Reply
Thread Tools View Mode
Old 24th Jan 2011, 23:02   #161
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Originally Posted by The_Gnu View Post
Thanks mate I was about to post them but I had some problems with exel since I want to create a nice little chart. But Im trying to solve it and hope I can post it before the night.
Will be interesting to see, if you achieve the same temps as I do with a Scythe S-Flex @ 800RPM (this fan is totally inaudible from one meter away of it) blowing on the heatsink.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 24th Jan 2011, 23:26   #162
lakisss
I know what a dremel is...
lakisss's Avatar
lakisss has yet to learn the way of the Dremel
Something important: When you post the temp results, tell as and the ambient temp.
lakisss is online now   Reply With Quote
Old 24th Jan 2011, 23:28   #163
The_Gnu
8-bit addict
The_Gnu's Avatar
The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.
Nice to have some reference material
Yes, I'll be doing that
__________________
Project: ProtoHype (paused)
Project: GET A LIFE (Complete)
Project: Widescreen Projector(Complete)
Guide: How to brush Aluminum
The_Gnu is offline   Reply With Quote
Old 25th Jan 2011, 00:26   #164
The_Gnu
8-bit addict
The_Gnu's Avatar
Okay. Finaly got my temp chart done.
I think the results are pretty decent. It proves that the heatsink is atleast cooling. There is still improvements to be made on the cooling, like ditching that cooking oil on all the heatsink parts and replacing it with real thermal paste. And I also need to add the last heatpipe that will use the rest of the case for cooling.
I base the CPU temps on the "Core#0" value from CPUID. For a reference, the values of the stock cooler with no fan in idle was Core#0=65°C and GPU core=59°C. I assume that the reason for the start temp being lower than ambient temp is because some kind of "standard value" of the tempcalculations, but maybe some of you guys can confirm this.
Well here you go, CPU seems to stabilize at around 45°C and GPU at 43°C
It seems like it takes about 2hours for the temperature to reach peak lvl. I will continue on with my load meassuring tomorrow.
Btw, anyone know of a program that takes meassures and makes it own graph over a long time? I've tried speedfaan but I can only measure for 12m or something.
__________________
Old 25th Jan 2011, 01:15   #165
sixfootsideburns
modeteer
sixfootsideburns has yet to learn the way of the Dremelsixfootsideburns has yet to learn the way of the Dremel
very... very... impressive. When your finished (with your permission of course) I'l love to post a picture that me and a buddy did with bottle caps that is also a Mario Theme. I think it could compliment your finished project quite nicely
but of course, this is your show and if there is any risk of taking your spot light I don't want to post it. This is just so freaken awesome!
sixfootsideburns is offline   Reply With Quote
Old 25th Jan 2011, 01:38   #166
jrs77
theorycrafting
jrs77's Avatar
Well, my thingy runs at around 35°C (GPU/CPU) with that same ambient of 25°C and rises to some 65°C when under load in a well ventilated case ofc.
That's about the same as with the standard 60mm-fan @ 3000RPM directly attached to the heatsink.
45°C isn't too shabby for totally passive cooling in this "unfinished" state tho and if you can keep it under 80°C under laod, then your setup is actually excellent for a passive cooling setup.
I tried to run the board completely without a fan aswell, and it was still stable under load, allthough temps got up to some 95°C.
Nicely done at the first glance I'd say
__________________
Old 25th Jan 2011, 06:44   #167
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
Well done! Sounds good so far, some silver 5 and a 3rd heatpipe will make a world of difference.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is online now   Reply With Quote
Old 25th Jan 2011, 07:26   #168
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on you
Oh man, that's totally sick.
__________________
stonedsurd is offline   Reply With Quote
Old 25th Jan 2011, 07:58   #169
Cosmot
Banned
Cosmot has yet to learn the way of the Dremel
thanks. its very great.
Cosmot is offline   Reply With Quote
Old 25th Jan 2011, 09:58   #170
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
This is insane man really really nice job!!!!
AnG3L is offline   Reply With Quote
Old 25th Jan 2011, 10:13   #171
Mattmc91
LOLS I TROL YOU
Mattmc91's Avatar
Mattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run Crysis
sell me it!
