Reply
Thread Tools View Mode
Old 20th Dec 2010, 16:28   #81
asura
jack of all trades
asura's Avatar
asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.
That, is most impressive. The chamfering turned out great, the stepping of the block over caps etc adds to the massiveness and thoroughness of it, and the heat pipes thrusting around the board look so elegant and fluid, I'm really interested to see what you do with the fins to make them a bit special.
asura is offline   Reply With Quote
Old 20th Dec 2010, 18:03   #82
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
+ rep for passively cooling a passive cooled board.
It's little crazy things like this that makes Bit fun.
I'm looking forward to seeing a chocolate bar case.
-and more work on Protohype.
Cheapskate is offline   Reply With Quote
Old 20th Dec 2010, 18:15   #83
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
The Zotac IONITX A-E isn't passively cooled by default. Temps get too high if you use the standard-heatsink without a fan, so it requires it's fan mounted to the heatsink, or any other form of blowing air at it, like a decent case-fan etc.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 20th Dec 2010, 20:05   #84
The_Gnu
8-bit addict
The_Gnu's Avatar
The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.
Thanks for your detailed review Regarding the heatpipes, I'm glad I managed to find and scavange already prebent heatpipes. Most diy bending of heatpipes I've seen end up looking really poor and I trie to avoid that as much as possible
hehe thanks cheap.. or should I say Chuck +rep to you for that. As jrs77 stated above, I don't think the board is intended to run passive as it gets really hot under load. However without any hard load and with a good ventilated case, it might work.
Regarding ProtoHype, I have been redesigning the whole backplate as I didn't like the look the outcome of it. I intend to do some work on that during the holidays.
Yeah thats true. I did a CPU stresstest with the board laying free on a table and stopped when it reached 80°C before I aborted. During Idle the temp was around 60°C.
__________________
Project: ProtoHype (paused)
Project: GET A LIFE (Complete)
Project: Widescreen Projector(Complete)
Guide: How to brush Aluminum
The_Gnu is offline   Reply With Quote
Old 23rd Dec 2010, 16:00   #85
Cheapskate
Cheapskate's Avatar
I guess that's true. The one I have in the Ion cube has a dead-slow 120mm fan blowing over it.
Old 28th Dec 2010, 18:00   #86
jnco_analog
What's a Dremel?
jnco_analog has yet to learn the way of the Dremel
Marvelous project The_Gnu, from concept to realisation... i've been a long time follower since your widescreen projector but this one blows my mind.
Probably because i've been wanting to build a passive cooled cpu/gpu rig myself for years but never had the guts since i've never built a computer case from scratch before.
Do you think it's possible to passively cool an i7 930 @ stock (2.8Ghz) + an ATI HD5870 with the right amount of metal and the right design? Or at least have the option to cool it pasively when idle...
If you happen to have some information regarding heatpipes/heatsinks/passive cooling (links, books, papers, wathever) that you think i might find youseful to design somethink like that i would be very grateful
And respect once again for doing a wonderful job project after project
jnco_analog is offline   Reply With Quote
Old 28th Dec 2010, 18:25   #87
Wicked_Sludge
My eyes! The goggles do nothing!
Wicked_Sludge's Avatar
Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.
you can passively cool anything. its only a matter of space.
you might be interested in project hush. core i7-750 @ 4ghz, passively cooled.
PS, sorry for linking another project log to yours, Gnu
__________________
My Rig:
Gigabyte GA-P55A-UD3|Intel Core i5 750 @ 4.0Ghz|8GB G.Skill Ripjaws DDR3 1600|XFX HD5870|2x Barracuda 1TB RAID 1
Fiancées Rig:
Gigabyte GA-P67A-UD3|Intel Core i5 2500k @ 4.0Ghz|12GB Corsair XMS3 DDR3 1600|XFX HD5770 Xtreme|Samsung F3 1TB
Wicked_Sludge is offline   Reply With Quote
Old 28th Dec 2010, 21:25   #88
The_Gnu
8-bit addict
The_Gnu's Avatar
Thanks for your comments. 4 posts in 4 years I have to say feel realy honored to get this years post from you. The projector project Is so old it doesn't even have a prefix
As Wicked_Sludge said you can pretty much cool anything passively. It's all about the cooling capasity of the cooling you build. And when it comes to alu heatsinks, bigger is better. You can pretty easy calculate how much a heatsink is able to cool by using THIS nice little calculator.
Most info I have about these kind of stuff is from random google image links. So idon't remember any perticular site. Except THIS one. It's a passively cooled computer that shows you one way of doing it, but then there is always other ways. If you have an Idea, try it and don't forget to post the log here for others to take part as well Good luck
Np at all. That project is wonderfull and I don't mind giving it some extra credit in here.
__________________
Old 30th Dec 2010, 03:07   #89
jnco_analog
What's a Dremel?
