Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Oct 2010, 08:24   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
Tt eSports Challenger Keyboard Review
http://www.bit-tech.net/hardware/per...board-review/1
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 3rd Oct 2010, 08:48   #2
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn has yet to learn the way of the DremelHourBeforeDawn has yet to learn the way of the Dremel
if they can have an upgrade to make the fan motorized and a little bigger then your all set for the summer =p but really I will stick with my G15.
__________________
Current Rig: Project STEALTH
• DimasTech Test Bench • Black ICE Triple 120 Rad • Dual Bay Res/Pump • DD Fill Port & Res • D-Tek FuZion 2 CPU Block • ASUS M3A79-T Deluxe Mobo • AMD Phenom II 3ghz @ 4ghz • 8gb DDR2-1100 Memory • (2) AMD 6870 XFire • (2) WD Black 640gb Raid 0 • (2) 1.5TB SEAGATE • Blu-Ray/HD DVD Drive • ASUS XONAR DX2 • 30" DOUBLESIGHT LCD • (2) 23" ASUS LCD • ZALMAN 8 FAN CONTROLLER • (4) NOCTUA P12 • (2) NOCTUA P14 • 1000W ZALMAN PSU • WINDOWS 7 PRO 64 •
HourBeforeDawn is offline   Reply With Quote
Old 3rd Oct 2010, 09:05   #3
xela333
Minimodder
xela333 has yet to learn the way of the Dremel
lol same old thermaltake crap They make some of the most god awful looking cases known to man. More to the point their R&D department seem to work vie a small room and a pair of binoculars, viewing the gaming world from some wierd perspective if that makes any sense at all.
xela333 is offline   Reply With Quote
Old 3rd Oct 2010, 14:55   #4
pimonserry
sounds like a party.
pimonserry's Avatar
pimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremelpimonserry has yet to learn the way of the Dremel
Basically, you're better off with air conditioning and a better keyboard.
__________________
I'm a student, any money I might possibly have is not mine.
+REP ME FOR BEING WONDERFUL
pimonserry is offline   Reply With Quote
Old 3rd Oct 2010, 16:28   #5
SlowMotionSuicide
Come Hell or High Water
SlowMotionSuicide's Avatar
SlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for president
Tt eSports is a new name in the gaming peripheral market, but as it's an offshoot of the more established Thermaltake brand, we were expecting good things.
Please tell me you're joking.
__________________
G3258 @ 4.3GHz | MSI Z97 Gaming 5 | 8Gb Dominators | GTX 660 | Crucial MX100 256GB | F1 Spinpoint 1TB | Seasonic P-760 (XP²) | NZXT H440W
SlowMotionSuicide is offline   Reply With Quote
Old 3rd Oct 2010, 19:36   #6
Farting Bob
Supermodder
Farting Bob's Avatar
Farting Bob has yet to learn the way of the DremelFarting Bob has yet to learn the way of the DremelFarting Bob has yet to learn the way of the Dremel
The amount of air that fan likely moves youd get cooler hands by just occasionally blowing on them yourself, in between headshots.
Farting Bob is offline   Reply With Quote
Old 3rd Oct 2010, 19:57   #7
Lockon Stratos
I Will Snipe You!
Lockon Stratos's Avatar
Lockon Stratos has yet to learn the way of the Dremel
I dont think it would be too difficult to mod a 120mm fan to it - but do realise that the fan will draw a maximum of 5v from the USB - which is roughly a bit of a breeze on a 120mm
Lockon Stratos is offline   Reply With Quote
Old 4th Oct 2010, 03:44   #8
PopcornMachine
Snacker
PopcornMachine has yet to learn the way of the Dremel
A hand fan? That's just insulting.
PopcornMachine is offline   Reply With Quote
Old 4th Oct 2010, 14:38   #9
Bungletron
Ultramodder
Bungletron's Avatar
Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.
