Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Nov 2010, 16:12   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
What does TDP mean, Nvidia?
Reading through the [eurl=http://www.bit-tech.net/hardware/graphics/2010/11/09/nvidia-geforce-gtx-580-review/1]Nvidia GeForce GTX 580 1.5GB review[/eurl] guide threw up a new definition for TDP...
http://www.bit-tech.net/blog/2010/11...p-mean-nvidia/
Claave is offline   Reply With Quote
Old 11th Nov 2010, 16:29   #2
Snips
I can do dat, giz a job
Snips's Avatar
Snips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming Saiyan
You can't open up a can of worms purely based on a marketing department. ALL the manufacturers do it, Nvidia, Intel, AMD, Ann Summers claiming their products do this or do that. Real world benchtests can prove otherwise so let's just keep it at that. I constantly moan about the AMD marketing, something I'm serving time for, but I went down that trap of believing the pap and then seeing the crap. Be warned, you gonna get it bigtime Clive.
Snips is offline   Reply With Quote
Old 11th Nov 2010, 16:34   #3
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
perhaps it is the power draw for the actual GPU, rather than the 293w measured for the whole card?
but agree with article, why did nvidia choose to use power consumption rather than heat output? it doesn't exactly make them look good, only adds more to confusion
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 11th Nov 2010, 16:47   #4
Picarro
I Mod, Therefore I Own
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
Unless they went for the "MOAR NUMBERS IS MOAR!!1!!!!1" tactic .. Wouldn't really surprise me
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is offline   Reply With Quote
Old 11th Nov 2010, 16:50   #5
greigaitken
Supermodder
greigaitken has yet to learn the way of the Dremel
besides the 1/2w for sound - surely ALL the power consumed is turned to heat? surely it's better to know how much power the device will consume so that you know how much you will need to supply it. which should also be the same as how much heat it produces. Where else would the energy go?
greigaitken is offline   Reply With Quote
Old 11th Nov 2010, 16:51   #6
barrkel
Multimodder
barrkel has yet to learn the way of the Dremel
Thanks to the magic of conservation of energy, the power used by solid-state hardware (no moving parts) is all but equal to the amount of heat it needs to dissipate.
barrkel is offline   Reply With Quote
Old 11th Nov 2010, 17:01   #7
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.
This is kind of an odd blog post - essentially all of the power input of a computer component is output as waste heat. This isn't some kind of physical machine where some of the power is actually used to move something from A to B or to light a room or whatever. A CPU or GPU which uses 100W outputs 100W of heat. The logic (work) done by the chip comes from the entropy gap between (high entropy) electricity and (low entropy) low level waste heat. So to draw a distinction between measuring TDP by power input and by heat output is pure semantics - the figure is the same. Okay so Nvidia may be selling themselves short by using the TDP for the entire card rather than just the GPU, but ultimately this is a less misleading measure - what users really care about is (a) how much electricity does it use (i.e. how much is it going to cost me in electricity bills); and (b) how much heat will it dump into my case (or room, if it exhausts to the rear as many GPUs now do). The two things are the same.
__________________
mclean007 is offline   Reply With Quote
Old 11th Nov 2010, 17:06   #8
sleepygamer
More Metal Than Thou
sleepygamer's Avatar
sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.sleepygamer is the Cheesecake. Relix smiles down upon them.
Ann Summers Scientist does a press conference:
"Our new product, the 'Mysterious Passion' nightdress, complete with stockings and boots has been shown in tests to increase the TDP of your significant other by upto 20%. Please ensure that you have adequate hardware to tame this increase in heat."
Hee...
