#121 |
The Artist Formerly ATi_Loyalist
Looking most excellent my friend!
__________________
Visit The Sanatarium for more madness! Current Project: 1925 - An Art Deco Adventure |
#122 |
8-bit addict
Thanks a lot
Btw.. its ben a while since your last update. I'm eagerly waiting for your next update.
__________________
Project: ProtoHype (paused) Project: GET A LIFE (Complete) Project: Widescreen Projector(Complete) Guide: How to brush Aluminum |
#123 |
8-bit addict
Got some more work done in the workshop this weekend. First off I had to make another one of the heatpipeblocks I made last update since I failed on one of them. So now I finally have two. And later on you'll se some drilling of the backplate.
![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) The following photas are just to test the alignment of the different parts. Nothing is screwed tight at the moment. ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) I read in Hannes thread here on the forums that he had used a monitor as lighting. I had to give it a shot and here's my litle attempt at making a new photobooth. My computer monitors are mounted on swiwel arms and I just rotated them 90 degrees and displayed some white background and woohoo all those nasty shadows are gone. Works pretty good for these smaller pieces atleast. ![]() (CLICK TO ZOOM) Also played around a bit with some colors in the CAD program and this is how the cooler most likely will look like in the end. ![]() (CLICK TO ZOOM) Hope you like it
__________________
#124 |
man it's all harder than it looks
SO COOL
#125 |
Hypermodder
This is looking too sweet. I never thought of the monitor idea. Very original. I finally broke down and bought two softboxes off of Ebay to use for taking pics. I may still pick up a smaller light tent for stuff like this.
__________________
Previous Project: Zenith Antique Radio Scratch Build Current project: Project Quintessence |
#126 |
8-bit addict
Thanks
![]() Thanks. I would like some real softboxes/tent aswell since the monitors aint that superbright. But I think my weakest link is my cam at the moment since Im still using an old compact cam.
__________________
#127 |
Keep calm & mod on. =)
Crazy awesome
#128 |
8-bit addict
__________________
#129 |
Modder
I think i want one
this case is going to be sweet and i cant wait to see its done
#130 | |
8-bit addict
__________________
#131 |
Making You Feel Old Since 2010
I don't think you should have colours, the clean, smooth look is way too cool to not keep.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#132 |
8-bit addict
No colours? Then I don't think it'll be obvious that it's a mushroom. It would more look like..uhm.. a bunch of cubes.
__________________
#133 |
8-bit addict
Time to show what has been done lately. All the 20 heatsink parts need to be mounted on to the heatsink plate. Therefore I need to drill holes in each piece an also thread these holes manually. As you might guess this took a while since there is more than 50 holes, and since this procedure is pretty repetitive I cut down on the action pictures.
![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) It feels really go to be able to start mounting stuff even though this is only a testmount to check the alignment of the holes. Here you can see the mushroom outline and all the "spots" mounted using M3 hex screws. ![]() (CLICK TO ZOOM) The rest of the parts mounted aswell. Note that the parts are not aligned perfectly since this is only a test, and some of the cubes might look out of place. ![]() (CLICK TO ZOOM) ![]() (CLICK TO ZOOM) You might have noticed that the heatpipes are mounted in this last picture. I will show you that in the next update since there is still some more work to be done on the backside. *off to dig some 8-bit tunes*
__________________
#134 |
Topiary Golem
It really looks like you're building some kind of a satellite death ray device! I must confess I'm trying to skip all the text in your build. Just watching the pics unfold is sending nice jolts down my spine. What will he do next?
__________________
Project: Seawolf Project: 1 Project: Flux (est 2012) Modders make project logs. Project logs make mods. Mods make modders.
#135 |
That's a lot of tapping especially in thick alu
, shame white anodising can't be done but it could look great polished up or even just silver anodise, still really looking forward to seeing the finished piece & it would have to be the coolest looking heatsink ever .
#136 | ||
8-bit addict
![]() Nice to hear you like the moment of surprise, since that is kind of the plan. Att first I intended to show some proper sketches and renders of the finsihed piece, but decided not to since I guess It might have ruined some of the fun. Quote:
__________________
#137 |
what was dat sandvich ?
this looks really awesome !
i still don't understand how the rest of the case is going to look like though :worries:
__________________
My deviantart page : link Battlefield 3: Mindrusted My computer : Link |||||||||
#138 |
Hypermodder
This is looking awesome. Very nice work.
__________________
#139 | |
8-bit addict
Thank you very much der woodmeister
__________________
#140 |
I still stand by my choice of no colour, but this looks great. Non nom nom.
__________________
| Tags |
| aluminium, godly nostalgia bomb, heatpipe, htpc, mill, mini-itx |
| Thread Tools | |
| View Mode | |