I am still rocking an aluminium Thermaltake Tsunami Dream case from way back and am constantly on the lookout for good upgrades so I must agree that other than the frio cooler surely they have done nothing worthwhile for a while, it does all seem to be rather bizarre.
Bungletron is offline   Reply With Quote
Old 4th Oct 2010, 16:02   #10
Zayfod
Multimodder
Zayfod's Avatar
Zayfod has yet to learn the way of the Dremel
We'd have preferred a few standard-sized dummy keys to blank off other annoying keys, such as Insert.
Since when is Insert of all things an annoying key?
__________________
A voice of reason... mainly ignored...
Deviant Art Gallery
Tyan Tiger K8W, dual AMD Opteron 240, 3Gb Ram. Dual core, the old fashioned way!
Zayfod is offline   Reply With Quote
Old 4th Oct 2010, 17:30   #11
HandMadeAndroid
That's handy.
HandMadeAndroid has yet to learn the way of the DremelHandMadeAndroid has yet to learn the way of the DremelHandMadeAndroid has yet to learn the way of the Dremel
More land fill crap
__________________
i7 3770k, Asus P8Z77-I , 16gb Patriot 1866 ddr3,EVGA 670FTW, Bitfenix Prodigy,crucial M4 128ssd,western digital black 2tb storage, wacom intuos/ i7 sandy bridge kobalt 17" laptop,120ssd, 8gb crucial ram, 500gb7200 WD storage drive, nvidia 555m 3gb/64gb iPad 2
HandMadeAndroid is offline   Reply With Quote
Old 4th Oct 2010, 18:56   #12
b5k
Multimodder
b5k has yet to learn the way of the Dremel
Okay, so here's the Revision v2.0: MOUNT THE FAN INSIDE THE KEYBOARD AND HAVE SOME DUCTING TO FUNNEL IT UP THROUGH THE KEYS!
Jesus, you just bolt a fan to the top of a keyboard? What sort of bollocks is that...
b5k is offline   Reply With Quote
Old 4th Oct 2010, 20:58   #13
HourBeforeDawn
a.k.a KazeModz
have you ever accidently hit it and whatever you were typing erased what was in front >.< thats annoying.
__________________
Old 5th Oct 2010, 11:57   #14
Abhorsen
Hypermodder
Abhorsen's Avatar
Abhorsen has yet to learn the way of the DremelAbhorsen has yet to learn the way of the DremelAbhorsen has yet to learn the way of the Dremel
I saw this at i40, i was like, a fan, seriously?
Would love to see a review of the Razer Blackwidow released yesterday.
__________________
None found.
Abhorsen is offline   Reply With Quote
Old 6th Oct 2010, 19:47   #15
SMIFFYDUDE
Supermodders on my D
SMIFFYDUDE's Avatar
SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.
People will literally think your a w@nker if they see this keyboard on your desk.
__________________
i7 6700K|Sabertooth Z170 S|16GB Crosair Dominator Platinum 3200MHz|KFA2 GTX 1080 HOF|Creative Sound Blaster ZxR|Super Flower Leadex Gold 850W|Corsair 780T|HP LP2475w|Speedlink Medusa 5.1|CM Storm Inferno|Windows 10
Steam: SMIFFY
SMIFFYDUDE is offline   Reply With Quote
Old 7th Oct 2010, 14:23   #16
Bungletron
Ultramodder
Bungletron's Avatar
Ah, the niche market, clever.
Old 7th Oct 2010, 22:42   #17
Canon
Reformed
Canon's Avatar
Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.Canon is the Cheesecake. Relix smiles down upon them.
What.....seriously? Am I imagining this or am I looking upon a keyboard with a fan on it? (which by the way looks like an afterthought)
It looks like a Razer Arctosa knock-off with a slightly different colour scheme, less buttons and a fan slapped on the top of it.
My case sits next to me on my desk, the little amount of air that escapes that is probably 10x the amount that would come into contact with my hand from that fan.
