Reply
Thread Tools View Mode
Old 23rd Dec 2010, 07:11   #41
Boddaker
TRON CAT!
Boddaker's Avatar
Boddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run Crysis
Ok class... a couple modding math formulas to remember:
Cold symptoms + sleep deprivation = momentary lapse of concentration
momentary lapse of concentration + high-speed buffing wheel = bent fin!
I guess one bent fin out of 24 aint bad lol. Luckily I had extras cut!
__________________
www.bods-mods.com
Originally Posted by my brother
Is the name "Neptune's Trident" something you came up with? I can't see how a planet and chewing gum are related.
Boddaker is offline   Reply With Quote
Old 23rd Dec 2010, 07:48   #42
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
At least it didn't end up sticking out of your leg. Has happened to me also, several times.
I'm glad to not have suffered any injuries. Next fin please, mod on.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 23rd Dec 2010, 08:53   #43
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
Momentary lapse of concentration - angle grinder jumps off aluminum and skates "lightly" across forearm.
I got it cleaned up and bandaged and kept going.
Bring on the fins!
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is offline   Reply With Quote
Old 27th Dec 2010, 02:24   #44
Boddaker
TRON CAT!
Boddaker's Avatar
The last little bits are falling into place.
Had to supplement the A700's exhaust venting, since my new base pretty much enclosed the factory outlet. Here's how it originally exited the unit. The back cover had a matching opening over the black grill area. But now the hot air would just be blowing into the base.
So an air duct would have to be made to direct the hot air towards the fins and out. So I mocked it up with some construction paper and transferred its shape to some roof flashing and cut it out.
Then I marked the folds and bent them down using spare box tubing and my vise. A block of wood was used to put even pressure over the bending area.
The box tubing provided a nice sharp, straight edge over which to bend.
Top half is done.
Added a bottom to it and riveted them together.
Finished piece.
Finished piece fastened to the A700.
This, in addition to a separate heat shield I'm making to go over the projector, should help keep the temps at an acceptable level inside the base.
__________________
www.bods-mods.com
Old 27th Dec 2010, 02:33   #45
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
Time running out Brian. Looking good.
john
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 27th Dec 2010, 17:56   #46
Boddaker
TRON CAT!
Boddaker's Avatar
Thanks John, yes it's time to wrap this thing up!
So how does one paint something in 40º wet rainy weather and no paint booth? Answer: hang some plastic sheeting around a space heater and a heat lamp!
Here's the base taped off and hanging, ready to prime.
After a couple coats of black primer.
Shooting the gloss coat after wet-sanding with 400 grit.
While that was drying, I turned my attention towards the heat shield. Got it cut, bent, and edges filed so I could test it for fit once the base was dry.
Got the base mounted to the A700 this morning and did a smoke test.
An iris-downed shot of the projected image. It's a bit blurry because the Sensei is sitting too close to the wall and it won't focus that close. Also, the date's wrong (should be today).
I'll post up final pics later today. 'til then!
__________________
www.bods-mods.com
Old 28th Dec 2010, 07:15   #47
Boddaker
TRON CAT!
Boddaker's Avatar
Brought Sensei in to the conference room at my work place to take final shots. Enjoy!
I'd like to thank everyone who helped me throughout this project: Moddersmart, Crucial, Pacific Waterjet, and especially to Lenovo for having the contest and providing me with one of their cool products to mod!
__________________
www.bods-mods.com
Old 28th Dec 2010, 07:43   #48
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Truly amazing dude
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 28th Dec 2010, 09:04   #49
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
You are a master in modding man that looks way better than any industrial device !!! Bravo!
AnG3L is offline   Reply With Quote
Old 28th Dec 2010, 09:24   #50
Nexxo
There is no rep for awesomeness.
Moderator
Nexxo's Avatar
Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.
That is such an obvious and brilliant idea that I'm surprised no one else has ever thought about it. Should be produced commercially, really.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust
Nexxo is offline   Reply With Quote
Old 28th Dec 2010, 12:06   #51
Attila
still thinking....
Attila's Avatar
^^^ I'm with him. Really excellent work mate. The finish is factory.