__________________
Senpai | CPU | Intel i5 2500K | RAM | 16GB Corsair Vengeance 1600MHz | Mobo | Gigabyte Z68X-UD3H-B3 | GPU | Asus STRIX 960 4GB | SSDs | Intel 730 Series 250GB, Corsair Force 3 120GB, OCZ Agility 120GB | HDD/Storage | 2x1TB Samsung Spinpoint F3 | PSU | Silverstone Strider 700W | Case | NZXT M59 | Monitor | 24"+20" LG Flatrons | Keyboard | Razer Blackwidow TE | Mouse | Roccat Tyon
sleepygamer is offline   Reply With Quote
Old 11th Nov 2010, 17:27   #9
Bakes
Hypermodder
Bakes has yet to learn the way of the DremelBakes has yet to learn the way of the DremelBakes has yet to learn the way of the Dremel
Clive,
nVidia is actually using that definition in order to fool the consumer. Whilst Intel and AMD/ATI are using the definition of the power output over every condition (so an Intel TDP would be the absolute maximum that chip/unit would use), nVidia is defining 'over standard operating conditions', that being games. So, when you get an ATI TDP and an nVidia TDP, they can mean wildly different things.
For example:
Original source: http://www.behardware.com/articles/7...x-480-470.html
That site measured the actual power input using a special PCIe riser card - as you can see the ATI 5870 is very close to its published TDP of 188w, but the GTX 480 is far higher - the published tdp is around 260w but under furmark (ie full load rather than the load you'll see in games) it increases by around 40 watts.
This makes the nVidia tdp values even more incomparable - since whilst ATI shows tdp values that roughly correlate to the power draw, nVidias only correlate to the power draw whilst playing games - doing a high-stress test such as furmark or folding will increase the power draw massively.
Bakes is offline   Reply With Quote
Old 11th Nov 2010, 17:41   #10
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn has yet to learn the way of the DremelHourBeforeDawn has yet to learn the way of the Dremel
@Bakes cant get the image to load and also do they have a pic of this special riser card???
__________________
Current Rig: Project STEALTH
DimasTech Test Bench Black ICE Triple 120 Rad Dual Bay Res/Pump DD Fill Port & Res D-Tek FuZion 2 CPU Block ASUS M3A79-T Deluxe Mobo AMD Phenom II 3ghz @ 4ghz 8gb DDR2-1100 Memory (2) AMD 6870 XFire (2) WD Black 640gb Raid 0 (2) 1.5TB SEAGATE Blu-Ray/HD DVD Drive ASUS XONAR DX2 30" DOUBLESIGHT LCD (2) 23" ASUS LCD ZALMAN 8 FAN CONTROLLER (4) NOCTUA P12 (2) NOCTUA P14 1000W ZALMAN PSU WINDOWS 7 PRO 64
HourBeforeDawn is offline   Reply With Quote
Old 11th Nov 2010, 17:44   #11
MaverickWill
Dirty CPC Mackem
MaverickWill's Avatar
MaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run Crysis
Not helped by the fact that nVidia are apparently using circuitry on the card itself to prevent full power draw on the 580. Anandtech managed to circumvent it here, which shows, if we subtract the SLI result from the single result, a difference in power usage of 325W. Calling an efficiency of 87% (good, efficient PSU), I make that to be 283W.
__________________
Antony's got his hat on, hip, hip, hip, hooray!
MaverickWill is offline   Reply With Quote
Old 11th Nov 2010, 17:44   #12
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
TDP is totally uninteresting tbh.
Maximum powerdraw at the AC-plug is a way better measurement as this is what you pay for with your electricity-bill.
So it would be great if manufacturers would just introduce a new term, which then would be called: MPD.
As it is currently it's totally flawed, and with a short example you can picture it very well.
The fuel needed for cars is measured in litres/100km (standard triple-mix) for example, and they speak about the fuel you need to fill in your tank.
Now, if a manufacturer would instead measure the whole thing in kW used to drive 100km instead, that would totally ruin the picture, as motors used in cars vary between 30-50% efficiency.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 11th Nov 2010, 17:47   #13
Jampotp
dem spacers are well phat init blud
Jampotp has yet to learn the way of the Dremel
+1
Jampotp is offline   Reply With Quote
Old 11th Nov 2010, 18:33   #14
Phil Rhodes
Hypernobber
Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.
More pertinently, we know that TDP should be a measurement of waste energy (heat, unless something goes drastically wrong) and not, as Nvidia says, a measurement of maximum input power.
But those numbers should be so nearly identical as to make no difference.
Other than the power required to run the fan (a couple of watts) and the energy required to drive the PCIe bus lines and DVI outputs (not insignificant, but not much), all of the energy supplied to the card will eventually be dumped as heat.
