News Intel updates SSD toolkit
Discussion in 'Article Discussion' started by CardJoe, 13 Sep 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    I wonder how hard it would be to make the Tuner program work for other SSDs? If all it's doing is OS optimisations it shouldn't be too much trouble.
    Off topic, has anyone got any advice for configurations to optimise an OCZ Vertex (1st ed)?
  3. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Hope it works on my 160 G2... It wont become any faster because o my ICH8M-E...
    EDIT: It's the same performance as before :D
    But now I see that I already made 2.81T of writes on the SSD (how??), it only has 9 months...
  4. WildThing
    WildThing Minimodder
    26 Jul 2007
    Cool, I'll be giving this a try tonight.
  5. Gryphon
    Gryphon What's a Dremel?
    24 Apr 2009
    *puts the pedantic hat on*
    towards end of the second paragraph it should read 'but the first offers some...'
    other than that, something like this would be handy for other SSD makes... surely the changes to the system settings would be the same for any SSD?
  6. knuck
    knuck Hate your face
    25 Jan 2002
    I have had mine for 5 months and didn't even know they made a toolkit for it.
    Will try it right away.
    [12 seconds later edit]
    aaaaaaaaaaaaaaaaaand it doesn't work. I click on my SSD and it refreshes again.
    LAME
  7. Gareth Halfacree
    4 Dec 2007
    D'oh - branephart. Fixed, cheers.
  8. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    i didn't even know this existed :eek:
    "intel recommends running Intel SSD Optimizer once a week"
    i used it for the 1st time today.
  9. Ross1
    Ross1 What's a Dremel?
    15 Feb 2009
    thanks for the notice..... would have seen it otherwise. Didnt really do anything to my system, apart from advise me to turn super-fetch off. Personally, its something I find helps performance even with a SSD.
  10. Makaveli
    Makaveli What's a Dremel?
    25 Nov 2009
    Did you do any other tweaks to your system? I took the page file off my ssd etc.
    I've had my 160GB G2 since Dec 09
    so about 8 months
    And i'm only at 778GB's in host writes!
  11. V3ctor
    10 Dec 2008
    Never did that... I did it on my Q6600 with the GSkill Falcon and forgot to do it in this SSD on the notebook... big fail...
    Now I give lots of credit to HDD's too... That's alot of writes to do. Now with this toolkit It will be ok :)
  12. Taniniver
    Taniniver Minimodder
    24 Aug 2010
    Same for me Ross1. Also, predictably, the stuff about doing a TRIM on the drive says I can't run it because my drive is one of the first generation 50nm Intel SSD's, not the second generation 32nm ones.
    Cheers Intel. I really like being screwed by no TRIM support for being an early adopter. You are not telling me it's impossible to implement it on this drive, they just don't want to.
  13. robots
    robots What's a Dremel?
    27 May 2010
    Yay! I'm getting this right now. I use the old one once a week like it recommends. I don't know what it does if anything. Hopefully this one will do it's mysterious tweaking well.
  14. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    Thanks for the update, interestingly it wanted to disable prefetch along the already disabled Superfetch which Windows 7 disabled on first install.
Tags: Add Tags
