Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Oct 2010, 15:59   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
Samsung announces 1ms monitor
http://www.bit-tech.net/news/hardwar...-1ms-monitor/1
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 5th Oct 2010, 16:21   #2
Loafers
What's a Dremel?
Loafers's Avatar
Loafers has yet to learn the way of the Dremel
I doubt most consumers would be unable to differentiate between a 2 and 1ms monitor in a double blind test.
Loafers is offline   Reply With Quote
Old 5th Oct 2010, 16:29   #3
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run Crysis
Of course they wouldn't. IIRC, tests demonstrate unless you're looking at two images that really contrast (like a full black and full white screen), no body can notice something that quick.
Think about it - a response time of 0.001 seconds versus 0.002 seconds. It's pointless.
__________________
Intel Core i5-2500K | 8Gb Corsair Vengeance DDR3 1,600 Mhz
Gigabyte Geforce 460 GTX OC 1Gb | 1Tb + 1.5Tb Samsung Spinpoint F3 | Asrock Z68 Extreme4
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 5th Oct 2010, 16:43   #4
danielleil
Can't stop spending...
danielleil has yet to learn the way of the Dremel
Sounds like old news, I live in China and bought one of these from www.newegg.com.cn back in May. Cost worked out to around 250 quid and it is a great monitor.
__________________
i7 5960X @ 4.5GHz 1.25v. Asus Rampage Extreme, 2 x GTX 770. Corsair AX1200i. 1tb Samsung Pro.
danielleil is offline   Reply With Quote
Old 5th Oct 2010, 16:52   #5
Showerhead
Ultramodder
Showerhead's Avatar
Showerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run Crysis
I assume this is still a grey to grey transition. If not it's impressive I've never seen a black white black transition go anywhere below 5ms
Also Viewsonic beat them to it
Showerhead is offline   Reply With Quote
Old 5th Oct 2010, 17:22   #6
SMIFFYDUDE
Supermodders on my D
SMIFFYDUDE's Avatar
SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.
Nobody will notice the benefit of 1ms responce time over 2ms in real life. I'd prefer manufacturers get back to making reasonably priced 24" monitors with 1920x1200 resolution instead of slicing an inch of screen off with 1080 res.
__________________
i7 6700K|Sabertooth Z170 S|16GB Crosair Dominator Platinum 3200MHz|KFA2 GTX 1080 HOF|Creative Sound Blaster ZxR|Super Flower Leadex Gold 850W|Raijintek Triton|Corsair 780T|HP LP2475w|Speedlink Medusa 5.1|CM Storm Inferno|Windows 10
Steam: SMIFFY
SMIFFYDUDE is offline   Reply With Quote
Old 5th Oct 2010, 17:32   #7
azrael-
I'm special...
azrael-'s Avatar
azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!
As long as it's still a 60Hz TN panel this isn't really interesting. Give me a 120Hz xVA or IPS panel with LED backlighting and I'll get excited.
__________________
It's not the end of the world ...but you can see it from here.
Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA
azrael- is offline   Reply With Quote
Old 5th Oct 2010, 17:34   #8
cgthomas
Cpt. Handsome
cgthomas's Avatar
cgthomas has yet to learn the way of the Dremel
What's the refresh rate?
Will it shatter the image ghosting barrier in 3d?
__________________
Iím an AquaTuning product tester - I am........ honestly
cgthomas is offline   Reply With Quote
Old 5th Oct 2010, 17:38   #9
The_Beast
I like wood ಠ_ಠ
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
meh
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 5th Oct 2010, 17:55   #10
Teelzebub
Up yours GOD,Whats best served cold
Teelzebub's Avatar
Teelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming Saiyan
Originally Posted by The_Beast View Post
meh
+1
__________________
bt was once a great and vibrant forum wtf happened to it? , there must be a Hex on us back to mediocrity Get back under your bridges you scummy Troll's and STFU Mountain mods case, Enermax 1250w PSU, Asus Maximus V Extreme, i7 3770k @ 14.6ghz, Samsung 840 250gb SSD. 500gb Seagate,Corsair H80i wind tunnel, 16gb Corsair Vengeance pro 1866mhz,4xEVGA GTX 670 quad SLI 2 x Dell U27" @ 2560 x 1440, 4 bags of weed
Teelzebub is offline   Reply With Quote
Old 5th Oct 2010, 18:00   #11
PabloFunky
Ultramodder
PabloFunky's Avatar
PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.
