Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 2nd Nov 2010, 12:51   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
VIA Nano Dual-Core Preview
VIA's first ever multi-core CPU part: its aptly dual-core Nano platform, gets a grilling on our test
http://www.bit-tech.net/hardware/cpu...core-preview/1
Claave is offline   Reply With Quote
Old 2nd Nov 2010, 12:54   #2
yakyb
i hate the person above me
yakyb's Avatar
yakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysis
have had a glance read over this and looks fairly promising, will there be further reviews once ITX versions are availible
yakyb is offline   Reply With Quote
Old 2nd Nov 2010, 13:40   #3
Bungletron
Ultramodder
Bungletron's Avatar
Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.
looks half decent if they can get th video optimisation and pricing right
Bungletron is offline   Reply With Quote
Old 2nd Nov 2010, 14:13   #4
V3ctor
Tech addict...
V3ctor's Avatar
V3ctor has yet to learn the way of the Dremel
It's a great product, but it should come up earlier... When AMD unleashes it's Zacate cpu/apu, it will totally kill this VIA... I don't know how VIA can survive for much longer.
__________________
Main: Intel Core i7 4770K@4.5Ghz / ASUS Sabertooth Z87 / 2x4Gb Gskill Trident X 2400Mhz / MSI GTX 750Ti 2Gb GDDR5 / Samsung T260 / 2x Corsair Force GT 240Gb raid0/ Corsair HX-850W/ Silverstone FT02R-Wi
Laptop: Intel Core i7 4790K 4-4.4Ghz / 8Gb DDR3 1600Mhz / nVidia GTX 980M 8Gb GDDR5 / Samsung SSD 256Gb XP941
Hobby: AMD Opteron 175 / ASUS A8N-SLi SE / 3Gb DDR400 / ATI HD4850 512Mb GDDR3 / Crucial M550 128Gb M2
V3ctor is offline   Reply With Quote
Old 2nd Nov 2010, 14:24   #5
SaNdCrAwLeR
Multimodder
SaNdCrAwLeR has yet to learn the way of the Dremel
are you certain? it's AMD we're talking about... the days when they showed awesome stuff to the consumer is long gone (well in the CPU marketplace anyway)
SaNdCrAwLeR is offline   Reply With Quote
Old 2nd Nov 2010, 15:17   #6
xaser04
Ba Ba Ba BANANA!
xaser04's Avatar
xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.
It looked promising right up until I read this:
Originally Posted by article
General CPU performance might be firmly ahead of Intel's Atom, but it falls short of the CULV Core 2 Duo: a part that's now nearing the end of its life. The advantage of the Core 2 Duo's common L2 cache between both cores is clearly apparent when we consider the SU7300 has a clock speed of only 1.3GHz, versus the Nano Dual-Core at 1.8GHz. Even then, the TDP of the SU7300 - which, bare in mind has 1MB more cache to power - is around 10W less than VIA's anticipated final TDP when the Nano Dual Core moves to 40nm. That's a considerable downside for VIA if it wants this CPU to be seriously considered for laptops - ultra-thin or not.
__________________
Daedalus - Clevo P170SM | i7 4700MQ @ 3.4Ghz | GTX780M 4GB @980/6000 | 16GB DDR3 | 17.3" 1920x1080 |
ZPM "VIVE" Mini - Fractal Node 202 | i7 4770S | GTX1070 | 8GB DDR3 | 4K TV / HTC VIVE |
Consoles / Retro - PS4 Pro | PS4 | Xbox One x2 | Dreamcast x2 (VGA) | WiiU | Retron5 |
xaser04 is offline   Reply With Quote
Old 2nd Nov 2010, 15:18   #7
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Yeah, it's exactly 50 days when AMD last showed some awesome stuff
http://www.anandtech.com/show/3920/a...e-than-core-i5
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 2nd Nov 2010, 16:13   #8
Ross1
Multimodder
Ross1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run CrysisRoss1 can run Crysis
heh, i didnt realise you used the planet earth bird scene.
