Reply
Thread Tools View Mode
Old 25th Nov 2010, 11:11   #41
The_Gnu
8-bit addict
The_Gnu's Avatar
The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.
Originally Posted by murtoz View Post
Love the space invaders heatsinks!
haha thanks. Space invaders was a new one, have to add that to the list along with tetris, lego, and periodic table
__________________
Project: ProtoHype (paused)
Project: GET A LIFE (Complete)
Project: Widescreen Projector(Complete)
Guide: How to brush Aluminum
The_Gnu is offline   Reply With Quote
Old 25th Nov 2010, 20:04   #42
DBA
I do my modding with a spoon
DBA's Avatar
DBA has yet to learn the way of the Dremel
Space invaders was also my first thought.
Love your work
DBA is offline   Reply With Quote
Old 26th Nov 2010, 09:20   #43
devilxc
Biding my time...
devilxc has yet to learn the way of the Dremel
Gnu, love your work. Looks like another great build. I've always wanted to build a case linking the CPU to large passive heatsinks.
I'll be following this on closely!
devilxc is offline   Reply With Quote
Old 26th Nov 2010, 15:42   #44
The_Gnu
8-bit addict
The_Gnu's Avatar
Love your work
Haha that is pretty damn close, never thought of that Thanks a lot
Thanks, glad you like it. Maybe you should build one
And a small progress update: Yesterday I started building the "cpu to heatpipe block" or whatever it's called. Don't know the right term since both "cpu cooler" and "block" feels wrong wen dealing with heatpipes Anyway.. I encountered some errors in the workshop and the piece is not fully done yet. Hoepfully I can get some time off during the weekend to finish it.
Cee ya
__________________
Old 30th Nov 2010, 03:11   #45
The_Gnu
8-bit addict
The_Gnu's Avatar
I ve been busy this weekend building the cpu to heatpipe thingy. There is a lot of pics so I won't take time to comment each of them. Basically some manufacturing pics and some of the finished piece. Feel free to ask if something is not clear.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
Here Im milling the 6mm O groves for the heatpipes. They are to deep to be able to drill so I milled them with a ball nose cutter.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
Here is the finished bottom piece. The nuts are from the original cooler and they are not normal nuts. It's like a thread changer that changes the M4 threads on the cooler to fit the special screws with springs that will screw it onto the motherboard. The nuts also act like a spacer between cooler and motherboard. The nuts are not fully tightened yet because they will be removed later on. The round slot you see in the picture below is to allow room for one of the capasitors on the motherboard. The reason for one piece of the bottom is higer is because the cpu and gpu is not at the same level. There is still some cleaning up like wetsanding and polishing to do but you get the idea.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
If you were wondering the lid have had some sanding done to it
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
In the end I noticed that the holes/grooves are 6mm in one direction and 5,8mm in another. I don't see how this could have happened since I had a 6mm ball nose mill and each slot is 3mm deep. Therefore it should be 6mm wide. I'll have to sort it out next time since the heatpipes are 6mm and won't fit at the moment.
Hope you like it.
__________________
Old 30th Nov 2010, 03:21   #46
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Holy crap Gnu, that's terrific. Very nice machining.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 30th Nov 2010, 03:33   #47
Wicked_Sludge
My eyes! The goggles do nothing!
Wicked_Sludge's Avatar
Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.
that looks fantastic. it looks like a part designed to handle a heavy load...like part of a tank or submarine or something.
one bit of criticism, would you not get better performance if the heatpipes were much, much closer to the base the the block? there seems an excessive amount of metal that the heat has to transfer through before it reaches the pipes.
__________________
My Rig:
Gigabyte GA-P55A-UD3|Intel Core i7-870 @ 4.0Ghz|12GB G.Skill Ripjaws DDR3 1600|AMD 7970GHz Edition|2x Barracuda 1TB RAID 1
Wicked_Sludge is offline   Reply With Quote
Old 30th Nov 2010, 03:52   #48
The_Gnu
8-bit addict
The_Gnu's Avatar
Thanks mate
Thanks, yeah it is kind of heavy . Thanks for your thoughts as well. The reason for why it is so thick is that there are some capasitors (or whatever it is) in the way on the motherboard. You can se them to the left in this pic (silver/red and black)
I was planing to bend the pipes down but assumed that the bend would probably need to be pretty big not to destroy the pipe. I assumed that the pipes would then end upp furter away from the cpu because of the bend and I would also have less surface of the heatpipes connected to the alu. However it is possible that I will mill down the bottom some more when it's all test fitted and I know for shure how much space I have left.
