Reply
Thread Tools View Mode
Old 5th Sep 2010, 04:58   #1
BigBig5
Single Braid Sleeving
BigBig5's Avatar
BigBig5 has yet to learn the way of the Dremel
NZXT M59 [aka The Blue Green Machine] Updated 10/24
The real The Blue Green Machine mod. I had a old case mod that had the same name, unfinished because of window cracking and case too small. Well a fresh start. In the pic it has a old PSU thats going to be swiched out with a Siverstone DA 650 with Single Braided Sleveing. Here is the link to the hardware specs http://www.mypcmod.com/viewpc.php?id=228
This is my main computer I use and I go to college, so its not going to get done fast.
Before pic:
BigBig5 is offline   Reply With Quote
Old 6th Sep 2010, 02:04   #2
BigBig5
BigBig5's Avatar
UPDTAE:
I have most of the sleeving done. I use MDPc X sleeving. Colors: Gray, Aquamarine-blue, and Green. Still need to do 4-pin molex.
Here are some pics:
Siverstone DA 650
24-pin ATX: The rest of the wires will be blue.
SATA
__________________
AMD
MODS:
Old 10th Oct 2010, 01:05   #3
BigBig5
BigBig5's Avatar
Here is some updated pics. I still have to get 2 140mm fans and 1 120mm fan. Maybe some led lights.
__________________
AMD
MODS:
Old 10th Oct 2010, 11:26   #4
Mattmc91
LOLS I TROL YOU
Mattmc91's Avatar
Mattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run Crysis
Did you even shrink your heatshrink? it looks so loose on the wires.
It's also 2x as long as it's meant to be.
looks a lot cleaner at the least.
Mattmc91 is offline   Reply With Quote
Old 10th Oct 2010, 16:56   #5
BigBig5
BigBig5's Avatar
I did the day I finished the sleeving.
__________________
AMD
MODS:
Old 11th Oct 2010, 16:40   #6
BigBig5
BigBig5's Avatar
BUMP
__________________
AMD
MODS:
Old 11th Oct 2010, 16:45   #7
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
You dont "bump" a worklog... Your last post was yesterday.
Put you camera on something static, put the iso down to 100.
Your heatshrink on the cables looks to be 3 times as long as needed.
Nice colorscheme otherwise
__________________
p0Pe is offline   Reply With Quote
Old 24th Oct 2010, 04:57   #8
BigBig5
BigBig5's Avatar
Updated: I zip tied the 24-pin wires to the motherboard tray and covered it with a green cable tie.
__________________
AMD
MODS:
Old 24th Oct 2010, 05:09   #9
BigBig5
BigBig5's Avatar
I'm going to get 2 140mm green led fans for the top and 1 blue led fan for the side. The side fan now will be moved to the front. Thinking of painting the front mesh green and bay covers blue, green or alternating. What do you all think would look better? The PCI slot covers will be alternating blue and green. Might get some wire grills for the back and top fans and paint them blue, should I cut them out for that?
__________________
AMD
MODS:
Old 30th Aug 2011, 01:25   #10
BigBig5
BigBig5's Avatar
I am not going to do much of any thing else on this because its being my main computer for school and gaming. I'm in the planning of building a small HTPC/Gaming computer mod.
__________________
AMD
MODS:
Reply
Tags
m59, nzxt, nzxt m59
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
