News ViewSonic launches 24in 3D monitor
Discussion in 'Article Discussion' started by CardJoe, 15 Oct 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. runadumb
    runadumb What's a Dremel?
    20 Jan 2010
    The AMD certification makes me wonder why it's missing a display port. When will we get a 20-24inch eyefinity capable (dedicated stand) 3D IPS (or e-IPS) 1920x1200 monitor?
    Lol I'm asking for way to much aren't I? Should probably throw OLED into that mix too with all the likely hood of that spec coming anytime soon.
    Any solid monitors coming into the bittech offices in the near future? And no I don't count this.
  3. enciem
    enciem Minimodder
    23 Sep 2009
    I've always thought that I'd never be interested in 3D until they lose the glasses. Somehow I think wired glasses is going in the wrong direction, they'll be a joy when paired with a set of headphones as well.
  4. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Toshiba is working on a 3d screen that wont require wearing any form of glasses when that goes mainstream then you will really see 3d take off.
  5. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    ...And probably not until. It's what would persuade me ot think about investing in the tech.
  6. runadumb
    20 Jan 2010
    Remember that 3D screens also run at 120hz. Even if you don't give a flying F about the 3D you get 120hz on your monitor. No downside
  7. enciem
    enciem Minimodder
    23 Sep 2009
    ...but the compensation for what are basically weak sunglasses in the color reproduction makes the screen rubbish for 2D usage
  8. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    wired glasses doesnt seem a bad idea to me, as most peeps are sat within a foot and a half of their monitor, and it saves on adding infrared tr/rcvr, maybe they could tie it in with some headphones :)
  9. Woodspoon
    Woodspoon What's a Dremel?
    10 May 2008
    Still think all this 3d stuff is just a gimmick to get people buying untill they come up with something better to flog.
  10. wyx087
    wyx087 Multimodder
    15 Aug 2007
    agree, £300 for a 1080p monitor? no thanks, i'd rather spend a bit extra for a IPS monitor at 1920x1200
  11. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Agree with this. Normal HD TV's and monitors are getting cheaper and cheaper and they need something to tout as 'the next big thing'. Unfortunately, i don't think 3D is it (certainly not with the current technology limitations).
  12. Disco
    Disco What's a Dremel?
    16 Oct 2010
    Many find the pros outweigh the cons for 2D gaming.
    120Hz monitor
    Pros
    Virtually no input lag.
    Less trailing on motion (more frames means less of the sample and hold effect)
    More responsive and smoother (due to having more images 120 per second rather than 60 per second)
    Cons
    Black levels can't match IPS
    Colour reproduction can't match IPS
    Poor viewing angles
    A 120Hz IPS would be the best of both worlds.
  13. Grape Flavor
    Grape Flavor What's a Dremel?
    23 Sep 2009
    good thing no one's forcing us to buy them then.
  14. leveller
    leveller Yeti Sports 2 - 2011 Champion!
    1 Dec 2009
    Will be good to see this in action, hope I get a chance.
    But I won't be buying until they hit 27 or 30"
  15. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Am I right in my assumption that 3D requires a much higher Hz to work? What is the minimum requirement for the AMD and Nvidia 3D cards?
    If it is just the Hz side which holds it back, then why can't I use my 600Hz LG non-3D Plasma as a monitor with a compatible GFX card and 3D glasses?
  16. JA12
    JA12 What's a Dremel?
    3 Mar 2010
Tags: Add Tags
