Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 29th Nov 2010, 08:10   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
QNAP TS-210 Turbo NAS Review
http://www.bit-tech.net/hardware/net...10-turbo-nas/1
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 29th Nov 2010, 08:42   #2
Fractal
I Think Therefore I Mod
Fractal's Avatar
Fractal has yet to learn the way of the Dremel
Yawn... Wake me up when off-the shelf NAS boxes either maximise Gigabit bandwidth or are cheap enough to justify the slow speed.
Fractal is offline   Reply With Quote
Old 29th Nov 2010, 08:51   #3
srmans
What's a Dremel?
srmans has yet to learn the way of the Dremel
Agreed, they could be cheaper but then don't forget they offer other advantages some of us need i.e. easy of setup and low power consumption.
Bit-tech, any chance you could update your performance charts in this review or future storage reviews to show baselines Win7PC-2-Win7PC transfers, or Linux for that matter on similar storage (green drives) and network (1GbE) hardware? This would allow us to view NAS storage performance in the context that most of us are familiar with i.e. peer to peer Windows shares. The added context would be very helpful, you could use two "Affordable" build machines perhaps....
srmans is offline   Reply With Quote
Old 29th Nov 2010, 09:04   #4
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
I don't see why not - will try to get the numbers in the next week or two using our test gear!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 29th Nov 2010, 12:30   #5
GW42
Minimodder
GW42 has yet to learn the way of the Dremel
certainly doesn't meet the first criteria, but you can get the netgear stora for 50 for a (empty) 2 drive NAS. Top speed is only about 20MB/s on large sequential files, but the speeds are at least above the truly bottom of the barrel "gigabit" equipped NAS's that can't even max out a 100Mbit connection.
The Stora isn't fast, but it is low power and it is cheap (which is reflected in it's software....) I had been holding out on NAS's as I always thought they were overpriced for what they were - 50 got me the functionality of a NAS without thinking I'd have been better to build myself a low power pc.
GW42 is offline   Reply With Quote
Old 29th Nov 2010, 13:35   #6
jimbok11
Minimodder
jimbok11 has yet to learn the way of the Dremel
quick one - not sure if it's mentioned in the review (and I just missed it), but I'm assuming that drive spindown is present?
reason I ask is because I've read on other sites that a lot of the cheaper NAS boxes don't really offer it...
jimbok11 is offline   Reply With Quote
Old 29th Nov 2010, 16:25   #7
Aracos
Ultramodder
Aracos's Avatar
Aracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run Crysis
So would bit-tech get this or the DS210+?
__________________
Originally Posted by Ubisoft CEO
Our clear goal today is to come more regularly with our top brands
Ragnarok: i5 750 @ 3200MHz | Titan Fenrir | MSI P55-GD65 | 8GiB Vengence 1600MHz CAS 9 | 1GiB 6950 DirectCU II | 60GB Crucial M4 | Samsung F3 500GB | Samsung F3 1TB | Seasonic X-750 | X-Fi XtremeGamer | HAF932 | Win 7 Pro | openSUSE
Aracos is offline   Reply With Quote
Old 29th Nov 2010, 19:09   #8
TWeaK
Supermodder
TWeaK's Avatar
TWeaK has yet to learn the way of the Dremel
Given that the DS210+ got a recommended award I'd say the answer to that question is pretty clear, even if this is half the price.
TWeaK is offline   Reply With Quote
Old 30th Nov 2010, 04:36   #9
1-0-1
Nothing interesting to put here.
1-0-1's Avatar
1-0-1 has yet to learn the way of the Dremel
Was this not tested with iSCSI and maybe also with different Jumbo frame types? Jumbo frames will most properly not used as a plug and play option for most users and the lack to adjust MTU sizes on unmanaged switches is also not helping here. Eitherway it would be cool to see the difference what iSCSI/Jumbo Frames does to the performance of this unit.
1-0-1 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
