Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th Aug 2010, 09:26   #1
julieb
Minimodder
julieb has yet to learn the way of the Dremel
AMD aims Bobcat at servers
http://www.bit-tech.net/news/hardwar...t-at-servers/1
julieb is offline   Reply With Quote
Old 27th Aug 2010, 13:55   #2
TWeaK
Supermodder
TWeaK's Avatar
TWeaK has yet to learn the way of the Dremel
I'm really losing my faith in AMD. What's the point of routing for the underdog when they stumble over so many important things (Llano anyone?)? The fact that they're only just starting to consider developing something low-power for the server market when every other player is already half-way there at least is just another example of this.
God I almost sound like crazyceo.
ARM are the new AMD. Now, if only Microsoft would hurry up and make a decent version of Windows for it...
TWeaK is offline   Reply With Quote
Old 27th Aug 2010, 14:39   #3
Goty
Supermodder
Goty has yet to learn the way of the Dremel
Well, since Llano hasn't been released, yet, I wouldn't really call it a stumble. If you're talking about the release date being moved back, you've got to consider the fact that the process technologies simply weren't there to make it any earlier.
Goty is offline   Reply With Quote
Old 27th Aug 2010, 15:31   #4
TWeaK
Supermodder
TWeaK's Avatar
I was referring to Llano merely being yet another revision of the ancient K8 architecture, although you're right that I shouldn't pass judgement until it's released and tested. It's just that people have been pinning hopes on Bulldozer bringing AMD back into contention but now we find it's geared towards the server/workstation market, with everyone else being left with K8 for their desktops.
I am still optimistic about Bobcat though, it could be good to have a netbook with reasonable performance. I just think they're coming in too late for the low power server market. I think those in the know will probably lean towards ARM once their products are out and those who want Windows servers or anything else will likely go for Intel.
Old 27th Aug 2010, 18:41   #5
Goty
Supermodder
You do realize that AMD has traditionally released new architectures for the server space first and then re-purposed them for the desktop, right? That's exactly what happened in the Opteron-Athlon 64 generation and that worked out quite well, now didn't it?
Also, Llano is not going to just be K8 with a GPU strapped onto it; there should be modifications made similar to those in the Athlon 64 -> Phenom -> Phenom II transitions. The only source out there claiming it's going to be an unmodified K8 is Fuad over at Fudzilla, and he's a certified moron.
Old 28th Aug 2010, 03:17   #6
TWeaK
Supermodder
TWeaK's Avatar
I never said that it was going to be pure K8, but let's face it: compared to the Core i series or even the Core 2 series AMD and its K8 derivatives just haven't cut the mustard. Sure, they'll probably bring out an enthusiast chip based on the Bulldozer design but I doubt it will have the performance advantage Opterons had in their day. Meanwhile, we're being told to wait just a little while longer (yet again) until we can have something worth splashing out on, other than for budget/power efficiency needs.
I do still hope AMD can get its foot in the door and deliver something worthwhile, but I'm almost completely out of hope. If it wasn't for ATi I'd completely write the company off.
Old 29th Aug 2010, 22:46   #7
theflatworm
Gordon Freeman's Crowbar
theflatworm has yet to learn the way of the Dremel
Am I the only one who thinks the headline: "AMD aims Bobcat at servers" is awesome? Reminds me of:
http://xkcd.com/325/ which is one of the best internet cartoons ever!
theflatworm is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
