#1002 |
In Flames we Trust
awesome design - stunning quality.
![]() I'm looking farward to your upcoming projects.
__________________
Scratch Build - Jestercon - MOTM Nominee Aug 2010 - building paused |
#1003 |
Keep calm & mod on. =)
Every single 0.1% out of 100 is totally awesome on this Gnu, inspiring on dedication to every single little detail.
![]() ![]() This might be my favorite & there are some crazy good contenders but this has fantastic engineering with a scoop of fun & fun gives special bonus points to a project for me as does innovation which this also has, I'd rate this 10/10 on everything, bet it's very pleasing seeing & using this now. ![]() ![]() $1000 worth of alu, that is kickass news Gnu, look forward to seeing what you do with that lot. ![]() ![]() I take the pixelated avatar is your love of 8-bit theme.
#1004 |
Supermodder
Brilliant , Brilliant , Brilliant
#1005 |
Too broke to mod
That looks phenomenal, great job!
__________________
Black Momba: i5 2500k @ 4.5ghz | Corsair H80 | MSI P67A-G43 | 8GB DDR3 1600 Ripjaws | 128GB Corsair M4, 1TB Barricuda | 2GB 6950 | Asus PA248 IPS + Acer P243w | Asus Xonar d1 | Windows 7 Ultimate x64 | Seasonic X760 | Fractal R3 | Cooler Master Quick Fire Rapid | Cooler Master Inferno Lenovo U410: i7 3517u | 8GB ram | 24GB + 750GB HDD | 14 inch ultrabook |
#1006 |
Multimodder
Great work!
__________________
Inverted 600T - OCN Mod of the month July 2012 CM Test Bench V2 - Cooler master mod competition 3rd prize Rig of The month December - Guru3D Nice articles of the test bench: Here and here |
#1007 |
Professional Sleever & Modder
The best ITX Scratchbuild ever !
Congrats my friend ! |
#1008 |
Multimodder
one of my all time faves.. congrats on an amazing build. very much looking forward to your next project
__________________
Project Carbon Apple |
#1009 |
Squid
Gnu, gnu, gnu... This is soooo stunning!!!! The power LED idea is amazing, and designed with such precision. I love it... The case itself looks perfect, I love that green color. But the NES controller mod, just WOOOOW!!! It just couldnīt look better. The detailing man. To turn the orgin cable spot into a mini USB, thatīs perfection. I learn so much from your logs man! Btw, do you know if you could use multiple ps3 in one PC? ... And would you say itīs a manageble soldering task? ... Anyway, all those hrs put into this build... the perfect alighments, the lack of space and the pixel filing(!), ALL WORTH IT! Well done... Looking forward to the pico build!
#1010 |
I ate Bhindi Bhaji.
Wow, two years of work comes to a close. I remember seeing the first of this and guessing what you were creating.
Very well done, its truely amazing. |
#1011 |
I Mod, Therefore I Own
Absolutely stunning final result Gnu!
Congratulations
__________________
ZiiP Gamestore [ZiiP] Gaming Community - IW BlackMailers and loonies abound! Sui Generis: i7 920, Corsair H50, 6GB Dominator C7 1600, EVGA x58 SLI LE, Corsair F3 120GB SSD, Samsung F3, Sapphire 5870 Vapor-X, Corsair HX850W, Corsair Obsidian 800D, Iiyama 26" Prolite, Logitech G15, Logitech G5, Sennheiser PC350. |
#1012 |
Ook ? Ook !
AWESOME BUILD !!
#1013 |
LIKE AN ANIMAL!
![]() ...still picking it up.
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far. ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn Iä! Iä! Cthulhu fhtagn!
#1014 |
Multimodder
Really god damnn nice..
__________________
Finished: -Mini-PC http://forums.bit-tech.net/showthread.php?t=248203 unfinished: none!
#1015 |
modeteer
This is hands down my favorite case this year,
Often I am impressed by the work I see on bit-tech, but very rarely am I truly astounded. I just had to show my office mates at work your case because its to amazing not to share it with other people. Craftsmanship, design and execution are all top notch mate. Huge props, I will be voting for you in MOTY when it comes around and I seriously hope you win. Nothing but win... I'm just blown away.
#1016 |
What's a Dremel?
Beautiful work mate!!!
#1017 | |||||||||
8-bit addict
Thanks Doc
Epic thanks Quote:
![]() Thanks Gtek Quote:
Thanks for the nice comment. Thanks for following this project KidMod and all the support Thanks Attila, Im honored. I can only say the same about your stuff. Thank you Editor. ![]() Quote:
![]() Quote:
![]() Thanks Thank you ![]() Thanks KoSoVaR, and thanks for the support during this project Quote:
Regarding multiple PS3 controllers on one PC. Im not shure I have seen that being done actually, I would guess that it might be a bit tricky. But I can try and make a quick test this weekend to see if it's possible to connect two controllers to one Bluetooth dongle. The soldering task however can be pretty tricky. So if you are not used to solder 1mm stuff, it can be tricky. And also, the new PS3 controllers don't have this connector for the flex pcb that I used to solder my cables to. They new versions only have contact spots on the pcb that they press the flexpcb to. Kind of the same way that the black conductive surface on the button rubber works. But you can use all PS3 controllers I think, it's just that a matter of how tricky it will be. I opened 4 controllers before I found an old version that I decided to continue with. Quote:
Thank Ziip Thank you Guille. Hm...Im not so shure I would dare to touch that though. Thanks ![]() Quote:
Cheers mate
__________________
Project: ProtoHype (paused) Project: GET A LIFE (Complete) Project: Widescreen Projector(Complete) Guide: How to brush Aluminum |
#1018 | |
Squid
Again, what a winner this build is!! MOTY!! |
#1019 | |
8-bit addict
Thanks again Quizz
__________________
#1020 |
Retro Fan
Quick question. How are you using the wireless capabilities on a pc? Is it Bluetooth?
__________________
~Intel Core I3 3220 ~8GB Corsair Vengeance 1600Mhz~ CorsairCX600w ~ Asus GTX560ti Direct CUII Core @ 950Mhz Memory @ 2250Mhz ~ P8H77 ~ 128GB Samsung 830 SSD ~ Gelid Tranquillo ~ USB modded NES, Master System, Mega Drive and N64 controllers for Emulation~
| Tags |
| aluminium, godly nostalgia bomb, heatpipe, htpc, mill, mini-itx |
| Thread Tools | |
| View Mode | |
