#81 |
Never stuck with stock@Hotmods.net
#79: Hm, strange indeed. If there's trapped air in there, it SHOULD work it way out eventually, but with all that tossing and turning you did, I doubt there's any air left. Is the fluid hazy (because of air bubbles in it)?
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#82 |
Modder
I have had about 6 different loops in the past, and the last one I did had the same problem.
This was using a XSPC bay top for a DDC pump and i tried for hours to get the air out. I couldnt find out the problem (removed the loop and replaced with air as I had a LAN party next day). but the previoous loop I had the liquid gravity fed directly in to the top port of the pump from an EK spinner Res, this loop had no problem with air bubbles. Now to be honest I think it was down to the res choice as it releases the air bubbles out easier. Here are pics of the set up... ![]() ![]() Hope this helps.... |
#83 | |||
MMMMMMm watercooling....
![]() Will be working on this tomorrow and give you all an update.... fingers crossed it works with all my newfound information thanks to you guys. Cheers Rip
__________________
Asus ROG Maximus V Formula MoBo, Core i5 3570K @ 4.7Ghz, 6GB Corsair Dominator Ram 1600Mhz, SLi GTX460's(1GB), Enermax Revolution 1250W PSU, Xigmatek Elysium Chassis
Dual WaterCooling Loops with 12 Noctua NF-P12's = WOOOOSH!!! ![]() |
#84 |
Working on suggested solutions at the moment guys. Just wondering if the flow route through my blocks is ok. suggestions on changes are very welcome.
![]() Have Eliminated any Pump Fault. Have Eliminated any radiator fault. Its gotta be the waterblocks now.... Gonna open all the blocks again to be 100% sure they are not blocked just incase. Cheers Rip
__________________
#85 |
Project: Elegant-Li
I know those mosphet blocks and northbridge blocks are serious flow killers, that may be contributing.
I would change the path to cpu-top mosphet-left mosphet-northbridge. The current set up may be having trouble pumping through the restrictive blocks. Going straight from the cpu to the top block will allow gravity to help feed fluid into the lower blocks and may fix your problem.
__________________
Project: Elegant-Li *NEW* Project: Alpha FINISHED Project: LEXA Revival FINISHED Project: LEXA FINISHED MOTM Nominee October 08 |
#86 |
Hasta Maņana
Are you running a DDC or D5?
#87 |
Side bewb.
I believe he's running a DDC, so there's pleanty of head pressure there, I think it could well be what the boy from oz said. Have a look at re-arranging the loop, it may help.
__________________
Bewbs. |
#88 | ||
Yep DDC...
)The kicker is i have had this system running perfect 3 weeks ago as it is... Thanks for all the help guys... Keep em coming. Will post later on today on my finding on seperate block testing. Cheers Rip
__________________
#89 |
Side bewb.
Tbh man, I'd go grab some 90* fittings, I've used one in my loop and it's fine, the DDC has enough pressure.
Actually, I've just looked at your loop, they're huge. It could be a case that the pump doesn't have enough power to pump the fluid all the way round the loop. Maybe.
__________________
Bewbs. |
#90 | |
![]() The 90 degree fittings might be the next option. Thanks mate Rip
__________________
#91 |
Side bewb.
Np, it's what we're here for! As for it running perfect 3 weeks ago? Remember, computers are just like women, temperamental beings, it's probably hit its time of the month.
__________________
Bewbs. |
#92 | |
Cheers Rip
__________________
#93 |
Project: Elegant-Li
I'd give the 90degree fittings a try anyway. Because the blocks slow down the flow rate so much the fittings will hardly make a difference.
Thanks for the +re pas well mate, glad I could help.
__________________
#94 |
FAULT FOUND 25/10/2010
Hay Guys,
First thanks to all who helped troubleshoot this with me. its very much appriciated. The vast amount of knowlage from you all makes for good company i have to say. I have found the problem part. The CPU BLOCK. Its a Swiftech Apogee TX. only a lil bit of coolant is coming through which the pump only a foot away going full pelt. very odd really given you would think it only has a very simple job. rather than opening it up and messing around anymore i am getting an RMA set up with Scan and it replaced under warrenty. More time wasted but its the best option. Least i dont have a 3 grand system standing in my living room looking sorry for itself anymore.... Thanks Again guys, More pics of final build as soon as the block comes back... Woot. Cheers Rip
__________________
#95 |
The modding head is firmly back on.
You've found the problem that's the main thing, I know it slows things down, but that's all part of the fun.Well that's what they say, but personally I reckon it's a load of bollocks.
#96 | |
![]() Rip
__________________
#97 |
Project: Elegant-Li
I'm glad you found the problem mate. Don't the GTZ's have a flow plate in the upper block to disperse the water flow? That's probably what the problem is.
__________________
#98 | |
http://www.swiftnets.com/assets/imag...x-exploded.png My guess is that some gunk got stuck down there. Or perhaps something was dropped down there without him noticing before putting the loop together. In any case, to RMA it seems a tad exaggerated, as this block comes apart pretty easy for inspection.
__________________
#99 | ||
Cheers Rip
__________________
#100 |
Project: Elegant-Li
Swiftech tend to make really good stuff and their warranty is pretty lenient. I had a Swiftech Apogee GTX and the alu top started to corrode after a few months. They sent me a Delrin replacement free of charge.
__________________
| Tags |
| lian-li - case mod |
| Thread Tools | |
| View Mode | |
