Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Nov 2010, 14:46   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
Fractal Design Define XL Review
We loved Fractal's Define R3 case but will the super-sized XL version be a class act?
http://www.bit-tech.net/hardware/cas...ne-xl-review/1
Claave is offline   Reply With Quote
Old 19th Nov 2010, 14:50   #2
memeroot
aged and experianced
memeroot has yet to learn the way of the Dremelmemeroot has yet to learn the way of the Dremelmemeroot has yet to learn the way of the Dremel
looks nice though
memeroot is offline   Reply With Quote
Old 19th Nov 2010, 15:04   #3
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
I wonder what sort of a difference another 140mm fan would make in the uppermost mount.
Pity Fractal didn't include this fan given the poor stock CPU performance.
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 19th Nov 2010, 15:13   #4
Ljs
Mod Master
Ljs's Avatar
Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.
"so instead of a single 120mm intake fan there’s room for two 140mm intake fans"
Doesn't the R3 have room for two 120mm fans at the front?
Ljs is offline   Reply With Quote
Old 19th Nov 2010, 15:56   #5
SlowMotionSuicide
Come Hell or High Water
SlowMotionSuicide's Avatar
SlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for president
About a bloody time someone actually saw the case. Shame about performance, and also shame this case isn't still available even though Finnish retailers have had it listed for about 2 months now. I got tired of waiting, so I got myself a nice fat 800D instead.
Hope they bring out something in mATX next.
__________________
G3258 @ 4.3GHz | MSI Z97 Gaming 5 | 8Gb Dominators | GTX 660 | Crucial MX100 256GB | F1 Spinpoint 1TB | Seasonic P-760 (XP²) | NZXT H440W
SlowMotionSuicide is offline   Reply With Quote
Old 19th Nov 2010, 16:12   #6
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
so its bigger and not better. Shame cos it has the potential to be so good
bulldogjeff is offline   Reply With Quote
Old 19th Nov 2010, 16:40   #7
Paradigm Shifter
de nihilo nihil fit
Paradigm Shifter's Avatar
Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.
I can't help but think this could do with growing about an extra inch taller, and using that increase to put a bit more space between the bottom of the mobo and that internal division...
__________________
Core i7 5820K | 32GB Crucial DDR4 | Asus Rampage V Extreme | Titan X | 1TB SSD + 6TB HDD | 7680x1440 + 1920x1200
Paradigm Shifter is offline   Reply With Quote
Old 19th Nov 2010, 17:49   #8
Lazy_Amp
Entry AMD Engineer
Lazy_Amp has yet to learn the way of the Dremel
Yeah, since both CPU case fans are exhaust, probably not very great there.
All these with big top exhausts would probably do pretty well with a H50 pulling hot air in.
I think the angle on the top... probably doesn't help at all...
Lazy_Amp is offline   Reply With Quote
Old 19th Nov 2010, 19:31   #9
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn has yet to learn the way of the DremelHourBeforeDawn has yet to learn the way of the Dremel
I have to admit I like Fractals cases.
__________________
Current Rig: Project STEALTH
• DimasTech Test Bench • Black ICE Triple 120 Rad • Dual Bay Res/Pump • DD Fill Port & Res • D-Tek FuZion 2 CPU Block • ASUS M3A79-T Deluxe Mobo • AMD Phenom II 3ghz @ 4ghz • 8gb DDR2-1100 Memory • (2) AMD 6870 XFire • (2) WD Black 640gb Raid 0 • (2) 1.5TB SEAGATE • Blu-Ray/HD DVD Drive • ASUS XONAR DX2 • 30" DOUBLESIGHT LCD • (2) 23" ASUS LCD • ZALMAN 8 FAN CONTROLLER • (4) NOCTUA P12 • (2) NOCTUA P14 • 1000W ZALMAN PSU • WINDOWS 7 PRO 64 •
HourBeforeDawn is offline   Reply With Quote
Old 19th Nov 2010, 19:42   #10
The_Beast
I like wood ಠ_ಠ
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
If it wasn't for that stupid side panel fan I'd buy about 12
I really ruins the look
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 19th Nov 2010, 21:12   #11
Skill3d
Multimodder
Skill3d has yet to learn the way of the Dremel
Guys fix your "s" key... There seem to be missing lots of s's in the article...
