Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 16th Nov 2010, 13:05   #1
CardJoe
Freelance Journalist
bit-tech Staff
CardJoe's Avatar
CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!CardJoe - it's over 9000!!!!!!!!1!1!1!!!
Hitachi announces ultra-fast SSDs
http://www.bit-tech.net/news/hardwar...ra-fast-ssds/1
CardJoe is offline   Reply With Quote
Old 16th Nov 2010, 13:35   #2
leveller
Yeti Sports 2 - 2011 Champion!
leveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremelleveller has yet to learn the way of the Dremel
It's another milestone in SSDs life. So now we can expect larger capacity and faster.
Would like to know pricing asap, although I expect out of my reach.
leveller is offline   Reply With Quote
Old 16th Nov 2010, 14:22   #3
Floyd
Wire Twister
Floyd's Avatar
Floyd has yet to learn the way of the Dremel
Even "basic" small capacity SSDs are out of my thoughts for now. Too much money for tiny drives. When they make 1TB SSDs under 100 bucks then I might consider. Im all about capacity over speed in terms of price.
I even bought into a 10k Raptor and my normal 7200rpm 1TB smokes it in speed other than small file transfers. Waste of money.
Floyd is offline   Reply With Quote
Old 16th Nov 2010, 15:04   #4
DriftCarl
Supermodder
DriftCarl has yet to learn the way of the Dremel
i really want an SSD now since I got my new PC. I have scored 7.9 on all the windows experience index things except the hard drive, which comes up at a crappy 5.8. Surely this SSD should bring it up close to the 7.9 cap?
DriftCarl is offline   Reply With Quote
Old 16th Nov 2010, 16:21   #5
ViPPeR_666
Minimodder
ViPPeR_666 has yet to learn the way of the Dremel
I currently own a pair of SF-1200 based 60gb OCZs in a RAID 0 array and they scored 7.9 on windows index. If you just want the 7.9 score itself you may wanna buy something right now instead of getting that Hitachi SSD.
__________________
"The Christian god can be easily pictured as virtually the same as the many ancient gods of past civilisations. The Christian god is a three-headed monster; cruel, vengeful and capricious. If one wishes to know more of this raging, three headed beast-like god, one only needs to look at the calibre of the people who say they serve him. They are always of two classes: fools and hypocrites."
John Adams
ViPPeR_666 is offline   Reply With Quote
Old 16th Nov 2010, 16:44   #6
schmidtbag
Supermodder
schmidtbag has yet to learn the way of the Dremelschmidtbag has yet to learn the way of the Dremel
ocz has created a sata SSD that operates at over 700MB/s, but, it does require its own raid card. hitachi imo is the winner because they created something that'll fit in any sata3 ports.
i really don't understand why sata3 isn't being used as much. if sata is backwards compatible, why not just use the fastest?
schmidtbag is offline   Reply With Quote
Old 16th Nov 2010, 19:04   #7
Floyd
Wire Twister
Floyd's Avatar
Its the OCZ IBIS. Its insanely fast and insanely priced.
From what I read though they have a 960GB drive for the low low price of about 2500 EUR.
Old 16th Nov 2010, 22:52   #8
borandi
Multimodder
borandi has yet to learn the way of the Dremelborandi has yet to learn the way of the Dremelborandi has yet to learn the way of the Dremel
The WEI is a pretty useless number tbh.
I'd like to know what controller they're using, but that information has been suspiciously left out of this news article. It's not even postulated what controller is being used.
borandi is offline   Reply With Quote
Old 17th Nov 2010, 01:25   #9
lifer
Water on the pcb
lifer has yet to learn the way of the Dremel
Hope its more reliable than their death stars were.
lifer is offline   Reply With Quote
Old 17th Nov 2010, 05:45   #10
Fractal
I Think Therefore I Mod
Fractal's Avatar
Fractal has yet to learn the way of the Dremel
5.5W isn't very impressive for a SSD. Most energy-efficient high capacity HDDs manage about that. A good SSD should be around 2W power draw or less.
Fractal is offline   Reply With Quote
Old 17th Nov 2010, 06:17   #11
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
SSD aren't about capacity and won't be for quite a long time. SSD are made for OS and apps not data storage
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 17th Nov 2010, 07:29   #12
JA12
Minimodder
JA12 has yet to learn the way of the Dremel
Windows experience index? Now there's an oxymoron.
JA12 is offline   Reply With Quote
Old 17th Nov 2010, 11:01   #13
murtoz
Busy procrastinating
murtoz has yet to learn the way of the Dremel
Nope.
Physically fit, maybe. Work - not at all. You need a SAS port for a SAS drive to work.
The other way round does work, SAS controllers are compatible with SATA drives.
murtoz is offline   Reply With Quote
Old 17th Nov 2010, 18:05   #14
Mister_Tad
Serious about coffee
Moderator
Mister_Tad's Avatar
Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!
Would surprise me a great deal if you see these in a retailer near you any time soon. I should imagine the vast majority of them are headed for HDS VSP and USP-V arrays (or have been living in them for at least a few months, the may have only been just announced by HGST, but HDS have offered SSD options for their kit for quite some time)
Mister_Tad is offline   Reply With Quote
Old 17th Nov 2010, 19:42   #15
Phoenixlight
Modder
Phoenixlight's Avatar
Phoenixlight has yet to learn the way of the Dremel
Why do you care what windows thinks of your storage medium?
Phoenixlight is offline   Reply With Quote
Old 18th Nov 2010, 07:17   #16
jamesislush
What's a Dremel?
jamesislush has yet to learn the way of the Dremel
OCZ do a much faster drive, the Z-Drive. Top rated model is 2TB with read/write speeds of 1400/1400 mb/s. Insane speeds using MLC-Flash in an 8 way RAID setup. Not just intended for enterprise either, the Z-drive is 8XPCIe. Of course, you would have to pay over £6500 for the thing, but imagine how fast Windows would boot lol.
jamesislush is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
