Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 6th Nov 2010, 09:20   #1
Yewzorz
Minimodder
Yewzorz has yet to learn the way of the DremelYewzorz has yet to learn the way of the DremelYewzorz has yet to learn the way of the DremelYewzorz has yet to learn the way of the DremelYewzorz has yet to learn the way of the Dremel
Dell saturation
Hey Guys, Ive been a long time reader of CustomPC/bit-tech, but a first time poster
And unfortuantely I come with a problem, Ive recently got a Dell Inspiron 1545, hopwever the colours on the screen are so undersaturated. Does anyone know how to increase the saturation (ive checked in all the Intel media controller options, nothing, only a saturation fontroller for movies, not for general screen use) D:
Thanks
Yewzorz is offline   Reply With Quote
Old 6th Nov 2010, 14:51   #2
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpit
Update you Intel GPU, check if you have such option in the Intel control Panel.
If not.. then there is nothing you can really do to my knowledge.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 10th Nov 2010, 11:25   #3
Yewzorz
Minimodder
Thanks.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