__________________
Old 30th Nov 2010, 04:50   #49
dgurion
What's a Dremel?
dgurion has yet to learn the way of the Dremel
If you are going to try bending the heat pipes.. A break line bender will most likely work.. They are around the same diameter.
dgurion is offline   Reply With Quote
Old 30th Nov 2010, 14:11   #50
The_Gnu
8-bit addict
The_Gnu's Avatar
Yeah ive seen those and will keep that in mind if I decide to bend the pipes. Thanks
__________________
Old 1st Dec 2010, 09:16   #51
perplekks45
LIKE AN ANIMAL!
perplekks45's Avatar
perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.
'nuff sed.
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far.
ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
Iä! Iä! Cthulhu fhtagn!
perplekks45 is offline   Reply With Quote
Old 1st Dec 2010, 20:08   #52
The_Gnu
8-bit addict
The_Gnu's Avatar
Originally Posted by perplekks45 View Post
'nuff sed.
Then Ill answer you with this:
__________________
Old 4th Dec 2010, 19:28   #53
The_Gnu
8-bit addict
The_Gnu's Avatar
Okay, here we go again.
I have fabricated some more of the parts for the heatsink. Yet again I didn't bother to post pics of how they were made as it's exactly the same process as the previous ones.
(CLICK TO ZOOM)
This next piece is made a bit different from the previous ones and this is the getho method I used to solve the problem of the piece being to unstable when milling. A bigger block of steel on the backside and som clamps to hold it steady, worked really good without a lot of vibrations.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
If you havn't already figured out what this project is all about then this lats pic will probably make the guessing a lot easier There is still some more parts to fabricate but here you can se the basic shape of the finished heatsink.
Btw I really need to build myself a better photo studio since I have always a problem getting the lighting right with all the shadows and crap.
__________________
Old 4th Dec 2010, 19:42   #54
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!
I'm loving this already! Frikkin awesome idea with the design of the blocks!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 4th Dec 2010, 19:56   #55
The_Gnu
8-bit addict
The_Gnu's Avatar
If you even like my stuff 1/10 of how much I love what you have done, then I'm honoured.
Thanks a lot
__________________
Old 4th Dec 2010, 20:15   #56
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
Welcome to modding 101. First lesson; You can't bend pre-formed heatpipes. They would fracture and burst. Even if you heated them enough to bend them safely, they'd no longer be heatpipes, they'd be plain copper pipes.
On topic: I love it, plain and simple! Your machining is awesome and the whole concept is original and bold. I'm sub'd
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Old 4th Dec 2010, 20:21   #57
rowin4kicks
a man walked into a bar ...
rowin4kicks's Avatar
rowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for presidentrowin4kicks should be considered for president
Great milling skills Gnu! Wish i had access to a mill again (although definatly broke the last one I used!)
__________________
Penguin v6.0 - i7 4770k - 7990 - Corsiar 250D - Dell U2410
My Flickr
rowin4kicks is offline   Reply With Quote
Old 4th Dec 2010, 21:09   #58
The_Gnu
8-bit addict
The_Gnu's Avatar
Yeah the heatpipes Im using are pretty much pushed to the limit even by the manufacturer. The pipes are crumpled on the inside of each bend and I wouldn't dare to change those bends the sligthest as im pretty shure they would brake as you say. Luckly I won't need to either. However Im pretty shure the Straight parts are bendable to some extent. Thanks for pointing that out and l'm glad you like the concept of my project
Thanks for commenting my milling skills since I still feel like a newb when amongst the others in the workshop. I'm practising though and there is a lot to lern. Sorry to hear you broke and lost the mill, don't know if I dare to ask what happened
__________________
Old 5th Dec 2010, 06:04   #59
Achron
Cad Pro Quo
Achron's Avatar
Achron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the Dremel
L.O.V.E. it. I can't wait to see where you take this one.
__________________
Completed: Acronym
Achron is offline   Reply With Quote
Old 5th Dec 2010, 12:44   #60
The_Gnu
8-bit addict
The_Gnu's Avatar
Thanks, nice to hear the CNC God is watching.
__________________
Reply
Tags
aluminium, godly nostalgia bomb, heatpipe, htpc, mill, mini-itx
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
