Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 12th Oct 2010, 19:13   #1
Baetucious
What's a Dremel?
Baetucious has yet to learn the way of the Dremel
Pins on my 1366 motherboard are not aligned? Help!
I have just bought all the hardware to build a new PC from Scan. After opening my Motherboard (A gigabyte X58A UD3R rev 2), and taking off the protective hard peice of plastic which covers where the CPU goes, I immediatly noticed that three pins are slightly bent.
I tried placing my CPU (a i7 930) on top, and it seemed to wobble around a little, and the latch would not sit confortably on top of it, in fact, the latch is actually quite a bit higher than it should be.
I do have scansure, so if this is really bad I will have to contact them to get it fixed, but I'm just asking with one final hope that this may be fixable or normal?
Any ideas guys? Thanks a bunch,
Bill.
Baetucious is offline   Reply With Quote
Old 12th Oct 2010, 19:41   #2
Teelzebub
Satan the one true God / Modarator
Teelzebub's Avatar
Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.
It should take a little bit of pressure to lock in the cpu. I would get the system built and see what happens.
If you are really concerned give Scan a call.
Mabe take a pic of the socket and email it to scan.
Dont try to fix it yourself.
__________________
Before buying from someone on the MP please read the rules and the Problematic sales on the Market Place http://forums.bit-tech.net/group.php?groupid=86
A large wooden box with screws, nails and a condom in it just to be on the safe side, All over clocked to the max I'm not boasting really I'm not
Teelzebub is offline   Reply With Quote
Old 12th Oct 2010, 19:44   #3
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.
You noticed that 3 Pins are bent on the CPU? Or something on the MB is bent?
Every computer that i have put together after you raise the latch the CPU should drop right in no resistance or fuss just drop right in. If there are pins bent on the CPU I personally would send it back no telling what happened prior to you receiving the CPU. i.e. it was dropped/mis-handled somewhere. But that's just my personal thinking if its not 100% right especially something that important i would send it back instead of taking the chance of something going wrong later and someone claiming that you bent the pins.
__________________
Originally Posted by Deders View Post
What if you touch yourself with kittens?
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is offline   Reply With Quote
Old 12th Oct 2010, 19:48   #4
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for president
He's tslking about LGA sockets, so the pins are on the motherboard... I'd RMA the **** out of it personally...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Sapphire Radeon HD 5870, 128GB Crucial M4, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 12th Oct 2010, 19:49   #5
Teelzebub
Teelzebub's Avatar
LOL you dont have pins on a i7 they are in the socket which is what the OP is saying looks bent.
Phone Scan mate, Remember if you RMA it and there's nothing wrong you will be charged a fee.
__________________
Old 12th Oct 2010, 19:49   #6
smc8788
potato
smc8788's Avatar
smc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on yousmc8788 - may the hammer of Bindi be bestowed on you
Scansure or no Scansure, if the motherboard arrived with broken pins I'd be sending it back straight away...
__________________
My Rig: [FD Define Mini] - [Asus P8Z77-M Pro] - [i5 2500k @ 4.4GHz/1.34V] - [Corsair H60] - [8GB Corsair Vengeance LP] - [Asus GTX TITAN] - [512GB Vertex 4, 1TB F3, 2TB F4 x 2] - [Corsair HX650]
Other stuff I own: [BenQ XL2411T] - [HHKB Pro2 Type-S] - [Zowie EC1] - [Sennheiser HD800] - [Audez'e LCD2 rev. 2] - [Woo Audio WA7 Fireflies] - [Philips 46PFL9705H] - [Onkyo TX-NR515] - [B&W 685]
[Steam] - [Battlelog]
smc8788 is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
