Reply
Thread Tools View Mode
Old 21st Nov 2010, 11:30   #81
paz45
Supermodder
paz45's Avatar
paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.paz45 is the Cheesecake. Relix smiles down upon them.
Great, panels been away long time, looking forward to saturday , pics pics pics
paz45 is offline   Reply With Quote
Old 21st Nov 2010, 11:31   #82
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
It'll be nice to see it all together.
bulldogjeff is offline   Reply With Quote
Old 21st Nov 2010, 11:38   #83
PabloFunky
Ultramodder
PabloFunky's Avatar
PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.
Because the case is prob more than 60kg? (infact ive damaged my desk lifting it onto it)im guessing, coz i cant lift it anymore hardly, im gonna have to take pics in situ, room is small.
I want to try take pics so it shows the artwork flowing ,
maybe i could take pics of panels separate on floor or laquered up?
Should run MSN and forums brilliantly now eh?
Gonna add some 2.5 bays on next internal structure for Monster3, im able to make/fabricate most things, but i feel things get spoilt once you go too arty farty..
I wanted quality/ cleanish looks.
Im hoping the artwork isnt to overkil, but wont know till its assembled.
Easy enough for me to now make panel kits, plain one for the week and artwork ones back on for the weekend.
Thing im most happy about is that i guessed mobos would get bigger, so made it as a 10 pci slot, prob whilst xl format was on drawing board still, although i initially labeled mine up as SEATX, still prefer that over XL.
PabloFunky is offline   Reply With Quote
Old 21st Nov 2010, 12:09   #84
bulldogjeff
60kg WTF have you made it out off..lol That thing weighs more than my Misses.
Old 21st Nov 2010, 12:12   #85
PabloFunky
Ultramodder
PabloFunky's Avatar
Im not a small bloke, and i lift quite alot at work sometimes, so pretty much 60 id say.
top panel 12mm ally
bottom panel 12mm ally
structure 1.5mm steel
side panels 3mm ally
front/rear 5mm ally
case is 680mm high 320mm wide 580 width
4 rads
liquid
mid plate 3mm ally
its massive
Old 21st Nov 2010, 12:36   #86
bulldogjeff
That makes sense when you say it like that. Thinking about it mine probably weighs getting on for 15kg, maybe more.
Old 21st Nov 2010, 13:01   #87
Mattmc91
Ultramodder
Mattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run Crysis
60KG is nothing Pete you wuss
Mattmc91 is offline   Reply With Quote
Old 21st Nov 2010, 20:16   #88
PabloFunky
Ultramodder
PabloFunky's Avatar
he he, yeah matt, i know, im not as young as some of you guys anymore.
not heavy as such, but for a pc i think it is, if i win them handles, would prob need m12 bolts to fix it well.
Old 27th Nov 2010, 15:28   #89
PabloFunky
Ultramodder
PabloFunky's Avatar
OMG, cant believe how much pics suck compared to the real thing,
the artwork came back today, its really shiny and big .
this is how it all lines up, gonna try take a few more pics, working on it at moment.
heres one for the moment.
Going to fit filports in top now and then assemble front again
hope some pics later or tomoz
Old 27th Nov 2010, 15:31   #90
bulldogjeff
Nice Pablo, that looks SWEEEEEET!!!
Old 27th Nov 2010, 15:59   #91
ringo
Supermodder
ringo has yet to learn the way of the Dremel
I like the artwork of your case. It looks fantasitc.
ringo is offline   Reply With Quote
Old 27th Nov 2010, 17:00   #92
PabloFunky
Ultramodder
PabloFunky's Avatar
Hes got it as my instruction, to allow planet to wrap oto top, perfect align.
when right panel fitted, youl get the full planet wrap
Even though artwork was expensive, i really am happy, shame im poor at photos, will try in daylight tomoz, to try show shiney.
im not putting on corner pieces yet, as i will remake from ss or get chromed, i need to add some pad at back of them to avoid scratching artwork.
this will allow me to fit side panels securly then
Thanks ringo and bulldog,
i didnt realise an artwork could be so big, yet still so detailed, i think when i retire, would be something id like to learn, maybe for Monster 10 ?
Old 27th Nov 2010, 17:41   #93
paz45
Supermodder
paz45's Avatar
Worth the long wait then pablo, he he forget the tape , put them side panels on
Old 27th Nov 2010, 17:43   #94
PabloFunky
Ultramodder
PabloFunky's Avatar
Thanks, cant risk it, it will rip up the laquer, no hurry, so can wait till i do it proper like.
and its warmer downstairs, so i can look at panels all night, and watch tv also.
Old 27th Nov 2010, 18:41   #95
PabloFunky
Ultramodder
PabloFunky's Avatar
ok , put corner piece on carefully,
still need some daylight pics, but this best i got at mo.
Old 27th Nov 2010, 19:08   #96
sixfootsideburns
modeteer
sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.
though the artwork isn't my favorite it is definitely amazing... all together its even more apparent just how outstanding it really is and how much time was dedicated to making it so. Congratz on this as it finally comes together mate!
sixfootsideburns is offline   Reply With Quote
Old 27th Nov 2010, 19:49   #97
PabloFunky
Ultramodder
PabloFunky's Avatar
mates already said about poor photos, but room is badly lit, im not good photographer etc.
thanks for comments though.
Old 28th Nov 2010, 02:22   #98
Monkey Puzzle
Multimodder
Monkey Puzzle's Avatar
Monkey Puzzle has yet to learn the way of the Dremel
60kg? 12mm panels? Why?! Is it built to survive small arms fire?
Btw, those steel corner brackets would blend in much better if they were black.
__________________
Project: Hush!
Monkey Puzzle is offline   Reply With Quote
Old 28th Nov 2010, 06:19   #99
PabloFunky
Ultramodder
PabloFunky's Avatar
right, ok black for corner brackets, noted.
12mm panels, so the edges can be milled away for the side panels to slot in, could of possibly done 8mm, but no 8mm ally in stock.
60kg, thats just what it worked out at.
Soon be light, hoping to take some better pics.
unless i invite everyone round to see it instead,(but not practical i think)
Old 28th Nov 2010, 06:35   #100
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
That really is some epic artwork.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
