#1 |
Supermodder
GPU3 console client?
I just started folding on Zotac GTX 470 AMP and I'm wondering, there's a GPU 3 systray client (I'm running it now, but is there a Windows GPU 3 console client? I'm used to see the progress and now I have to start this silly viewer. And second question, if there is a console client, is there any performance difference? Right now PPD shows in about 12500 PPD.
Thanks for the help. |
#2 |
Needs more dragons and stuff.
http://foldingforum.org/viewtopic.php?f=24&t=14671
Only for Vista and XP at the moment. Windows 7, stick with the system tray client. |
#3 |
AKA ZombieKiller1
The 'Vista' console client works perfectly on Win7, it just isn't specified.
__________________
#4 |
Supermodder
Thanks guys, I think I'll stick with tray for now. Seems performance about 13K is usual for that car anyway
#5 |
AKA ZombieKiller1
There would be no performance difference, to view the clients use Fahmon or HFM.NET then you dont need to use the 'viewer'. Its been that long since I used a systray client I can't really remember much other than that they are unnecessary in my opinion.
__________________
| Tags |
| client, console, gpu 3 |
| Thread Tools | |
