#41 | |
The Emy Charger
How do I get the light effect on the entire fiber? |
#42 | |
Modder
TIR is total internal reflection, the process by which the light light can travel down the fibre via reflecting off the internal surfaces. You will need to remove all the cladding and coating to get the side glow effect. I would recommend you use plastic optical fibre (POF) as it firstly much bigger in general and is far more forgiving. Alternatively you can google 'plastic optical fibre side glow' and find a local source. Regards Ed |
#43 |
Poor student
Wow, this is very artistic! Love your attention to detail!
#44 |
Keep calm & mod on. =)
That's really useful info k4p84 thanks.
repFor anyone who hasn't seen his Lord of the Rings castle project, it really is a must see, flipping amazing & it's complete. ![]() http://forums.bit-tech.net/showthread.php?t=142915 |
#45 |
Ultramodder
WOW.
__________________
Main: Q6600|4gb OCZ Flex II|Asus P5Q|Antec P190|EVGA 460OC 768mb HTPC: Q6600|4gb|Gigabyte G31 Mobo|Coolermaster Elite 360|Sapphire ATI 5450 512mb |
#46 |
Modder
#47 | |
The Emy Charger
#48 |
The Emy Charger
Proceed slowly due to a problem with fiber optics, sanding it not give me a satisfactory effect lighting level, anyway I wired the first led Strip on the first branch ...
![]() ![]() ![]() ![]() And then today I went to withdraw the plexiglass for my liquid cooling tubs ..... ![]() Bye bye....... |
#49 |
Supermodder
oooh... shiny!
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#51 |
The Emy Charger
Waiting for the bundle of optical fibers with side lighting from China ... ... I dedicated to pools for liquid cooling. Here are the cuts:
![]() ![]() ![]() ![]() ![]() Now we're going to glue the first pieces to the Bowl containing my action figure Jack Sully ... ... ![]() I later realized tubes of inlet and outlet of the bath great ..... ... ![]() Now we practice holes on the Central cylinder ... ... ... and the subsequent application of little tubes ... ... ![]() ![]() ![]() Here's the finished work in respect of the first Assembly of the pieces of the tanks ..... ... ![]() ![]() ![]() Stay tuned........ |
#52 |
Supermodder
Are you going to use led strips for the branches or optic fibre? IMO optic fibre fed from a rgb light source would be better.
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
#53 |
The Emy Charger
Until I get the optical fibers with lateral lighting, I finished the large tub, one that will go under the tree. After doing the hole I threaded with a tap from 1/8 to seat the hose (commonly used for wash basin mixers), which will have the task to let
the liquid inside the tank ... ... ... ![]() ![]() Water tightness test and subsequent discharge when the wired valve at the bottom of the flexible tube... ![]() One of the two plugs that will block the hole filling and bleeding ..... ... ![]() ![]() Final closing of the bowl .... .... ![]() Ciauzzzzz. |
#54 |
Beyond Complexity Lies Simplicity
Nice ! Awesome creativity ! Subbed for sure !
PM me if you went for side glow and want to get rid of the ikea strands you've got ! I could use them for my new build !
__________________
Current Build : BORG COSMOS II Current build : 2001 - A Case Modyssey Finished build : IMPERIAL AT-AT Finished Build : USS EURISKO - Intrepid Mark II Class www.asphiax.wordpress.com |
#55 | |
The Emy Charger
Surely I will use one part, but will remain as much fiber as that of Ikea, when you will contact me .... ... I'll give what you need. |
#56 |
The Emy Charger
New up. .. .... today I am dedicated to the support of the pan containing Jake Sully, I used the wood since it has good machinability, then I already had at home and the thickness was perfect ... ... .... Seeing a screen shot of the movie I started to draw the shape ... ...
![]() After being cut with the jig saw I took measurements of the three holes of the Pan and precisely at the Center and on the sides, that of entry and exit ... ..... and I scored the wood to make the next cut ... .... ![]() ![]() ![]() ![]() Now at the openings on wood a centered point wood and after to pierce the plexiglass ... ... ... ![]() ![]() ![]() ![]() ![]() At this point, as in the first tank with small tubes of plexi, I go to paste them into their housings to inlet and outlet .... ... ![]() ![]() Then after the two fill holes and vent, I closed the tray with my Jake waiting for watertight test. ..... ![]() ![]() Stay tuned........... |
#57 |
Looking forward to what comes next & have been & will be doing all the way, what you are doing looks extremely ambitious.
#58 |
Supermodder
Love the avatar hybernation growth chamber thingy
__________________
#59 |
The Emy Charger
Pan test OK .... ....
And fiber optics to side lighting arrived ... ... ![]() ![]() And now at work!!!!!!!!! |
#60 |
Hi
Wow. Just wow. This Blew me away. If you can pull this off, it will be amazing. Nice idea with the Avatar hibernation thing, is that going to be the reservoir?
Keep Up the awesome modding, and subbed. - Dan
__________________
Rawr |
| Thread Tools | |
| View Mode | |
