#1 |
Is re-building his PC again
MSI (MS 7360) mainboard - Ok for overclocking?
Hey everyone,
Just a quick one really. Would this motherboard be suitable for overclocking? MSI (MS 7360) P35 chipset. I appreciate that il need a decent PSU, and case etc. But just thinking about the mainboard atm EDIT: Added linky to board specs http://www.msi.com/index.php?func=pr...2&prod_no=1215 Any opinions would be greatly appreciated! thank you Last edited by bdigital; 15th Nov 2010 at 17:30. |
#2 |
Any ideas guys? Ive got a hunch that its not suitable, but still interested in your opinions
ta |
#3 |
The modding head is firmly back on.
You can overclock on any mobo that has access to the right setting on the mobo. Some will have more options than others and some just overclock better than others.
And what I've just said looks about as clear as mud
#4 |
lol okies bud - Are there any suggestions of cheap brand new S775 board? (£30-40) that is a good overclocker?
Im also after a cheap ish PSU that i can use for overclocking said board. |
#5 |
http://www.scan.co.uk/products/gigab...3gb-s-matx-vga It wont break any records but you can have some fun with it. Just check the cpu support...lol
#6 | |
![]() Shame scan dont show the list of supported CPUs, it says 45nm support, but dont know if that would be backward compatable for the e2160 chips. |
#7 |
Packaging Master!
I can vouch for the GA-G31M-ES2L. It overclocked my E5200 to 3.5GHz and my E3300 to 3.36GHz. Its a little cheaper than the one jeff posted, but its decent enough. I had a thread about its reliability a few weeks ago, if you care to search for it. £35 from scan, although you can find it on their today only page quite often for £32.
edit: I have an E2160 too, and will soon be putting it in the G31M-ES2L. Aiming for 2.8-3GHz.
__________________
Bonnie i3-2100T | H61M-P31 | 4GB DDR3 1333MHz | 60GB OCZ Agility 3 SSD | GTX 260 |
#8 |
It should be ok G31 is the older chip set
Edit http://www.gigabyte.com/support-down...cs=Intel%20G31 looks like it will take anything same as my GA-P31_DS3L |
#9 |
Sweet nice one neal - looking at Scans 'today only' has thrown up these ones
Gigabyte GA-G31M-ES2L iG31 Express, S775, PCI-E (x16), DDR2 1066(OC)/ 800 MHz, SATA II, Micro ATX £35 inc vat http://www.scan.co.uk/products/gigab...a-ii-micro-atx Asus P5G41T-M-LX, Intel G41, S 775, PCI-E 2.0 (x16), DDR3 1333(OC), SATA 3GB/s, mATX, On Board VGA £33.71 http://www.scan.co.uk/products/asus-...x-on-board-vga Gigabyte GA-G41MT-ES2L, Intel G41, S 775, PCI-E (x16), DDR3 1066/1333(OC), SATA 3Gb/s, VGA, ATX £38.05 http://www.scan.co.uk/products/gigab...-3gb-s-vga-atx Gigabyte GA-G41M-ES2L, Intel G41, S 775, PCI-E (x16), DDR2 1333, SATA 3Gbps, MicroATX, Onboard VGA £36.06 http://www.scan.co.uk/products/gigab...tx-onboard-vga Any stand out models? |
#10 |
What ram are you putting in it?
#11 |
hmm corsair DDR2 XMS2 6400 (800MHz).
#12 |
That limits you to the top mobo then. All the rest are ddr3
#13 |
#14 |
sorry, don't know what I was looking at. If you are using your own GPU I would say the top one is slightly better
#15 |
I Mod, Therefore I Own
Have a look at the market place fourms, i think there is a P5k up there.
#16 |
Hmmm whereabouts is that murray? Could you drop me a link? I know mullberyy has a have a P5Q3 Deluxe/WiFi-AP, but thats DDR3 only.
#17 |
#18 |
Also, PSU wise, ive found a CX400 ATX2.2 and a CX430 ATX2.2
Are either of these good PSUs for overclocking (it kinda goes against my rule of buying modular, but reviews are pretty good and the price is right) CX400 http://www.novatech.co.uk/novatech/p...u-400cxuk.html CX430 http://www.novatech.co.uk/novatech/p...psu-430cx.html |
#19 |
For the extra few quid I would say go for the 430, but either will do. The main thing is a stable power supply. I can see myself picking up one of those..lol
#20 |
Yeah i thought the CX were hard to come by, but ive found them at novatech. Not sure if these are the right ones tho? ATX2.2 is new to me?
Do you think that because the CX400 reviews so well, that its a given that the 430w is quality too? As long as its happy overclocking and is powerful enough then im happy
| Thread Tools | |
