#101 |
Making You Feel Old Since 2010
I'm loving this! What an intuitive cooling solution that actually looks good for once... Mod on!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#102 | ||
8-bit addict
Well I'm glad you like the looks of my way of cooling since it's deffinetly not the most effective one. I'm pretty shure it breaks all the rules of heatsink designing there is. hehe but thats what makes it so fun
__________________
Project: ProtoHype (paused) Project: GET A LIFE (Complete) Project: Widescreen Projector(Complete) Guide: How to brush Aluminum |
#103 |
Supermodder
I like your cpu cooler, your solution is very cool.
#104 |
8-bit addict
Thanks. I hope it will cool as well
__________________
#105 |
8-bit addict
The next thing I was planing to do was to drill all the holes in the backplate. But since I don't know the exact position of the holes for the heatpipe-to-backplate-blocks until they're made, I'll do those first. I could have calculated the holeposition in the CAD model and hope that it'll fit in the end. But at this stage I prefer to rather build one piece at a time and to make shure everything fits because there is always the possibility of human error when using a manual mill.
And I got a taste of that human error at this stage. This is the piece that is supposed to connect the heatpipes to the heatsink. The plan was to make two similar pieces. But tired as I was, I managed to screw up the holes on one of the pieces so I only managed to finish one of them. ![]() (CLICK TO ZOOM) Here is the screwed up piece, holes are shifted 3mm to the right and I didn't noticed until after. But anyway I show this because I didn't take a picture of the good piece at this stage. ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) The initial plan was to have the bottom sliced part threaded and therefore the top part would clamp down when screwed. But I realized that since the bottom sliced part is actually thinner under the hole and tightening the screw will only result in the bottom piece bending upwards instead of the top. The contact surface wouldn't therfore be totaly flat. So I decided to make the threaded hole in the heatsinkplate instead. A long description for a tiny thing.. but anyway.
__________________
#106 |
Folding@Home CC Captain 2010/11/12
Awesome work!!! Will be awaiting the finish
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ | |
#107 |
Rebirth of S-K-Y-N-E-T
Pah stop doing such a nice job lol no really lookin awsome bubbah
#108 |
Keep calm & mod on. =)
Must be awesome being able to make your own heatsinks & it certainly looks mighty fine ![]() |
#109 |
Supermodder
This is looking so good! I wish i had the machining skills/the opportunity to do something like this!
#110 | ||
8-bit addict
Thanks
![]() Quote:
Thanks.
__________________
#111 |
#112 |
8-bit addict
Haha thanks.. they'll get their own log here for shure. But I'll have to finish the current projects before I start something new. Wouldn't have started this one if it wasn't for it being so small, in contrast to some of the other ideas.
__________________
#113 |
Cad Pro Quo
Very nice. I like the simplistic-ish clamps. I would have done something like this:
_/\_ On both sides and then clamped the two together (if you follow that in the least). Edit: Seriously this forum hates having letters with multiple spaces in between. Argh!
__________________
Completed: Acronym Last edited by Achron; 6th Jan 2011 at 05:57. Reason: Can't draw. |
#114 | |
8-bit addict
About your idea, do you mean to mill down the top pieces to make them flex more? Somewhat similar to what I did with the CPU cover in this pic: ![]() BTW. Anyone got any info regarding my touchbutton question in bottom of post #96? Basically, will an anodized surface work as the direct contacting surface for a touchbutton? I'm assuming that the non conductive properties of the anodized surface will not make it possible, but I've never played around with DIY touchbuttons so I can't confirm this.
__________________
Project: ProtoHype (paused) Project: GET A LIFE (Complete) Project: Widescreen Projector(Complete) Guide: How to brush Aluminum Last edited by The_Gnu; 6th Jan 2011 at 10:33. |
#115 |
I know what a dremel is...
Very nice work so far!
Why didn't you use copper for the blocks? |
#116 |
LOLS I TROL YOU
Copper is very expensive, Aluminium is easier to machine and more cost effective. and he'll be anodizing it, you can't anodize copper AFAIK
#117 | |
That 's why it's used by manufactures at the blocks. Also copper can be chromed. Another advantage is that you can solder the copper block and the heatpipes in order to achieve better transfer of heat, better than using thermal paste. |
#118 | ||
8-bit addict
Yes I could have used copper for the heatpipe blocks, you are right, and I was thinking of doing this. But I have no place to buy copper and the only copper I have was to small for the CPU block. So I decided to save it for the CPU and GPU blocks of my ProtoHype project. Soldering the pipes would have been the best I agree, but I hope that thermalpaste and alu will do fine for the pretty low heat output of this mboard. Thanks for the feedback
__________________
#119 |
I said intuitive, and now we have precision drilling, detail and heatpipes! Have lots of rep.
__________________
#120 | |
8-bit addict
__________________
| Tags |
| aluminium, godly nostalgia bomb, heatpipe, htpc, mill, mini-itx |
| Thread Tools | |
| View Mode | |
