Hardware Gigabyte GA-880GMA-UD2H Review
Discussion in 'Article Discussion' started by CardJoe, 24 Sep 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    At least it's a pleasure to look at.
    Somewhat pointless mb though, nowadays I'm only using AMD chips in budget builds for friends and relatives, and atm I think it's unnecessary to pay for USB3 and/or SATA6 in such scenarios. The money is better spent towards faster CPU.
  3. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    A floppy port on microATX board? Their typical response would be "but customers are requesting this feature". If I were a velociraptor I'd get some cheap second hand mobo instead of building a brand new PC to run DOS.
  4. lacuna
    lacuna Minimodder
    9 Aug 2004
    So you indentify that the board would be appropriate for an htpc and also point out that its highlights are the USB3 and SATA 6 ports and yet you test it with a 5870 and a normal hdd thus providing a review which only states the obvious: its not great for gaming.
    Excellent work.
  5. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    What I don't understand is that we're told the C300 (being the only drive to make use of SATA 6 atm) works loads better of the Rocket card. So that makes SATA 6 support rather redundant if you really want the extra speed of one of those drives.
    USB3 won't be mainstream for some time, and I only use the odd memory stick or card reader etc.
    So whilst it make, per se, make a board more "future proof", a don't really see a huge point.
    Am I missing something?
  6. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Nice review, although time for an article with a round-up of micro-atx boards , including best buys that are available for each platform. :)
  7. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
    I actually prefer to have the core unlocker option in BIOS as here than as a physical button on the MB. Maybe a button is a bit more newbie-friendly, but is in fact newbie-unfriendly if said newbie has to tweak settings for the core to be stable. The BIOS should act like a qualifying test, if you can use a friendly BIOS, you can be trusted with these advanced features.
    The only buttons I like on the MB are power, reset and clear CMOS (although, how hard is a bloody jumper?). I regard "Turbo" or OC knobs, switches and buttons as useless features.
    I'm thinking of adding it to my centrefold profile - Turnoffs: Pointless mobo gizmos.
  8. GreenGaucho
    GreenGaucho What's a Dremel?
    12 Jul 2010
    Bit-Tech editors,
    There's a typo in the pulldown menu. Page 7 reads "Gaming Perfromance."
  9. Krayzie_B.o.n.e.
    Krayzie_B.o.n.e. What's a Dremel?
    2 Aug 2009
    Nice Micro-ATX mobo for a HTPC but get rid of those dam IDE plugs.
    Nice review but here's the real highlight of this article.
    "Death Star PC that has the power to simultaneously end worlds and heal dying children"
    but if your PC could only do one, which one would you choose?
    After deep thought (15 seconds) I chose End Worlds.
  10. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    uh... what is wrong with half the people posting here? seriously, people are either complaining that it has old technology or complaining that it has new technology. if you don't like it, nobody is forcing you to buy it. so what if it has a floppy or ide interface, does it hurt anything? no. what else are you going to put in that particular location?
    and so what if it has usb 3 or sata 3. maybe someone just wants a budget board that supports those. if someone wants a cheap computer that will last them a long time, its pretty smart to buy a board like this and get new technologies. keep in mind that this is an amd board too. you can use some crappy dual core sempron and eventually upgrade to hex core phenom II whenever you can afford it.
    now, stop complaining about a product that is supposed to give less wealthy people a large selection of features.
  11. Adnoctum
    27 Apr 2008
    What a shocka! Call the tabloids! PC enthusiasts using a forum to express their...<GASP>...opinions and preferences.
    Welcome to the Internet, what took you so long?
  12. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    Kinda useful for installing WinXP - which would be a sensible choice for many performance-critical applications, though Linux would be better for most non-gaming purposes.
    As for USB 3.0 - one good reason for having it is for copying full image backups onto an external disk which could then be taken off-site. Such backups (including the whole hard disk) can be dozens, or hundreds, of GBs in size and USB 3.0's 400MB/s transfer rate would be preferable to USB 2.0's 60MB/s.
  13. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Future proof HTPC anyone?
    On-board Graphics,
    Perfect upgrade path for CPU's.
    Enough slots for ram.
    PCI-E for Updated graphics if needed in the future.
    SATA3
    Nowt wrong with this for a nice HTPC with the power to upgrade when needed.
    Regardless... i don't want a Earth Destroyer, i want a PC that can collapse a star.
  14. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    I stand by this and point out that sometimes having a mATX pc can make a difference, being a htpc, workhorse so it can be on 24/7 downloading and storing as also as a LAN gaming rig for being portable.
Tags: Add Tags