__________________
Canon is offline   Reply With Quote
Old 7th Oct 2010, 23:00   #18
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
That's exactly what I thought when I read that. Since when have Thermaltake been a company to expect good things from?!
I built my brothers new gaming PC at the time in one of those about 2-3 years ago, and it wasn't all that horrible a case at the time, but it was still pretty cheap and cheerful. He still has it, gave it to his wife when he bought a new PC earlier this year. "CoolAll your life" seriously? That's the stupidest company slogan I've ever heard. And since you've mentioned the Frio I'll add this - I bought one last week to put in my overclocked i7 920 system because I was a bit sick of the plain Jane looks of the standard Titan Fenrir. I bought it purely based on the CPC review where it won a premium award. I amost bought a Coolermaster V8 instead, but it was out of stock. Anyway, the Frio arrived and I fitted it to my EVGA X58 classified motherboard. Several things to note.
- Too "plasticky". no need for it, it could be a great cooler but the quality, as always, is just not there.
- Wonky fins. If I take the fans off it and look at the angle of the fins in relation to the vertical heatpipes, it's blatantly obvious that every fin in the thing is mounted at an angle. Again, no build quality.
- Manual speed adjustable fans. Really? 3-pin fans with manual potentiometers on them instead of a PWM fan, since practically every motherboard worth anything these days has a PWM CPU fan header. Rubbish - I've already ordered a pair of PWM fans and a splitter for them so I can plug them into the motherboard header and have them controlled by the system, like they should be.
- It's too big. Yeah, bigger is more effective, but this thing actually hits the chipset heatsink fin array on my EVGA motherboard. It fits on the board by the skin of it's teeth. And this is a larger than normal board... I dread to think how many boards there are that it will not fit.
Sure, it's an improvement over previous Thermaltake coolers, and a step in the right direction... it may even be the most effective cooler when you compare it degree by degree to all the other coolers on the market, but IMHO Thermaltake still can't design and manufacture high quality components... just cheap, plasticky crap. I'm picking up a V8 for this machine as soon as they come back into stock at Scan.
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Old 7th Oct 2010, 23:06   #19
Canon
Reformed
Canon's Avatar
I built my brothers new gaming PC at the time in one of those about 2-3 years ago, and it wasn't all that horrible a case at the time, but it was still pretty cheap and cheerful. He still has it, gave it to his wife when he got a new one earlier this year. "CoolAll your life" seriously? That's the stupidest company slogan I've ever heard. And since you've mentioned the Frio I'll add this - I bought one last week to put in my overclocked i7 920 system because I was a bit sick of the plain Jane looks of the standard Titan Fenrir. I bought it purely based on the CPC review where it won a premium award. I amost bought a Coolermaster V8 instead, but it was out of stock. Anyway, the Frio arrived and I fitted it to my EVGA X58 classified motherboard. Several things to note.
Their staff are very dedicated too! An e-mail sent about a month ago to inform them of a pretty silly typo in the advertisements for their new 'Armor' case range, got a reply telling me it had been forwarded to that department manager to then be passed on further until it was resolved. Couple of weeks down the line I get an e-mail from the UK representitive telling me that it had been fixed and they were very thankful and was given a telephone and e-mail to contact them.
Next week, ads had been dished out again.......same typo. I have to agree on 'CoolAll your life' it's more ridiculous crap that these low quality companies come off with, I think the fact that they havn't come up with anything good is down to the fact that they're so tight they're employing staff that are responsible for marketing that can barely operate a keyboard (probably the same to develop this garbage) and have little grasp of the English language, an essential for advertising in any region.
p.s having an upper and lower case 'T' (Tt) on my keyboard in bold red would annoy the **** out of me.
__________________
Old 7th Oct 2010, 23:20   #20
Unicorn
Unicorn's Avatar
Having an upper and lower case "T" on my CPU cooler does annoy the **** out of me.
Like I said, the V8 is a-comin'.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
