Reply
Thread Tools View Mode
Old 20th Sep 2010, 19:20   #41
DarkFear
Supermodder
DarkFear's Avatar
DarkFear has yet to learn the way of the Dremel
Wow. Nice!
You sure you have enough USB ports there?
DarkFear is offline   Reply With Quote
Old 20th Sep 2010, 20:06   #42
PabloFunky
Ultramodder
PabloFunky's Avatar
PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.PabloFunky is the Cheesecake. Relix smiles down upon them.
Yeah, quite a few usb eh?, but i think would of looked odd with any less.
The width of case is 310mm
may be too late, but i wanted to have artworked, the last 2 as usb charge ones.
not sure what the temps are supposed to be on the nb on a ud9, this board seems run hotter than the ud7.
ambient is 20, nb running at 46c, not going above 54 on load?
cpu temp also 2c hotter than on the ud7.... May need a little reseating of the cpu waterblock maybe.
One thing is the eist speedstep or whatever you call it dont seem to work right on this mobo?, always locked at the 2.80g of my i7 930, bios is eist enabled etc etc, so not sure whats going on, worked ok on ud7.
oh well its about the case really, not whats inside it i suppose.
I really hope this ud9 mobo is upto running MSN ok.
PabloFunky is offline   Reply With Quote
Old 23rd Sep 2010, 19:12   #43
flaming_goat
Modder
flaming_goat's Avatar
flaming_goat has yet to learn the way of the Dremel
why have you used individual cables for the usb ports? Is there a reason not to use a hub?
Will there be enough space to plug them all in on the mobo?
flaming_goat is offline   Reply With Quote
Old 24th Sep 2010, 16:22   #44
PabloFunky
Ultramodder
PabloFunky's Avatar
Initially i had intended to use doubles usb, but getting ones with long enough leads was a pain.
Also getting douyble moulded ones in vertical orientation seems impossible (well ive never seen any)_.
had made a circuit board up, to see how that would go, but pcb mounting, not enough mech support i felt.
Also would of been some issues with mounting them professionally onto front panel.
bottom 12mm ally panel is milled out to allow clearance and usb plate slots into milled front rear to sit right.
So was always open to design suggestions etc, but this way worked out the best.
first 4 usb can come from mobo header, another front 2 can be the usb charge ones on the ud9s header.
I was gonna buy that NXT usb expansion hub internal thing yes, that would of then given me all 8 usable.
Initially i had the ud7, but ud9 allows 2 more ports.
if i had say 6 usb on front, it may of looked odd, really i needed to tell artist to colour mark the last 2 usbs as charging ones.
if id known at time, i would of had it silk screened along with the rest.
However all theese little things have been noted, for the build of Monster3.
always happy for comments good or bad, only way i can improve things.
Old 24th Sep 2010, 17:29   #45
Ripitup121
MMMMMMm watercooling....
Ripitup121's Avatar
Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.
Wow man, Savage Mod, I love the "FIRE-UP" text under the power switch. Great Job
__________________
Asus ROG Maximus V Formula MoBo, Core i5 3570K @ 4.7Ghz, 6GB Corsair Dominator Ram 1600Mhz, SLi GTX460's(1GB), Enermax Revolution 1250W PSU, Xigmatek Elysium Chassis
Dual WaterCooling Loops with 12 Noctua NF-P12's = WOOOOSH!!!
Ripitup121 is offline   Reply With Quote
Old 24th Sep 2010, 17:45   #46
PabloFunky
Ultramodder
PabloFunky's Avatar
Thanks, Yeah, i always wanted to have this screened onto my panel, so wasnt gonna let it go by on this case.
Artist said that when prepping front panel may loose screened text..
Im like Noooooooooooooooooooooooooooo!
he said is easily capable of reproducing it, hes a freehand artist, which is what i want, to avoid clinical style, however he was saying that has got a stencil cutter he uses if really needed, which may be the option here.
I dont want him going too arty farty and spoiling the plainish look, but hes been good in past, so should be fine.
Im so tempted to ring him everyday, saying is it done yet, but i know he hates that, and i dont wanna rush him.
Ive seen i can now replace my ek d5 pump tops with white ones, do you think that will look ok?
Im trying to get everything either blue or white you see, with gold fittings.
Old 28th Sep 2010, 12:13   #47
PabloFunky
Ultramodder
PabloFunky's Avatar
right got 4 d5 tops in white to replace black ones.
Well not sure if i prefer black now,, typical, but not gonna change back, and it suits the colour scheme, perhaps when everything is blue/white will be better, also my photography isnt too good.
I think if rear of pump/housing was blue would be good
if i powdercoat the screws white or blue, should look loads better, the black screws dont look right unless the build was black/white.