Skill3d is offline   Reply With Quote
Old 20th Nov 2010, 00:08   #12
Phoenixlight
Modder
Phoenixlight's Avatar
Phoenixlight has yet to learn the way of the Dremel
What side panel fan? From the pictures it doesn't look like there is one. I like the look of the case overall and GPU cooling is more important that CPU cooling because you can always buy a cheap aftermarket cooler for a CPU, you can't do that for a GPU though so it's not bad.
Phoenixlight is offline   Reply With Quote
Old 20th Nov 2010, 01:15   #13
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
Looks like a natural evolution from the P180/P182... without the stupid extra sticky outy bits.
Mankz is offline   Reply With Quote
Old 20th Nov 2010, 07:09   #14
IanW
Grumpy Old Git
IanW's Avatar
IanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming Saiyan
I think Beast means the fan cutout shown in this pic:-
__________________
i7 4770K@3.9GHz / Corsair H100i / Asus Maximus VI Gene / 16GB Corsair Vengeance 2133 /
Asus Strix GTX1080 Advanced / 500GB Samsung 840 Evo / 1TB Sandisk SSD / BeQuiet! 1kW /
Thermaltake Core V21 / Dell U2713HM / Corsair K70 RGB / Logitech Performance MX / Win10 / Kubuntu 17.04
IanW is offline   Reply With Quote
Old 20th Nov 2010, 09:31   #15
okenobi
Ultramodder
okenobi's Avatar
okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.okenobi is definitely a rep cheat.
Is it me, or do E-ATX cases just suck for cooling (pun intended)? The ATCS840 review similarly blames the cavernous interior for ruining airflow from the intakes to the hot stuff. Makes you wonder if they're useful for anything other than servers....
okenobi is offline   Reply With Quote
Old 20th Nov 2010, 10:43   #16
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
This. I love the way it looks, I want to watercool one but the side panel is very off-putting. Shame.
__________________
stonedsurd is offline   Reply With Quote
Old 20th Nov 2010, 10:50   #17
azrael-
I'm special...
azrael-'s Avatar
azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!
At least this time they seem to have managed to have identical case feet all the way round...
__________________
It's not the end of the world ...but you can see it from here.
Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA
azrael- is offline   Reply With Quote
Old 20th Nov 2010, 10:53   #18
xaser04
Ba Ba Ba BANANA!
xaser04's Avatar
xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.
Yep, 2x 120mm just like the R2.
Would a HD5970 (and presumably the equally large HD6990) actually fit in this case? It looks to be a bit of a squeeze with a HD5870 (Just like the R2/R3).
__________________
Daedalus - Clevo P170SM | i7 4700MQ | GTX780M 4GB | 16GB DDR3 | 17.3" 1920x1080 |
ZPM HIVE Mini - Fractal Node 202 | i7 4770S | GTX1070 | 8GB DDR3 | Dell 1440p G-Sync |
Consoles / Retro - PS4 Pro | PS4 | Xbox One x2 | Dreamcast x2 (VGA) | WiiU | Retron5 |
xaser04 is online now   Reply With Quote
Old 20th Nov 2010, 13:47   #19
Material
Soco Amaretto Lime
Material's Avatar
Material is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpitMaterial is almost as Godly as yodasarmpit
Yes you're correct on this, that's my bad, I've fixed it in the review.
Material is offline   Reply With Quote
Old 20th Nov 2010, 13:51   #20
Material
Soco Amaretto Lime
Material's Avatar
Believe it or not we actually answer this in the review
Originally Posted by The Article
we could fit an ATI Radeon HD 5970 2GB in the case even with the caddy in line with the fan
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