__________________
stillthinking
Old 28th Dec 2010, 15:18   #52
slipperyskip
Seemingly Disinterested
slipperyskip's Avatar
slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.
Awesome. Fins R da sex. I'm looking forward to seeing it in person next week.
slipperyskip is offline   Reply With Quote
Old 28th Dec 2010, 17:16   #53
Boddaker
TRON CAT!
Boddaker's Avatar
Originally Posted by Editor22 View Post
Truly amazing dude
Thanks man!
Thank you Alex.
Thanks Nexxo. Numerous people have said this, and I hope you are all right! Maybe Lenovo will get a bunch of orders for it at CES lol.
Thanks Attila! There are a few areas where I wish I could have addressed more, but time was not on my side, so sacrifices had to be made.
Thank you Jeffrey. I'm glad you will be there to make sure Sensei is handled properly.
__________________
www.bods-mods.com
Old 12th Jan 2011, 16:58   #54
Boddaker
TRON CAT!
Boddaker's Avatar
Found a shot of Sensei on display at Lenovo's area inside the Venetian at CES (thanks to Charles from TBCS for taking the picture!) At least I now have proof it physically made it there in one piece. Shame they couldn't get the projector to work.
Spotted the edge of Sensei in this video interview of the contest winner, James Fislar.
<Come on James, move out of the way, you're blocking the shot! lol >
__________________
www.bods-mods.com
Old 12th Jan 2011, 17:53   #55
slipperyskip
My camera crapped out so I didn't take a single photo of anything. It might have been a good thing that they didn't turn Sensei on because people were allowed to do whatever they wanted to the displayed mods. Dean's Arcade dock was played almost continuously taking a serious beating from the crowd. I joked that he would have made a fortune if he had a coin slot working with it.
Lenovo did a good job talking up the mods and were genuinely proud to be displaying them. A lot of people got to see them and we all spent a lot of time talking to the crowd about case modding in general. Lenovo seemed to be pleased with the result and indicated that they would be interested in doing more of this in the future.
Sensei looked great! Much bigger than I expected. Unfortunately, Dean's Arcade dock was a huge hit and our mods sadly sat on either side of it. LOL
Old 12th Jan 2011, 21:41   #56
Gtek
Supermodder
Gtek's Avatar
Gtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run Crysis
Great idea, practical, good looking and perfectly build... just great
__________________
***gtek-computerdesign.com***
Gtek is offline   Reply With Quote
Old 12th Jan 2011, 22:50   #57
jj_sky5000
Multimodder
jj_sky5000's Avatar
jj_sky5000 has yet to learn the way of the Dremel
Here is the drive by shot of the Sensei , Must have been late for dinner. I have no idea why he didnt stop and talk about it.
The lenovo sales guys where stopping by more and more to show them !!!!
jj_sky5000 is offline   Reply With Quote
Old 12th Jan 2011, 23:17   #58
Gaming_freak_10
Hypermodder
Gaming_freak_10's Avatar
Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.
wow this is an amazing project there! .. i wish i could have one of those.. dang it lol
Gaming_freak_10 is offline   Reply With Quote
Old 13th Jan 2011, 02:57   #59
wahoomcdaniel
Multimodder
wahoomcdaniel has yet to learn the way of the Dremel
I think this is a great adaptation and I can see that it would be a worthwhile presentation/teaching aid. I’m surprised it hasn't gained more attention, but like some brilliant ideas, acceptance may be slow until consumers figure out what they're missing. You did a really nice job.
I do have one suggestion when you & Lenovo go into production – your idea for the piano hinge would have been an improvement. I realize that you didn’t have time to create and incorporate a mounting brace, though. Still an overall win on this mod.
wahoomcdaniel is offline   Reply With Quote
Old 13th Jan 2011, 03:12   #60
jprykov
Minimodder
jprykov has yet to learn the way of the Dremel
That guy missed the best MOD that has ever been made! he's in a hurry... maybe he has to go to the bathroom because of LBM or something haha!
jprykov is offline   Reply With Quote
Reply
Tags
boddaker, bods-mods.com, lenovo, sensei
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