Opinions welcome.
1 down 3-4 to go
Old 28th Sep 2010, 12:37   #48
Mattmc91
LOLS I TROL YOU
Mattmc91's Avatar
Mattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run Crysis
Pidgeon poo internals.
Get the copper parts of your HK 3 nickle plated, or gold plated ^^
nub.
Mattmc91 is offline   Reply With Quote
Old 28th Sep 2010, 12:38   #49
PabloFunky
Ultramodder
PabloFunky's Avatar
Nickel,, ,hmmmm shiny but crappy, gold palte may be a good idea though.
5014 Is The best.
what is this nub?
Old 28th Sep 2010, 13:06   #50
Mattmc91
LOLS I TROL YOU
Mattmc91's Avatar
You is
Why not get a load of cheap fittings, strip them down and gold plate them if you want gold fittings?
Old 28th Sep 2010, 13:14   #51
PabloFunky
Ultramodder
PabloFunky's Avatar
Pointless, gold fittings readily available matey, got loads.
I prefer the look of the copper to nickel plating also
looked up nub, its not a word, sorry, so cant understand what the hell you are on about.
your welcome to come round and fit the other pump tops for me though.
I should be going out to powdercoat today the bits that are sprayed and are beginning to wear.
Now if i get everything in white will be £20, however a second setup cost if i want some parts in 5014 blue, plus what i said id pay mate to take it over in his car for me.
as i want bits p[owdered ready for Monster3 also.
however pc is running and loving me ud9
Old 28th Sep 2010, 16:38   #52
BearJew
Novice Artificer
BearJew has yet to learn the way of the Dremel
This case is great looking and well thought out to accomodate all the cooling you've put in. Well done, it's a piece of beauty.
One question thought, i'm planning my own build and was just wondering what the dimensions where on your i/o cut out and pci cut out on teh back plate?
BearJew is offline   Reply With Quote
Old 28th Sep 2010, 16:47   #53
PabloFunky
Ultramodder
PabloFunky's Avatar
Thanks, fair time in the planning for sure.
Well i made the rear plate based on i/o part, based on an old one from an 7 pci case.
Was made from 1mm ally, and folded,
If i find some spare time, will measure it up for you, but i think someones done a sketchup model already on here somewhere?
and someone made one from solid billet.
Old 28th Sep 2010, 20:46   #54
BearJew
Novice Artificer
Cheers for the response, i made a thread earlier about the same problem and two people replied giving me all the answers i needed, but thanx for taking the time to respond. =)
Again excellent build ^^.
Old 28th Sep 2010, 23:36   #55
Infiniti
i modded the wheel!
Infiniti's Avatar
Infiniti has yet to learn the way of the Dremel
awsome looking build ya got here!! kep it up buddy
Infiniti is offline   Reply With Quote
Old 29th Sep 2010, 05:31   #56
PabloFunky
Ultramodder
PabloFunky's Avatar
Thank you, waiting on artwork, but not want to bother him yet.
Pc seems working ok, although i seem to have a bit of cap whine, or feedback from psu or something, its not loud, but when you focus on it, its a little annoying, not too good for a £400 mobo eh?
unless its coming from pumps, which i doubt.
ooops just seen ud9 now £50 cheaper, dam how much profit must be made on theese things, to be able to do that
till next update.
Old 6th Oct 2010, 18:06   #57
PabloFunky
Ultramodder
PabloFunky's Avatar
Ok, ive spent along time getting this case the way i wanted it, precision making most parts,
I really didnt want the artwork stage to spoil it, but have been really happy with my artist.
Now im Really reall really happy with what pic he just sent me.
He gave me a teaser, as other panels almost finished also, hes even going to recorrect a speeling error on the front panels silk screen (think i spelt auxiliary wrong, american way maybe?
anyway, i will let pics do the talking as whatever i say will not do it justice.
what more can i say, apart from im really looking forward to the rest of pics, and am deffo gonna pay for him to bring to me, not to post.
enjoy
Old 6th Oct 2010, 18:19   #58
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
I like tha space in there! Is that self portrait?
__________________
Razer2007 is offline   Reply With Quote
Old 6th Oct 2010, 18:39   #59
Dahl1n
Modder
Dahl1n has yet to learn the way of the Dremel
Just amasing paint jobb nice built to
Dahl1n is offline   Reply With Quote
Old 7th Oct 2010, 05:07   #60
PabloFunky
Ultramodder
PabloFunky's Avatar
Looks like in pics, its not laquered yet, i normally have to aprove, before laquering takes place, otherwise too late then obviously
The laquer will protect and bring out the gloss shine.
I think it may be a kinda self portrait, as i have met the artist, he may of based it on me?
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