If everyone measured TDP as power input, we'd be much better off.
Phil Rhodes is offline   Reply With Quote
Old 11th Nov 2010, 18:46   #15
alwayssts
Minimodder
alwayssts has yet to learn the way of the Dremel
I think this discussion is interesting, and I've mentioned it in the comments of articles from a couple different sites because it really could change the perception of a product, or what is allowable under pci-e spec. I'm glad the people at Bit-tech publicly exposed this issue, as I'm sure I'm not the only one that thinks there needs to be a standard.
Not everyone looks at charts and graphs like me, or perhaps you. Even if they choose to inform themselves beyond a TDP rating, independent reviews have variables, such as power supplies and their efficiency. A consistent test platform to test/meet a pci-e spec TDP does not seem much to ask. Both nVIDIA/AMD conform to the pci-e spec, yet can define how the spec is measured? That's ridiculous. Furmark/OCCT seems like a test fair for a workstation card, but something like Crysis makes sense for consumer products.
I compared the 4870x2 for example, versus the 5970. 4870x2 has a TDP of 286W. 5970 has a TDP of 294W. In reality, under a normal gaming scenario, the former uses close to it's TDP while the 5970 uses less than 225W. Hell, 5970 uses less power gaming than GTX580! The confusion is simply because AMD made a stupid decision starting with the 5000-series to change their TDP testing. Furmark/OCCT are not representative of the power/heat for the 5000/6000 series at all, and I hope AMD changes back. I understand some may think nVIDIA is twisting numbers, and that's a fair argument if you agree with AMD's method, but I happen to believe nVIDIA is calling this correctly and AMD is shooting themselves in the foot. Who is to say a 5870x2 wouldn't use under 300W using nVIDIA's method? It likely would. Why cock-block themselves?
As I've said before, it will be interesting to see if and/or when dual GF104/Cayman products are released, and if this discrepancy still exists.
alwayssts is offline   Reply With Quote
Old 11th Nov 2010, 19:03   #16
jrs77
theorycrafting
jrs77's Avatar
Like I said there allready. Manufacturers simply need to agree upon "maximum powerdraw" at 100% load and state this number as "MPD" instead of using anything else.
__________________
Old 11th Nov 2010, 19:28   #17
Xtrafresh
It never hurts to help
Xtrafresh's Avatar
Xtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run Crysis
Clive, do i understand correctly that you are criticizing the nVidia Marketing department for not spinning this number to their advantage?
@jrs77: nVidia and ATI disagree about 100% load though. A card runs hotter and uses more power in furmark then when playing games, yet both generate 100% load if you believe GPUz.
__________________
Think of how stupid the average person is, and realize half of them are stupider than that.
- George Carlin
Xtrafresh is offline   Reply With Quote
Old 11th Nov 2010, 19:46   #18
Altron
LIKE A BAUCE!!!!
Altron's Avatar
Altron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the DremelAltron has yet to learn the way of the Dremel
The real issue here is the wording
"TDP is a measure of maximum power draw over time in real world applications"
What's "maximum power draw over time"? That's not an engineering term. You can have a maximum instantaneous power draw, and an average power draw over time, but not a "maximum power draw over time".
And what's "real world applications" - I feel like this would exclude articifial benchmarks that run every part of the chip at 100% utilization.
But splitting hairs over "input power" and "power wasted as heat" - that's just stupid. The only thing that produces an actual energy output other than heat is the fan (produces kinetic energy in air and produces sound) and the very low power signal going out over the video cables or the PCIe data lanes. That amount of energy is marginal compared to the power spent as heat.
__________________
If this post is not up to your standards, please lower your standards.
e^i(pi)+1=0
Altron is offline   Reply With Quote
Old 11th Nov 2010, 19:50   #19
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
I didn't even know there wasn't a standard set until read this.. you know nvidia though.. they will spin it to look better for themselves every time- even if what they are talking about has wood screws in it
thehippoz is offline   Reply With Quote
Old 11th Nov 2010, 19:53   #20
jrs77
theorycrafting
jrs77's Avatar
100% load = 100% of all the card can possibly deliver before it starts friying it's components.
I don't give a **** about benchmarks etc...
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
