Reply
Thread Tools View Mode
Old 18th Jan 2011, 21:23   #141
lakisss
I know what a dremel is...
lakisss's Avatar
lakisss has yet to learn the way of the Dremel
I have to say that i have doubts about the final result.
I think that the heatshink wiil work better in horizontal position than in vertical.
lakisss is offline   Reply With Quote
Old 18th Jan 2011, 23:02   #142
The_Gnu
8-bit addict
The_Gnu's Avatar
The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.
Originally Posted by KidMod-Southpaw View Post
I still stand by my choice of no colour, but this looks great. Non nom nom.
thanks.. and sticking to your opinion is only a god thing
Yes maybe your right about that. But by putting it vertical themboard will be placed below the heatsink and I hava a feeling that this might entrap the heat and heat up the heatsink from below. However, It's easy to find out once I get it up and running since I only need to flip it over. Eitherway, this case is designed to be horizontal but I will make some tests for shure.
__________________
Project: ProtoHype (paused)
Project: GET A LIFE (Complete)
Project: Widescreen Projector(Complete)
Guide: How to brush Aluminum
The_Gnu is offline   Reply With Quote
Old 24th Jan 2011, 19:42   #143
The_Gnu
8-bit addict
The_Gnu's Avatar
Hello again. So.. now things are really comming together. Today it's time for a test run. But before that. I will show you whats been done since last update.
First of is the heatsink plate, here you see the threaded holes to that the heatpipe blocks will be mounted to.
(CLICK TO ZOOM)
I also needed to clean up the edges of all the other holes. Done by hand with this tool.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
This is the backside of the plate and since this is the place were all the screw heads willl be, I decided to countersunk the holes to make the screws flush witht the rest of the plate.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
The countersinking resultet in the screws being to long. Since I couldn't find the right size in any store around, I took some long ones and milled them down.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
Since this is only a testing of the cooling I didn't want to smear thermal paste all over the parts since that would have cost a lot. Instead I used a small amount of regular cooking oil. I the final mounting I will use real thermal paste. Deffinetly not the best solution but atleast it's better than nothing.
(CLICK TO ZOOM)
I Found these motherboard stand offs in my box of goddies, I think they were delivered with the zotac mboard but I'm not shure. Anyway the mboard holes interfered with some of the other holes on the heatsink so I had to make these small pieces that allso acts as spacers.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
I also fabricated 2 more blocks for the heatpipes. Same procedure as the previous blocks.
(CLICK TO ZOOM)
I also added two more mountingholes in the middle on the previous heatpipeblocks.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
(CLICK TO ZOOM)
I really like these mboard fasteners.
(CLICK TO ZOOM)
(CLICK TO ZOOM)
The moment of truth has come. It's time to power this thing on. Above you can see the current setup, in all it's standard desktop testing fashion.
The knife?? it's the powerswitch.
So I turn it on and then....nothing happens, not a single sign of life.
Crap is my first thought, I mentaly start to go through all the steps to see if there is anything I forgot. I fear the worst that I somhow killed the mboard by static or something. Suddenly a desktop pops up on the screen. YAY...It works!!
I had totally forgot that I had built a deadsilent pc I was expecting some kind of noice but now there was only silence to be heard.
It's currently running fine next to me and I'm measuring the temps of to see how well the heatsink performs. I will show the results once I get some nice and stable temps
__________________
Old 24th Jan 2011, 19:48   #144
KidMod-Southpaw
Super Spamming Saiyan
KidMod-Southpaw's Avatar
KidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming Saiyan
I sense epicness in the air...
__________________
Project Logs: Refraction - Steampunk Flash Drive - Steel; Sleek; Slate
BitFenix Prodigy - Gigabyte Z87N - Intel 4670K - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - M4 128GB - WD Red 1TB X2 - H60 - Antec 650W - Dell U2312HM - Poker MX Red - Sennheiser HD 598
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 24th Jan 2011, 19:50   #145
Nealieboyee
Packaging Master!
Nealieboyee's Avatar
Nealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming Saiyan
LOL. Sigh of relief ey? Looks awesome so far!
I want temps!
__________________
CLARISSE
G4560 | Gigabyte GA-H110M-S2H | 8GB Kingston HyperX | GTX550ti | Sandisk Plus 120GB | Corsair CX430 | Cooler Master Hyper 212 PLUS
Nealieboyee is offline   Reply With Quote
Old 24th Jan 2011, 19:56   #146
The_Gnu
8-bit addict
The_Gnu's Avatar
Haha thanks mate, I prefer that much more than something burned in the air.
I want temps!
Yeah you bet..
