Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Sep 2010, 09:34   #1
julieb
Minimodder
julieb has yet to learn the way of the Dremel
Samsung preps wireless USB chips
http://www.bit-tech.net/news/hardwar...ss-usb-chips/1
julieb is offline   Reply With Quote
Old 6th Sep 2010, 09:43   #2
do_it_anyway
Supermodder
do_it_anyway's Avatar
do_it_anyway has yet to learn the way of the Dremeldo_it_anyway has yet to learn the way of the Dremel
The major problem here being that its obviously not b/g/n compatible. Its a new format entirely.
So, they are talking about televisions; I assume for internet tv(?); and yet it probably won't work with your existing router.
If you are a wireless fan, you therefore need b/g/n dongles for your PC's to connect to the router, samsung wireless dongles for your protable tech and a powerlead to charge it.
At these speeds, IF it can corner the market it might be quite good, but I can't see it overthrowing established tech. (Unless the dongle they makes includes a compatible b/g/n chip as well.)
do_it_anyway is offline   Reply With Quote
Old 6th Sep 2010, 09:53   #3
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
It's wireless *USB* - it's not for networking at all! It's literally a wireless replacement for a USB cable, between - for example - a camera and a PC.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 6th Sep 2010, 10:24   #4
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
I have 8-10 USB devices...and none use the power feature.
Maybe the issue isn't so big as suggested here?
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 6th Sep 2010, 10:30   #5
do_it_anyway
Supermodder
Point taken, but this further raises a "whats the point" question.
Add a wireless "n" chip to your device, then have that goddam awful transfer software you always have to install look for wireless devices on your network and transfer via the existing wireless network.
Voila, wireless transfer, at high speed, without all the R&D costs, and without the consumer needing yet more dongles.
Old 6th Sep 2010, 11:08   #6
Gareth Halfacree
WIIGII!
bit-tech Staff
Who mentioned dongles? The point is to have the chips *built-in* - that's why they come with a NAND controller and SD support.
Plus, you find me an 802.11n chip which costs as little as this thing will, takes up as little room on a PCB, and draws 300mW under full load. G'wan.
You're comparing apples to Megatron here.
__________________
Old 6th Sep 2010, 11:12   #7
Cogwulf
Minimodder
Cogwulf has yet to learn the way of the Dremel
I'm looking forward to wireless keyboard and mice which don't need to be sold with their own propriety dongle.
"plug and play" would become "open box and play"
Cogwulf is offline   Reply With Quote
Old 6th Sep 2010, 11:49   #8
do_it_anyway
Supermodder
Gareth, I am obviously failing miserably to understand this tech. And I apologise for raising non-issues.
Last question. How does the master PC that the device is going to sync to send and recieve the data? Surely it needs the same tech in the PC, and that means expansion cards or dongles until the motherboard manufacturers stat implementing built in chips?
Like you said, "it's been a finished specification since 2005 but is most likely nowhere to be seen in your rig."
I just immediately assumed that a dongle was going to be needed.
Old 6th Sep 2010, 12:12   #9
Cogwulf
Minimodder
Obviously a dongle or PCI card would be needed until it was integrated into motherboards, and I assume you would only need a single dongle to connect multiple devices.
Bluetooth devices for the PC haven't really caught on, hopefully the simplicity of being able to use existing USB drivers for a wireless device will encourage manufacturers to start using the technology
Old 6th Sep 2010, 12:22   #10
shanky887614
Multimodder
shanky887614 has yet to learn the way of the Dremel
whats the point in this?
you wil sill have to have you pc switched on
why dont they save themselfs the trouble and just release a wifi router with nas support built in s you just attach a usb hdd to it
shanky887614 is offline   Reply With Quote
Old 6th Sep 2010, 12:33   #11
Cogwulf
Minimodder
errr... they have
Old 6th Sep 2010, 13:01   #12
Phil Rhodes
Hypernobber
Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.
I think the point here is, yes, OK, it doesn't replace certain current applications of USB because they (very sensibly) included power with USB. It might, I think, suggest entirely new uses that were never practical in the first place, though.
Phil Rhodes is offline   Reply With Quote
Old 6th Sep 2010, 13:36   #13
Er-El
Supermodder
Er-El's Avatar
Er-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the Dremel
I really hope this takes off. It would be nice to have a universal wirelelss standard for peripherals supported everywhere, from all motherboards, to games consoles, etc. Because I sure as heck don't see that with Bluetooth yet!
Er-El is offline   Reply With Quote
Old 6th Sep 2010, 14:12   #14
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
to late make it usb3 capable, then release it initially as a usb3 pcie card with wireless usb in it as well
i mean speed wise not power.
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 6th Sep 2010, 15:22   #15
Sh00ter
Multimodder
Sh00ter's Avatar
Sh00ter has yet to learn the way of the Dremel
i can see it being usefull for most peripherals that you dont want next to ur pc or screen, printers, scanners, hell even card hubs, wireless usb stick anyone?? id get one just so i dont have to faff around plugging in and out to do work at home - if the range is something like 10m then i think it will be a hit
Sh00ter is offline   Reply With Quote
Old 6th Sep 2010, 18:22   #16
chrisb2e9
Dont do that...
chrisb2e9's Avatar
chrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysis
Sounds like blue tooth to me. A slight bit different of course but if my computer doesn't have blue tooth then why would it ever have this?
__________________
life can evolve without begetting plants or birds or cuddly mammals or sentient beings who write blogs on the internet; it just begets a glob of ooze.
chrisb2e9 is offline   Reply With Quote
Old 6th Sep 2010, 18:41   #17
Altron
LIKE A BAUCE!!!!
Altron's Avatar
Altron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the Dremel
Agreed. We already have a standard for low-power wireless data.
While it hasn't really taken off on desktops, it sure is popular on smartphones and laptops.
What would this provide that Bluetooth doesn't?
__________________
If this post is not up to your standards, please lower your standards.
e^i(pi)+1=0
Altron is offline   Reply With Quote
Old 6th Sep 2010, 20:01   #18
Wicked_Sludge
My eyes! The goggles do nothing!
Wicked_Sludge's Avatar
Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.
second'd
and furthermore, dont some motherboards already have bluetooth tech on-board?
__________________
My Rig:
Gigabyte GA-P55A-UD3|Intel Core i7-870 @ 4.0Ghz|12GB G.Skill Ripjaws DDR3 1600|AMD 7970GHz Edition|2x Barracuda 1TB RAID 1
Wicked_Sludge is offline   Reply With Quote
Old 6th Sep 2010, 20:48   #19
ZERO <ibis>
Supermodder
ZERO <ibis>'s Avatar
ZERO <ibis> has yet to learn the way of the DremelZERO <ibis> has yet to learn the way of the Dremel
Yea but it is more of a novelty.
This could be cool for all sorts of remotes too by simplifying the connections.
__________________
965 @ 4.26GHz-P6T DELUXE-GTX 280@750&1307-DDR3 Triple Channel@1001 MHz-RAID 0 Cheta 15.6k SAS-All Water cooled
IBIS GAMING
ZERO <ibis> is offline   Reply With Quote
Old 6th Sep 2010, 21:15   #20
DXR_13KE
BananaModder
DXR_13KE's Avatar
DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.
Bandwidth.
__________________
Renegade X - Release Date Unveiled
Check it out!!
DXR_13KE is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
