Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 24th Nov 2010, 16:10   #1
Lizard
@ Scan R&D
Lizard's Avatar
Lizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run Crysis
OCZ launches Blade 2, XTE RAM
OCZ has announced two new RAM series, the performance Blade 2 and low-profile XTE.
http://www.bit-tech.net/news/hardwar...de-2-xte-ram/1
Lizard is offline   Reply With Quote
Old 24th Nov 2010, 18:09   #2
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn has yet to learn the way of the DremelHourBeforeDawn has yet to learn the way of the Dremel
AWESOME this is great to see and cant wait to some testing done with this memory down the line.
__________________
Current Rig: Project STEALTH
DimasTech Test Bench Black ICE Triple 120 Rad Dual Bay Res/Pump DD Fill Port & Res D-Tek FuZion 2 CPU Block ASUS M3A79-T Deluxe Mobo AMD Phenom II 3ghz @ 4ghz 8gb DDR2-1100 Memory (2) AMD 6870 XFire (2) WD Black 640gb Raid 0 (2) 1.5TB SEAGATE Blu-Ray/HD DVD Drive ASUS XONAR DX2 30" DOUBLESIGHT LCD (2) 23" ASUS LCD ZALMAN 8 FAN CONTROLLER (4) NOCTUA P12 (2) NOCTUA P14 1000W ZALMAN PSU WINDOWS 7 PRO 64
HourBeforeDawn is offline   Reply With Quote
Old 24th Nov 2010, 21:03   #3
flibblesan
Destroyer
flibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpit
that's one funky looking comb.
flibblesan is offline   Reply With Quote
Old 24th Nov 2010, 22:00   #4
llOriginll
All about making it look good ;)
llOriginll's Avatar
llOriginll has yet to learn the way of the Dremel
Might be a stupid idea, but why don't we have RAM chips with heatsinks that go /// (or more sideways) away from the heatsink? They'd be lower profile again and would avoid contact with large CPU coolers :P
__________________
Coolermaster HAF 922 Powdered Red - ASUS Crosshair IV Formula - AMD Phenom x4 955 - Asus 1GB 560ti
- Corsair TX650W - Seagate Barracuda 500gig - Thermalright Ultra 120 w/ 2x 120mm Apache's - Asus 7.1 Xonar
llOriginll is offline   Reply With Quote
Old 25th Nov 2010, 08:48   #5
Snips
I can do dat, giz a job
Snips's Avatar
Snips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming Saiyan
"Overclockin' Ram that's kind to your Afro!"
Snips is offline   Reply With Quote
Old 25th Nov 2010, 22:47   #6
Taniniver
Multimodder
Taniniver has yet to learn the way of the DremelTaniniver has yet to learn the way of the Dremel
Sounds like a good idea to me, do all RAM sockets face the same way though on different motherboards? The DIMMs only go in one way round, so it wouldn't be much good if they ended up pointed \\\ towards the CPU cooler instead of away from it!
Taniniver is offline   Reply With Quote
Old 12th Dec 2010, 19:39   #7
ferdinand
Banned
ferdinand has yet to learn the way of the Dremel
Hello, this is a really fascinating web blog and ive loved reading several of the articles and posts contained upon the site, sustain the great work and hope to read a lot more exciting articles in the time to come.
ferdinand is offline   Reply With Quote
Old 5th Jun 2011, 16:22   #8
papasha408
What's a Dremel?
papasha408 has yet to learn the way of the Dremel
I am interested in all OCZ ram. Unfortunately, Blade ram is hard to find in my neck of the woods. I am also finding it hard to get a price on the new Blade 2 ram. Does anyone have an idea concerning price of 3X4, 12GB Blade 2 at 2133 and 2400 mhz?
papasha408 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