Thanks
The temps are rising but it's looking promising so far
__________________
Old 24th Jan 2011, 20:02   #147
zukomonitor
assumption is the mother of all....
zukomonitor's Avatar
zukomonitor has yet to learn the way of the Dremelzukomonitor has yet to learn the way of the Dremel
Looks amazing!
post the temps!!!!
gettin closer to the finish
__________________
i5 760 @ 3.6ghz |GA P55m-UD4 | Corsair XMS3 | Gigabyte GTX 460oc | Thermaltake Frio | Antec Truepower new 650 PSU | 160GB WD Blue hdd | Samsung DVDR | CM 690 II advanced | Win 7 Pro 64bit
zukomonitor is offline   Reply With Quote
Old 24th Jan 2011, 20:03   #148
KidMod-Southpaw
Good idea, how fast are temps rising? Oh, that's me sweating...
__________________
Old 24th Jan 2011, 20:04   #149
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Happens to me with my Zotac aswell every so often, when I forget to turn on the screen.
Immediately I think... WTF? Is it dead yet?
Damn those deadsilent systems
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 24th Jan 2011, 20:11   #150
The_Gnu
8-bit addict
The_Gnu's Avatar
Originally Posted by zukomonitor View Post
Looks amazing!
post the temps!!!!
Thanks..
easy now.. im trying to sumarize the temps.
Haha nice. Well the temps rose pretty fast in the beginning of the test but seems to starting to stabilize at the moment. I'm trying to make some nice charts.
Yeah I can totaly see this as a future problem. I will definetly need to incorporate som LEDs or something
__________________
Old 24th Jan 2011, 20:11   #151
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
I really hope the temps stabalise to a good temp, this project is too awesome to be let down by that, fingers crossed .
The silence would be odd for a pc but an awesome welcome .
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Last edited by Waynio; 24th Jan 2011 at 20:12. Reason: :D The silence would be odd for a pc but an awesome welcome :).
Waynio is offline   Reply With Quote
Old 24th Jan 2011, 20:15   #152
KidMod-Southpaw
Silent PC's are great, yes. Time for more overkill and more heatpipes!
__________________
Old 24th Jan 2011, 20:17   #153
The_Gnu
8-bit addict
The_Gnu's Avatar
Thanks.. mee too. Maybe youv'e also noticed that there is only 3 heatpipes in the current setup. The 4th heatpipe will be put on the back of the case (not made yet) so there will be even more surface area in the finished setup.
__________________
Old 24th Jan 2011, 20:23   #154
Waynio
Relaxing
Waynio's Avatar
Good stuff bet you can't wait to see it anodised, I know I can't .
__________________
Old 24th Jan 2011, 20:24   #155
KidMod-Southpaw
Defo. Gotta love alu!
Edit: Aluminium- WTF? Wait, what material is it again?
__________________
Old 24th Jan 2011, 20:38   #156
lakisss
lakisss's Avatar
Excellent so far!
I 'm waiting for your temps too, in vertical and horizontal position.
Question: What is this hole for?
I think you should insulate the mobo from the aluminium heat on the back, especially here where they get too close:
About static electricity:
You must connect the heatshink with the case through a ground wire when you finish.
Old 24th Jan 2011, 21:12   #157
The_Gnu
8-bit addict
The_Gnu's Avatar
So true. I spoke to the anodizer last week and he told me he had the colors and would gladly help me. Just to stop by when I'm ready.
Yep, Aluminium all the way.
Excellent so far!
Thanks for your nice pictures. I will try the case in horizontal position tomorrow. It'll be nice to see if theres a difference.
The hole your pointing at is for the 4th and last heatpipe. At first I planned to have this under the mobo as the three others but decided to have it above the mobo instead. It will connect to the aluplate that will encase all the components on the backside and complete the case. This way I will get even more surface area to disipate the heat.
About the insulation: I don't think I will need to insulate because of the heat but I will put a layer of thin plexi or similar just to make shure the mobo don't short with the heatsink blocks.
The mobo is already grounded to the heatsink with the mobospacers so I won't need any more wire.
__________________
Old 24th Jan 2011, 21:16   #158
KidMod-Southpaw
Walk to the andoniser, or I'll chase you down there!
__________________
Old 24th Jan 2011, 23:23   #159
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
O M G this is so f-ing epic man!!!!
While I was scrolling down the page and reading I was telling my self, temps, temps, temps,
where are the temps!??!?!
I will be patient and I will wait for more awesomeness!!!! Mod on bro!
AnG3L is offline   Reply With Quote
Old 24th Jan 2011, 23:49   #160
The_Gnu
8-bit addict
The_Gnu's Avatar
Haha I bet you would.
Thanks mate I was about to post them but I had some problems with exel since I want to create a nice little chart. But Im trying to solve it and hope I can post it before the night.
__________________
Reply
Tags
aluminium, godly nostalgia bomb, heatpipe, htpc, mill, mini-itx
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
