar
Fingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming Saiyan
drooool, dribbbble <wipes mouth>...
Looking forward to seeing the 4 bay NAS box and the black V1020.
__________________
Gaming: [Silverstone TJ08-E][Asus Z170M-PLUS ][i5-6600K][Tundra TD03][16GB 2666MHz][Asus 7970 DCUII TOP][Samsung 850 Evo 500GB][Corsair HX650][Dell U2412M][Corsair K60]
Main: [Lian Li PC-A04][Asus Z97M-Plus][i7-4770K][Corsair H55][16GB 1600MHz][iGPU][Samsung M.2 NVMe 256GB][Seasonic X-650 Gold]
Kids: [Silverstone SG05B][Asus H87I-Plus][i3-4330][8GB 1600MHz][Asus 6850 DirectCU][Crucial M4 256GB][ST45SF 450w][Dell E207WFP]
NAS 1:[Synology DS211j] NAS 2:[Homebrew OMV]
Fingers66 is offline   Reply With Quote
Old 25th Aug 2010, 15:30   #20
murtoz
Busy procrastinating
murtoz has yet to learn the way of the Dremel
+1
Was going to ask the same thing after the first time...
murtoz is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