Why is it that even a 1ms response time seems way worse than a 0ms response of a crt?
Im assuming its because a crt is a raster scanning device ?
Still waiting for the day when we have a thin tft screen with the spec of a crt, i know its getting close, but were deffo not there yet.
I assume theres many gamers on here that still swear by a crt?
PabloFunky is offline   Reply With Quote
Old 5th Oct 2010, 18:05   #12
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
ah, my eyes! it's TN!
i'll take IPS over TN any day, even if it's 1ms vs 10ms advertised speed.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 5th Oct 2010, 18:32   #13
B1GBUD
More Biddy Bang Bang than Sean Paul
B1GBUD's Avatar
B1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming Saiyan
Wake me up when they can offer a decent resolution, a 27" panel should be 2560 x 1440.
__________________
Teh unofficial Bit-Tech proof reader
Originally Posted by Teelzebub View Post
( Kid you dont want either only bud is any good lol )
B1GBUD is offline   Reply With Quote
Old 5th Oct 2010, 18:55   #14
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
you don't get it.. crt not only lag free it can display 120fps while it's at it- the new generation have no clue and they get tossed like a salad against a good player on a crt
thehippoz is offline   Reply With Quote
Old 5th Oct 2010, 19:43   #15
wuyanxu
wuyanxu's Avatar
Dell U2711?
Apple 27 inch?
and may be Hazro HZ27Wa?
__________________
Old 5th Oct 2010, 20:27   #16
chrisb2e9
Dont do that...
chrisb2e9's Avatar
chrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysis
I miss having a crt... such quality images. Too bad the "good" monitors we have these days just can't compare.
__________________
life can evolve without begetting plants or birds or cuddly mammals or sentient beings who write blogs on the internet; it just begets a glob of ooze.
chrisb2e9 is offline   Reply With Quote
Old 5th Oct 2010, 20:33   #17
NethLyn
Hypermodder
NethLyn's Avatar
NethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for president
Well I do, just because I've concentrated on the internal upgrades and the budget meant I wasn't gaming over 12 x 10 for a long time. So my first flatscreen wouldn't be for gaming, more just the web and general windows if I could get a good deal.
__________________
Intel=Fast, AMD=Cheap.
Member of Preys-World.com? Normal forum resumed, visit below:
forum.preys-world.com
NethLyn is offline   Reply With Quote
Old 5th Oct 2010, 21:09   #18
knuck
Hate your face
knuck's Avatar
knuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on youknuck - may the hammer of Bindi be bestowed on you
1ms or not, at 60hz it will still be full of tearing
__________________
| Intel i7 4770K | 12GB DDR3 2000 | Asus Maximus VI Hero | GTX 980 | Samsung 840 Pro 256GB | 10.5TB total | Seasonic X-1250 | Auzentech Bravura X-Fi | Fractal Design Define R3 XL | Corsair H50 | BenQ XL2420T 120Hz |
knuck is offline   Reply With Quote
Old 5th Oct 2010, 21:34   #19
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
LCD will always have that "laggy" problem, even if is 0ms !
You read me right, ZERO ms!
Gradius is offline   Reply With Quote
Old 5th Oct 2010, 22:33   #20
Burdman27911
Modder
Burdman27911 has yet to learn the way of the Dremel
Originally Posted by Samsung
creative professionals and computer gamers seeking the best possible viewing experience will immediately appreciate its benefits.
I highly doubt it. It likely also uses a TN panel with overdrive to achieve the 1ms response time, so it'll have artifacting instead of the "ghosting" which I even find to be worse...
Marketing win = consumer loss all around.
Burdman27911 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
