#1 |
CustomPC Staff
TNMOC hosts retro-coding lessons
The National Museum of Computing has played host to an interesting experiment in retro coding.
http://www.bit-tech.net/news/bits/20...ding-lessons/1
#2 |
Sharing is caring
Problem is, it's not going to make users do fewer stupid things.
Nice idea, if unlikely to be well received by any but us "enthusiasts"
__________________
Desktop: Asus Sabertooth X58, 12gb Corsair XMS3, i7 950, 2x XFX 6870 1gb's, Corsair 1kw Laptop: Alienware M15x, 5730 1gb, 8gb DDR3, i5 520M, Samsung 830 256gb, Seagate Momentus XT 500gb WHS: Gigabyte Z77-D3h, i3 2100, 16gb DDR3, 5xWD 1tb, 5x Seagate 1tb I game, Do you? |
#3 |
Officious Bystander
Awesome idea. I learnt to code on a BBC Micro, first with BASIC then with assembly language, and it really doesn't get closer to the metal than that. Even just using the machine required an understanding of using a command line. Then I progressed to the Acorn Archimedes with its RISC instruction set and learnt assembly all over again. Then I moved on to a 386 and had all the fun of dealing with the command line, batch files, extended memory headaches, qBASIC, and progressed to Pascal and C/C++. God I'm showing my age! Anyway, that basis gave me a solid understanding of the principles common to all computing systems, that anyone learning about computers by using a modern PC would simply never get.
For writing practical programs, modern systems are all very well - you can put together an app with a GUI that does something useful in about 10 lines of code, but it shows you nothing about all the stuff going on to actually make it work - memory allocation, resource management, threading / time-slicing and all the complexities of a modern multitasking graphical OS on modern hardware (multiple cores, processing on multiple platforms - GPU, CPU etc.) mean that writing in pure assembly would be totally impractical and that layers of APIs are needed to make things work, but all that abstraction obscures the important issue (for a computing student) of HOW things work.
__________________
My Flickr
#4 |
Multimodder
I promised myself I would never say anything this lame on the Internet without it somehow being sarcastic and cutting to some poor idiot, but I'm going to say it anyway.
ZOMG!! PDP-8!!! Okay, I've got the over-enthusiasm out of my system, normal operation shall resume shortly after I find some sedatives. |
#5 |
This is a title
In my uni course we had a module on basic computing, we went from building a simple counting circuit (where the 'clock' was me moving a wire between two connections) up to basic coding in assembly on something so old I didn't recognise it . Really helped me get an idea of the more low level stuff.
#6 | |
I Mod, Therefore I Own
Started with Basic on a Commodore C16
![]() But ehhh: Quote:
They could learn this on a modern system (something unix based without the desktop loaded)
__________________
SN25P A64 3700+ (San Diego) 2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T X1800XT 512mb Sapphire 200GB Samsung SP2004C 24" Asus something 1920x1080 |
#7 |
WIIGII!
bit-tech Staff
Yes, which was my point. I'd disagree: running a command isn't the same as writing a program. Sure, you can use shell scripts (or batch files, if you're a DOS-head) to do things - but that's a scripting language, not a programming language. You try doing something at an sh shell with no access to external programs - you're going to struggle!
Scripting != Programming, at least in my opinion. Your mileage may differ. Void where prohibited. Probably contains traces of nuts. Keep out of children.
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#8 |
Hypermodder
Great idea imo! This is certainly something I would benefit from. While my programming knowledge is abysmal, I would still love to learn more about how computers actually work.
__________________
Asus P8P67 PRO ¦ Intel i5 2500K @ 4.4GHz ¦ Titan Fenrir ¦ XFX 6950 @ 6970 ¦ 2x4GB Corsair DDR3 1600MHz ¦ 2x Crucial C300 128GB (OS + Games) ¦ Samsung Spinpoint F3 1TB ¦ Auzentech XFI-Prelude + Creative T7700 7.1¦ Enermax Liberty 500W ¦ Corsair 650D case ¦ HP 24" LP2475W ¦ Win7 x64
#9 |
Multimodder
It's a good idea to do some low-level programming even if it's a little frustrating sometimes, it gives you a better appreciation for high-level languages and increases your knowledge of the underlying CPU and memory processes.
I think that programming in binary is a step too far and a pointless exercise at best. Programming in the assembly language of a simple RISC architecture is a better idea and teaches you the concepts of the stored program model we use on computers today. You can also do this in an emulator of some sort on any modern computer. |
#10 |
Banned
ah now that's a good class.. poke and peek registers =] when I was a kid I think I memorized most of the common registers used on the atari 800xl you had msb (most significant byte) and lsb for some and you always used variables to save memory.. fun stuff
#11 |
Bunned
Pah, we learn assembler in electronics.
Also, since when did ICT actually become about computers? It seems like a good idea though. More people need to learn how computers actually work. |
#12 |
Multimodder
"Also, since when did ICT actually become about computers?"
I think since far too many people think learning office means they are a computer wizz, as that's all ICT seems to basically concentrate on. Learnt BASIC on my Speccy, then again on the BBC, then again on the C64!! - still have my programmers reference guide for the C64. although most of the POKE and PEEK commands I used were for unlimited lives in games etc.
__________________
Main Rig: C= Amiga A1200, ACA1231 (68030 @ 42MHz, 64MB RAM), 4GB CF HDD ![]() HTPC: E8400, HD5830, 4GB RAM, EK blocks, 1.5TB HDD's |
#13 | |
i hate the person above me
I went Spectrum -> QBasic -> Some Casio calculator basic variant -> VBA ->SQL + C# with the odd other little bit here and there |
#14 |
69 Dude!!
My first bit of programming was on a ZX Spectrum +3 with 128 KB RAM!
But I'm not sure you need to go back that far .. so long as you learn how to use C properly (Malloc, Pointers, Garbage Collection) you will be miles ahead of the competition. |
#15 |
Supermodder
I think it's a fantastic idea. Although I suspect the fact the course went down well means the participants were, shall we say, 'cherry picked'.
We did assembly / binary when I was at college, and no where near enough of it imho. Still having knowledge of how things work, and the mental structure for dealing with things from the base up has really helped me immensely in the commerical world. |
| Thread Tools | |