Mattmc91 is offline   Reply With Quote
Old 25th Jan 2011, 11:23   #172
perplekks45
LIKE AN ANIMAL!
perplekks45's Avatar
perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far.
ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
Iä! Iä! Cthulhu fhtagn!
perplekks45 is offline   Reply With Quote
Old 25th Jan 2011, 11:44   #173
The_Gnu
8-bit addict
The_Gnu's Avatar
Thanks a lot, bottle caps sounds nice would love to see that
Thanks for showing your temps. I also tried to run the stock cooler without any fan under load in the beginning. I decided to abort when the temps got to 80°C since they were still rising. I guess It might have reached 95 aswell.
Thanks
Thanks. Yeah I think There will be some improvements once this is done.
Thanks a lot guys
Originally Posted by Mattmc91 View Post
sell me it!
It's all a matter of figures
Originally Posted by perplekks45 View Post
HAHA
BTW: Im starting to meassure the load temps at the moment.
__________________
Old 25th Jan 2011, 12:00   #174
jrs77
theorycrafting
jrs77's Avatar
As far as I know, the CPU does an emergency-shutoff at 105°C core-temperature. These Atom-CPUs are really well made actually and intel specifies them with 85°C TCASE.
Lot's of people clocking the Atom 330 @ 2GHz as it has alot of headroom there when using the standard-cooling-solution. But hey... it's a chip with 8 Watt TDP to begin with
And for the ION-chip I found this info...
The ION chipset throttles its clock rate when it's getting too hot, so it seems to never exceed the 95°C. The throtteling begins at approx. 92 degrees - and if it's throttled, you need to reduce temperature to about 82 degrees to get full speed again.
So yeah. If your cooling-solution keeps the temperatures under 80°C at full load for CPU-cores and GPU/chip-core, then you won't see any troubles there.
__________________
Old 25th Jan 2011, 20:20   #175
The_Gnu
8-bit addict
The_Gnu's Avatar
Thx a lot for that info jrs77. I will definetly play around with the fsb to se what result I might get. I don't think I need to worry about reaching that 92°C throttel line
I've done some load testing today. I used prime95 and FurMark to stresstest both CPU and GPU at the same time. The results you can see below, I incorporated yesterdays Idle temp measures in the graph. The setup has been running for almost all day and I think it's safe to say that the temps are stable att 55°C. It took around 2h for the temps to reach the higest lvl, same as in idle mode.
I had planed to test the setup in a horizontal position aswell but that will be the task for tomorrow. I hope you liked the results as I have to say I'm pretty satisfied.
__________________
Old 25th Jan 2011, 20:24   #176
Wicked_Sludge
My eyes! The goggles do nothing!
Wicked_Sludge's Avatar
Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.
those temps are amazing! congrats!
__________________
My Rig:
Gigabyte GA-P55A-UD3|Intel Core i5 750 @ 4.0Ghz|12GB G.Skill Ripjaws DDR3 1600|XFX HD5870|2x Barracuda 1TB RAID 1
Fiancées Rig:
Gigabyte GA-P67A-UD3|Intel Core i5 2500k @ 4.0Ghz|12GB Corsair XMS3 DDR3 1600|XFX HD5770 Xtreme|Samsung F3 1TB
Wicked_Sludge is offline   Reply With Quote
Old 25th Jan 2011, 20:43   #177
jrs77
theorycrafting
jrs77's Avatar
Awesome temps you got there
I think it's safe to say, that your setup is a winner
__________________
Old 25th Jan 2011, 21:03   #178
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Woo hoo so it's gonna look awesome, have character, perform nice & with silence , excellent work GNU . +rep
Waynio is offline   Reply With Quote
Old 25th Jan 2011, 21:15   #179
The_Gnu
8-bit addict
The_Gnu's Avatar
Thanks guys I'm more than happy with the temp results so far. I think it's time to play with the fsb a little
__________________
Old 25th Jan 2011, 21:40   #180
TimtomNL
What's a Dremel?
TimtomNL has yet to learn the way of the Dremel
Wow this looks very nice and the temps are quite impressive!
TimtomNL is offline   Reply With Quote
Reply
Tags
aluminium, godly nostalgia bomb, heatpipe, htpc, mill, mini-itx
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
