News Rumour control: ATI Radeon HD 6970 benchmarked
Discussion in 'Article Discussion' started by Claave, 25 Oct 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    I already have enough trouble fueling my car, I don't want to fuel my PC too...
  3. wyx087
    wyx087 Multimodder
    15 Aug 2007
    but 1GB isn't enough. nVidia's 1.5GB or rumoured 2GB gtx580 makes more sense.
    at least for the resolution i will need it to run: 2560x1440.
  4. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    As always, I feel it best to wait for the Bit-Tech benchtests and not rely on third or fourth party reporting.
  5. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    But isn't the 6970 a dual gpu card?
    Every benchmark I've seen that show the 2gb results etc seem not to make a difference, so i beg to differ.
    I run perfectly fine at 5040x1050 with a single 5870.
  6. digitaldunc
    digitaldunc What's a Dremel?
    4 Oct 2010
    This more like it.
    If this is true I'm potentially sold...
    Going to rival GF100 for heat, then?
  7. wyx087
    wyx087 Multimodder
    15 Aug 2007
    can you run BFBC2 at that resolution with 4xAA? can you run Crysis max with any level of AA?
    im not sure if it's GPU underpowered or not enough memory, but fact is my 5870 struggles.
  8. nightblade628
    nightblade628 Minimodder
    10 Dec 2009
    This is the card I've been waiting for, but not until the GTX 580 is released to see which is faster and how fast the competition brings the prices down.
  9. Unknownsock
    13 Jul 2009
    I don't use AA for obvious reasons. But i can't say too much as I'm currently bottlenecked by my cpu.
    I've yet to see a benchmark were more than 1gb actually makes a difference with top end resolution.
    And i would have thought it would be the gpu underpowered in general.
  10. Goty
    Goty Minimodder
    13 Dec 2005
    AA performance is bandwidth limited, usually, whereas memory capacity has more to do with resolution scaling.
  11. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I find it unlikely AMD would release new top end cards that didn't beat the 480. So the results might be legit. But they don't really mean anything. It's all about the official benchmarks!
  12. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    6xxx series need to succeed fast. GTX580 and/or other Fermi-refresh could wipe the floor with 6xxx. Unfortunately for AMD, people will wait for GTX580.
    nVidia did it before when initial chip was in general rushed/badly designed and refresh outperformed competition. It is not a secret that Fermi was rushed like mad. And while GTX480 is noisy and power hungry there is plenty of potential in this chip. nVidia just need to clean-up mess they created. If these numbers for 6970 are anything to go by, then I'm absolutely certain that Fermi refresh will beat them easily in synthetic benchmarks.
  13. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    "the 1GB GDDR5 model, has performed admirably in the 3DMark Vantage test suite, scoring 23,499 3DMarks in Performance mode."
    It's those last three words that detract from those results.
  14. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    GTX580 has been rumoured to be merely 20% faster than the GTX480, so...
  15. Paradigm Shifter
    10 May 2006
    Try 6064x1200 or higher... and try turning details up. :) I found that frequently on 1GB cards pushing settings one notch too high resulted in large framerate drops as the cards ran out of VRAM. 2GB cards make a big, big difference between playable and unplayable at the more extreme Surround/EyeFinity resolutions. At least on GTX460 cards. I've not had the chance to play with ATi cards... and they're supposedly better at VRAM management so it might not have quite such the same impact.
    Only partially. Use Afterburner and a Logitech G15 to watch VRAM usage on cards with enough VRAM, and you'll see 4xAA push VRAM usage up tremendously.
    edit: For those interested in 1GB vs. 2GB in Surround...
    http://www.overclock.net/nvidia/801683-surround-gaming-nvidia-gtx460-mainstream-card.html
  16. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    "can you run BFBC2 at that resolution with 4xAA? can you run Crysis max with any level of AA?
    im not sure if it's GPU underpowered or not enough memory, but fact is my 5870 struggles."
    Now, now ...naughty, naughty! The "but can it play Crysis?" question is one deemed nolonger relevant by Bit-tech and so is no longer asked nor answered!
  17. mi1ez
    mi1ez Modder
    11 Jun 2009
    Looking forward to seeing proper figures. As has been said, it would be nice if they release a version with more VRAM, especially with AMD pushing Eyefinity.
  18. faugusztin
    11 Aug 2008
    No. That will be HD6990.
    HD6990 = high end dual chip
    HD6970/HD6950 = high end single chip
    HD6870/HD6850 = high mainstream single chip
    HD6770/HD6750 = mainstream single chip
    HD66xx = high lowend/low mainstream single chip
    The rest is lowend.
  19. exceededgoku
    exceededgoku What's a Dremel?
    19 Oct 2006
    As above HD6990 (Antilles) will be the high end dual gpu card (not sure if it will be dual chip or dual card)...
  20. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    hmm ya I think I will go with two 6870 then since it will be more then enough for the current market of games and most likely for a while with the norm being ported console games to PC.
Tags: Add Tags
