Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 8th Sep 2010, 21:29   #1
Sponge12349
(づ。◕‿‿◕。)づ ︵ ┻━┻
Sponge12349's Avatar
Sponge12349 has yet to learn the way of the DremelSponge12349 has yet to learn the way of the Dremel
GTS450 Final Specs revealed!
Stumbled across these specs for the GTS450 earlier, thought I'd share.
Rumoured release is mid september and I suspect pricing will probably be around the £90-110 mark.
How do you guys think this card will shape up against the HD5770/5750. If this card matches the HD5770 performance with a HD5750 price tag Nvidia would surely be dominating that share of the market over AMD. It'd be a real turn around for Nvidia compared with how they were somewhat stuggerling before the launch of the GTX460.
How do you guys think the GTS450 will shape up with these specs vs other cards out at the moment?
Sponge12349 is offline   Reply With Quote
Old 8th Sep 2010, 21:36   #2
Phalanx
Needs more dragons and stuff.
Phalanx's Avatar
Phalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for president
Can we have a source please? They better be on the £90 or lower mark, otherwise they'll be competing against their own card (the 460).
__________________
XBOX Live!: Ph4lanx | Steam: Catachan
Phalanx is online now   Reply With Quote
Old 8th Sep 2010, 22:02   #3
meandmymouth
I *am* a Dremel
meandmymouth's Avatar
meandmymouth should be considered for presidentmeandmymouth should be considered for presidentmeandmymouth should be considered for presidentmeandmymouth should be considered for presidentmeandmymouth should be considered for presidentmeandmymouth should be considered for presidentmeandmymouth should be considered for presidentmeandmymouth should be considered for presidentmeandmymouth should be considered for presidentmeandmymouth should be considered for presidentmeandmymouth should be considered for president
They have to come in under £100 otherwise people will just pay the extra few quid for the 460.
It brings the green team back with a bang!
meandmymouth is offline   Reply With Quote
Old 9th Sep 2010, 06:26   #4
docodine
I Mod, Therefore I Own
docodine's Avatar
docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!
So.... what are the specs?
__________________
Intel i7-3820 @ 4.65GHz | HD 7850 | 4x4GB Vengeance | Asus Sabertooth X79
HAF XB | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet
docodine is offline   Reply With Quote
Old 9th Sep 2010, 06:28   #5
Zinfandel
Zinfandel's Avatar
Zinfandel should be considered for presidentZinfandel should be considered for presidentZinfandel should be considered for presidentZinfandel should be considered for presidentZinfandel should be considered for presidentZinfandel should be considered for presidentZinfandel should be considered for presidentZinfandel should be considered for presidentZinfandel should be considered for presidentZinfandel should be considered for presidentZinfandel should be considered for president
The specs have been out for a fair while now.
First benchmark is in.
I reckon it's going to have to hit £80 considering you can get a 768mb 460 for £110 now.
Benchmark here.
As for specs.
The card will have 192 Cuda Cores and a 1GB GDDR5 memory along a 128-bit wide memory interface. The clocks of the card are maintained at 783/1566/900 MHz (core/shader/memory).
If these are £80, might be a nice little SLi set up for £160 considering they only draw (apparently) 106w.
Zinfandel is offline   Reply With Quote
Old 9th Sep 2010, 08:06   #6
Sponge12349
(づ。◕‿‿◕。)づ ︵ ┻━┻
oh sorry, i forgot the link
http://wccftech.com/2010/09/06/nvidi...ails-revealed/
and also on http://www.techpowerup.com/130391/Ge...sitioning.html
Old 9th Sep 2010, 10:42   #7
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.
Looks pretty darn good. If the price is right it's a goer.
__________________
Mac:Macbook Pro 7,1 w/Samsung 830 256GB, ML
xbmc:Windows 8 x64, Fractal Design Node 304, MSI Z77IA-E53, G2120 fanless, 2x2GB, 3TB, Samsung 830 256GB
dazzypops:Win8Prox64, i5-2500k@4.3, MSI Z77A-GD65, 8GB, 4TB, Samsung 840 Pro 256GB, 2 x MSI GTX660 (+110core, +535mem), LG IPS 24", Z5400 5.1
kenco_uk is offline   Reply With Quote
Old 9th Sep 2010, 10:50   #8
meandmymouth
I *am* a Dremel
If they scale as well as the 460's then yeah, SLi is coming into it's own.
Old 9th Sep 2010, 13:48   #9
Rofl_Waffle
Supermodder
Rofl_Waffle has yet to learn the way of the DremelRofl_Waffle has yet to learn the way of the Dremel
The real question is how the GTS 450 go against the 6770.
Rofl_Waffle is offline   Reply With Quote
Old 9th Sep 2010, 13:52   #10
Zinfandel
Zinfandel's Avatar
Awfully, with any luck.
With that said, the 460 price drop changes the market so presuming the 6770 is at a similar price point to the 5770 it'll be up against the 460, not the 450.
Reply
Tags
5770, amd, ati, gts450, nvidia
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
