News AMD Radeon HD 6870 leaked
Discussion in 'Article Discussion' started by CardJoe, 8 Oct 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    want it now kthnx.
  3. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    I'll wait for a Bit-tech benchtest as the rumours all over the place are either written by fanbois or are just too conflicting to get any sense out of them.
    When will you be getting your hands on them Bit-Tech? "Wink! Wink!, say no more!"
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    I seem to remember they already have one, but under non-disclosure!
  5. the_kille4
    the_kille4 Chaos will rule da world.eventually
    28 Aug 2009
    hmmm... I'll wait for the cayman...
    right now I own a 4870... its good enough now... and although it would be two generations behind the 6000 series... i will just wait till the 7s come out,
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    hum.... eyespeed?!?
    when will they simply put normal displayport on it? i had been looking around, and it seems i need to buy £16 adaptor just to use the normal displayport cable provided by Dell. interestingly, £5 for mini-DP to DP cable.
  7. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Juicy! Looking forward to seeing what these cards can do.
  8. azrael-
    azrael- I'm special...
    18 May 2008
    This sounds wrong. A far as I know the "XT" moniker betters the "Pro" moniker. Also, Barts is supposed to be the 67xx series.
    Well, I suppose we'll all find out really soon. Isn't there a press conference scheduled for 12 October 2010 or something?
  9. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Some say they do have the ability to use 5 monitors at once, instead of 3... basically, we have too much power and fast hardware for the software ... We need new consoles to see if we can have better graphics :(
    (not counting on poor optimized games like Crysis, Stalker, and Metro2033)
  10. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    There is an ATI event on Oct 14th in LA if thats what your thinking of, of cause the release date is still claimed/set to be the 12th.
  11. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    http://www.chiphell.com/thread-128230-1-1.html
  12. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Looking forward to the reviews.
  13. azrael-
    18 May 2008
    I find this a lot more dubious than the slides that circulated a couple of weeks ago.
  14. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    I'll have one please! Hope the prices on there are competitive... and there's some nice waterblocks available soon. Otherwise I can hopefully pick up a 5870 cheap.
  15. tzuri
    tzuri What's a Dremel?
    8 Oct 2010
    The way i read it from
    HD 68XX cards will be based on the XT and Pro Barts chips...
    So far XT is the top chip (dont think AMD will rebrand the Hierarchy in their chips)...
    The part of the article where XT is this, Pro is that - is speculation... based on a misread post...
    CHeers
  16. blohum
    blohum What's a Dremel?
    3 Mar 2010
    Indeed, we really need a new game that pushes the existing cards... I have the 4870 too and can play pretty much anything on it hence can't justify spending £300 on a 5870.
  17. Ajhayter
    Ajhayter What's a Dremel?
    10 May 2010
    Thats my plan as well. I upgraded my CPU to an i7 920 from an E8400, and got a board with SATA3 and USB3 (Asus P6X58D-E) with the idea to upgrade the graphics at a later date. In theory I have a machine that I won't need to actually upgrade for 5 or more years, with a little overclocking.
  18. Hustler
    Hustler Minimodder
    8 Aug 2005
    I have a 1Gb 4850 that cost me £75 in july 2009, and thanks to the wonderful world of DX9 console ports (he says in a sarcastic manner)...i have yet to find a game i cant play at very high frame rates with the settings mostly maxed out....
    I have decided i am not going to upgrade my GPU until i know what the requirements are for the only game im interested in 2011....Battlefield 3.
    At £75, the Radeon 4850 is turning out to be the best value Gfx card i have EVER owned.....
  19. GoodBytes
    20 Jan 2007
    what worries me is that the heatsink vent output is so small... that means that the air circulation will be less and the air itself passing through a smaller whole will produce more noise. They should use 1 connector with ana adapter that split into 2 DVI's instead. Ir an expansion card or something.
  20. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    Well picture looks like photoshoped 5970, he, he.
    More seriously. I will wait for reviews and non-reference cooling. Reference VGAs are only for peps going with water cooling.
Tags: Add Tags
