Case Mod - In Progress [Worklog] Purple LI
Discussion in 'Project Logs' started by aRkangeL, 29 Nov 2010.
  1. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Projecto Purple LI
    Hi all, i will start my new project, with little lian li.
    I want to make something beautiful:rolleyes::toast:
    Sponsor's WebSite Link's:
    http://www.aquatuning.com
    http://www.adata.com.tw
    http://www.seasonic.com/
    http://www.bitspower.com.tw/
    http://www.alphacool.com/
    A great thanks to every sponsor, without you nothing its possibel.
    hardware
    CPU: Intel i5 2500k
    Board: Asus P8P67M PRO
    Ram: Adata Plus V2.0 1866+
    VGA: Asus 5850 1Gb
    PSU: Seasonic X-760
    Case: LIAN LI PC-A04
    HDD: ???
    Watercooling
    Rad: Phobya G-Changer 240@white
    Block CPU: Alphacool HF 14 Yellowstone Silver
    Block VGA: EK-FC Nickel Plexi
    Pump:Phobya DCP 4.0
    Res:EK Combo DCP v4.0
    Conectors:???
    Tube:Tygon
    Liquid:Fluid XP UV Purple
    Other Stuff:
    Scythe Himuro
    Fans??
    Lot's of MDPC-X Sleeving
    FlexLight LEDs white
  2. WWISCHERATH
    WWISCHERATH What's a Dremel?
    6 Oct 2010
    Ok, this could be interesting. Whats the plan?
  3. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Make a mATX medium-powerfull rig, with WC and mod the case.
  4. DeadP1xels
    30 Nov 2009
    This is going to be cool
    i watch
  5. DerKeiser
    DerKeiser What's a Dremel?
    9 Nov 2010
    hmm... for the rad the best you could prob do is get one dual 240/280 for the gfx card and a 120/140 for the cpu.
    but that would require some serious modding; ROCK ON DUDE:)
  6. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    I shall be watching this!
  7. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Yes but i guess one 240 or 280 is enough.
  8. DerKeiser
    9 Nov 2010
    hmmm, if you say so!
    the reason i would go with more rad power is because of that expensive gfx card you got there.
    are you planning on a single loop? if so, your gfx may cause an increase in cpu temps. just giving heads up to you; but its your rig! :rock:
  9. mars-bar-man
    17 Apr 2009
    Right, here's my input, have a 240mm rad, and put a 120mm rad on teh back on the mount. And have push/pull fans on all the rads, it's the only way you'll see decent temps I reckon.
  10. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    I've seen an i7 920 and a 5870 with only a fine of 240 rad, and with acceptable temps, so it should be no problem. But I can consider putting the rad with fans in push-pull,
    And this is also a secondary rig since I have a show here at home, 800D with a 360mm rad and one 140mm
    Yes and but as I explained above, do not want an animal performance, and the cpu that it will take, it's nothing too big.
  11. mars-bar-man
    17 Apr 2009
    Even though, it's better to have it cooler. Otherwise there's not much point to the watercooling in fairness.
    Have you got a link to that i7 920 and 5870 on the single 240mm rad?
  12. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    No i don't because i saw this on the store.
  13. mars-bar-man
    17 Apr 2009
    You saw it in a shop? Fair shout then. I personally wouldn't want to run that kind of hardware on justa 240mm rad, unless they were running 3000rpm fans. But even then.
    I'd still personally go for at least a push/pull on the front rad.
  14. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Yes but I will probably make a new top for the case, and then takes one of 280 rad at the top, but it is all a bit unsure, because I need to have the first box to know what I'm doing and what material I can put it in!
  15. Ripitup121
    Ripitup121 MMMMMMm watercooling....
    18 Aug 2010
    I like, looking forward to seeing some progress :) :thumb:
  16. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Ok,
    its Hard to get money to compunets.
  17. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    First post updated!
  18. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    And it is!
    So Sexyy:D:D
  19. Hannes
    Hannes Design | Art | Performance
    24 Apr 2010
    Give us MOAR (..more) brother! :-D
  20. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Wait for the next session! AHAH
    Another box its incoming with sexy things! AHAH