Ross1 is offline   Reply With Quote
Old 2nd Nov 2010, 18:23   #9
Adnoctum
Kill_All_Humans
Adnoctum's Avatar
Adnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for president
I has Socket A flashbacks on that motherboard and cooler. From the stencilled lettering and baby-poo colouring, can I assume the board was made by Asus (or is that Pegatron now)?
When was the last time you saw a product with a VIA CPU? My guess it has been a while. I only see them occasionally in corporate thin client laptops (HP ones). I understand that VIA platforms are more common, and more popular, in Asia. I assume this is where VIA is focussing their energies now, and incidentally, probably why Richard was the only Euro journalist to get to try it out.
It looks pretty poor when the 1.3GHz SU7300 outperforms it.
And they will have no chance against AMD's Zacate/Ontario. All the strengths of this VIA platform pale when compared Zacate. With TSMC spewing forth in January, the Nano is too little, too late.
Which is sad because I like VIA, the little computer company that could.
__________________
Main Rig: Amiga A1200 - Motorola 68EC020@14.2MHz + 68030@50MHz Acc. Card - Lisa Graphics - 2+8MB RAM - 80MB HDD
LAN Rig: Amiga A500 - Motorola 68000@8MHz - Denise Graphics - 512+512KB RAM
Adnoctum is offline   Reply With Quote
Old 2nd Nov 2010, 19:48   #10
Andy Mc
I *am* a Dremel
Andy Mc's Avatar
Andy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming Saiyan
I know the board is a engineerign sample, but the 3rd PCIe 4x slot and the 2 1x slots in the first pic of the board looked back to front to me???
__________________
Andy Mc is online now   Reply With Quote
Old 2nd Nov 2010, 19:58   #11
xaser04
Ba Ba Ba BANANA!
xaser04's Avatar
It not only out peforms it, it does so whilst using 10w less which in ultra portable terms is a massive amount.
__________________
Old 5th Nov 2010, 03:32   #12
andrewf
What's a Dremel?
andrewf has yet to learn the way of the Dremel
My analysis is over at The Daily Circuit (if you remember what dual celeron 300a's are, you will enjoy that site). You Nano naysayers are thinking about it wrong. Regardless of the any laptop claims, it is a netbook or mini-tablet processor, and a darn good one of that. It toasts everything out there right now, and it is an open question as to whether that crown will be taken before it's hard launch. If not, it will have its day in the sun, and we will all benefit from some refreshing, real, actual, honest-to-goodness competition (remember what that was like?)
andrewf is offline   Reply With Quote
Old 8th Nov 2010, 07:58   #13
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
A 20W tablet and netbook processor? Good luck with that.
VIA folks told me themselves it's not really aimed at netbooks. It's value laptops, budget 'ultra-thins' and nettop PCs for emerging markets predominantly.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 9th Nov 2010, 07:58   #14
Adnoctum
Kill_All_Humans
Adnoctum's Avatar
Ha Ha Ha. This is either a terrific troll, or a clueless commentator.
You are incredibly confused I think. You are probably looking at the specifications of all those Chinese tablets running Android floating around, seeing that they have a VIA CPU, and then you mixed them up with the Nano.
Mate, the WM8505 is an ARM-based System-on-Chip design that has nothing to do with the Nano.
__________________
Old 10th Nov 2010, 04:59   #15
andrewf
What's a Dremel?
Anybody remember the QX9650? It had less than 65w power consumption under load but was rated by Intel at 130 watt TDP despite receiving a 65nm to 45nm die shrink. TDP ratings rarely reflect actual power consumption and can easily be off by 2x, as was the case with that processor.
The article clearly shows the performance is not on par with current good laptop processors like the Core 2 Duo, and why should it be, the die area of that C2D is about twice what the dual core Nano will be in 40nm and the C2D is priced more than double what the Nano needs to be at to make money for VIA. Zacate will also be larger than Nano and cost more. Ontario will probably consume less power but won't perform as well as Nano.
The Nano delivers good performance for netbook applications at what will probably be a low price. If the power consumption really is 25 watts whenever you browse the web, then that is another thing, but that is very unlikely.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