I am a long time reader here at bit-tech but I don't post very often but you should feel honored, your work is realy impressive
If I ever decide to build it I'll definitely post the log here!
Thank you (and Wicked_Sludge) so much for the links, some of them are really helpful!
Old 30th Dec 2010, 03:13   #90
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Looking very excellent GNU & can't wait to see the mushroom all anodised that'll be too awesome .
Waynio is offline   Reply With Quote
Old 30th Dec 2010, 11:20   #91
stuartwood89
Please... Just call me Stu.
stuartwood89's Avatar
stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.stuartwood89 is a hoopy frood who really knows where their towel is.
I'll be watching this one. Love passive builds.
__________________
My new blog Stu-Topia.com: because stutopia.com was already taken
Project - Storm Scout Restoration
Originally Posted by Joey Propane View Post
I thought Dragonforce were like a joke/troll rock band? Ya'know, like Nickelback?
stuartwood89 is offline   Reply With Quote
Old 30th Dec 2010, 23:30   #92
MrJay
You are always where you want to be
MrJay's Avatar
MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.MrJay is a hoopy frood who really knows where their towel is.
Can't wait to see more of this : )
What kind of storage are you going to have?....
Dosent look like there is going to be Mushroom
Sorry i had too...
MrJay is offline   Reply With Quote
Old 31st Dec 2010, 14:14   #93
The_Gnu
8-bit addict
The_Gnu's Avatar
Thanks again for the nice comments and nice to hear you find the links usefull. I'm expecting a worklog from you soon hehe
Thanks, Yeah I'm looking forward to the anodizing aswell, will give them a call next week to sort some things out.
Thanks, so do I
Sorry i had too...
Thanks, ehm... hm.. I don't think I got that joke. I'll just blame my crapy english and pretend that I did and do this...
progress update: I'm currently working on the supporting backplate for the whole mushroom heatsink at the moment and will show some pics of that this weekend.
Until then: Happy new year
__________________
Old 31st Dec 2010, 14:20   #94
zukomonitor
assumption is the mother of all....
zukomonitor's Avatar
zukomonitor has yet to learn the way of the Dremelzukomonitor has yet to learn the way of the Dremel
Sorry i had too...
@ The GNU - 'much room'
Cant wait to see the anodizing and it all coming together, mod on!
zukomonitor is offline   Reply With Quote
Old 1st Jan 2011, 22:33   #95
The_Gnu
8-bit addict
The_Gnu's Avatar
DOH
Thanks
__________________
Old 3rd Jan 2011, 15:13   #96
The_Gnu
8-bit addict
The_Gnu's Avatar
After some rest during the holidays, I've managed to make the backside of the heatsink/base of the case. Unfortunately the Y travell of the mill was 10mm to short and I had to mill the piece in two turns. Luckely I didn't screw up the alignment.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
As you will see in this photo, the milling gave some pretty bad edges. This was mainly because of the dull endmill that I was forced to use. But theres nothing that some elbow grease won't fix.
(CLICK TO ZOOM)
The round courners left from the milling process had to be removed with same basic filing.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
That is one scratchy piece of alu in desperately need of...
(CLICK TO ZOOM)
..some wetsanding
(CLICK TO ZOOM)
I cleaned up the internal corners with these needle files to make them really sharp
(CLICK TO ZOOM)
And there it is.. time to start drilling the 60+ holes to mount all the heatsinkparts and the rest of the hardware.
(CLICK TO ZOOM)
Oh I almost forgot. I was planing to make a touchbutton on/off switch based on the QT113A Microcontroller. The plan was to make one part of the anodized heatsink as the "touch sensitive part". I then realized that since anodized alu doesn't conduct electricity, I'm pretty shure it won't work. Can anyone confirm this?
__________________
Old 3rd Jan 2011, 15:22   #97
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
I am so so so curious to see what the final outcome will look like!!! Mod on pls!
AnG3L is offline   Reply With Quote
Old 3rd Jan 2011, 15:41   #98
The_Gnu
8-bit addict
The_Gnu's Avatar
Well if was able to mod at the speed you are(), then It would be done in a week. But since Im not you, you will have to hold on to that curiosity for a couple of more weeks
__________________
Old 3rd Jan 2011, 15:53   #99
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
I never saw the Mario theme coming! And i lol´d hard when i did Amazing work my friend! I cant wait to see how it will look out in 8 bit
__________________
p0Pe is offline   Reply With Quote
Old 3rd Jan 2011, 16:03   #100
Waynio
Waynio's Avatar
I had a rough guess it was the 8-bit mushroom but thought no he wouldn't lol & then I thought too awesome an ultra premium mushroom case is so cheesecake .
Reply
Tags
aluminium, godly nostalgia bomb, heatpipe, htpc, mill, mini-itx
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
