#1 |
Ultramodder
i guess this goes here
ok i got my gf2 mx 400 in abox hooked up to my video for a dvd/vcd/divx and music box
no problem is i brought a s-video - scart plug and pluged in the s-video instead of the rca/composite now i dont get colour in the picture and the new gforce drivers i have wont let power dvd 4 work in full screen with out me adjusting the screen res coz the newer drivers only do clone or spannin any thoughts please tell me i need hepl gettin this up |
#2 |
I *am* a Dremel
Try the very good www.tvtool.de it sorts out a load of nVidia TV issues.
Loads of people have had lots of luck with it. |
#3 |
Ultramodder
uno what mich thats twice u have kinda helped me out
any way ill try it out and see hwta i can do thanx |
#4 |
Ultramodder
dude i used it it fixes sum probs but still no colour
#5 |
I *am* a Dremel
1)Right try cycling your AV modes e.g. AV1 channel , AV2 channel on your television this often does the trick.
2)Sometimes if you use a input port compatable with S-VHS it works so try all scart sockets and all AV channel combinations. |
#6 |
Ultramodder
i have to scrats and 2 compisite only colour on rca/composite
#7 |
Freed on Probation
u might be outputting in the wrong tv format.
i know that on some pal tvs if u feed them an ntsc source itll dispaly in black and white... hazza
__________________
I may be fat but at least I am not Ginger "The President is no longer a cross-eyed Texan warmonger, unelected, inarticulate, who epitomises the arrogance of American foreign policy" - Boris Johnson |
#8 |
Ultramodder
my tv is ntsc compatible
#9 |
Freed on Probation
well mine said it was too, but it still displayed in black and white.
its worth a try eh?
__________________
#10 |
Ultramodder
yeah but when i use rca i use ntsc any way coz it uses less memory then pal thats how i no my tv is combatible plus i can choose what version of ntsc my tv will read or pal or auto
#11 |
Wannabe Martian
I take cycling through the AV inputs didn't help? My old mans TV was displaying B&W on svideo, until I relised that the AV input had two settings AV2 & AV2S. Once set to AV2S, it was fine. To get to that setting it was just a further cpush of the input button.
AV1 -> AV2 -> AV2S You get the idea.... The only other idea I can suggest is to check it out with a different cable - maybe a pin is buggered or there's a fault on one of the lines inside the cable.
__________________
"Maybe we're on Mars because we have to be, because there's a deep nomadic impulse built into us by the evolutionary process, we come after all, from hunter gatherers, and for 99.9% of our tenure on Earth we've been wanderers. And, the next place to wander to, is Mars. But whatever the reason you're on Mars is, I'm glad you're there. And I wish I was with you."
- Carl Sagan A GOO-ster is Born - Build Diary RSS I'm a Great Oakley product tester! My purpose built testing centre |
#12 |
Ultramodder
where abouts where that would be on my vcr
#13 |
Wannabe Martian
Err - thought we where talking about your TV, 'vette. If you're dasiy chaining through your VCR that coulr be the problem - it may not be passing the full signal through!
Try taking it out of the chain and plug the svideo feed direct to the TV scart socket that is svideo enabled. The AV input select button should be on your remote, and will look something like this: Code:
__________________
#14 |
Ultramodder
iu dont have scart or s video on my tellie its a cheap awa tellin im useing for the divx box
#15 |
Freed on Probation
dont use the scart then, ull loose any upgrade in passing tru the vcr anyway. so u may as well plug it straight into the back of ur telly....
or just change ur comp output to pal or pal 60
__________________
#16 |
Wannabe Martian
I'm guessing the only reason you're putting it through the VCR is to get an RF output to plug in the ariel socket?
__________________
#17 |
Ultramodder
ahh no im only puttin in the vcr becoz i aint got any more avs on my tv i only have 1 and my vcr has 4
#18 |
Wannabe Martian
Have you tried just sticking it direct to the AV socket?
If it works that way you could get a Scart switch box. You'd have to make sure that it passed Svideo signals though, bit TBH I don't think that's a problem as most of them do.
__________________
#19 |
I *am* a Dremel
You did not say it was through your video player that is why it does not work, just try it on a television and it may work.
You could buy a scart switch box from maplins that what my brother does with his computer and TV. The scart in the video player is not passing the chrominance part of the signal. |
| Thread Tools | |
